root/Development/ray/doc/man/man1/rcontrib.1
Revision: 1.18
Committed: Wed Sep 9 21:28:19 2020 UTC (5 years, 3 months ago) by greg
Changes since 1.17: +8 -1 lines
1 .\" RCSid "$Id: rcontrib.1,v 1.17 2020/03/14 16:25:46 greg Exp $"
2 .TH RCONTRIB 1 5/25/05 RADIANCE
3 .SH NAME
4 rcontrib - compute contribution coefficients in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B \-V
11 ][
12 .B "\-t secs"
13 ][
14 .B "\-c count"
15 ][
16 .B \-fo
17 |
18 .B \-r
19 ][
20 .B "\-e expr"
21 ][
22 .B "\-f source"
23 ][
24 .B "\-o ospec"
25 ][
26 .B "\-p p1=V1,p2=V2"
27 ][
28 .B "\-b binv"
29 ][
30 .B "\-bn nbins"
31 ]
32 {
33 .B "\-m mod | \-M file"
34 }
35 ..
36 [
37 .B $EVAR
38 ]
39 [
40 .B @file
41 ]
42 [
43 rtrace options
44 ]
45 .B octree
46 .br
47 .B "rcontrib [ options ] \-defaults"
48 .SH DESCRIPTION
49 .I Rcontrib
50 computes ray coefficients
51 for objects whose modifiers are named in one or more
52 .I \-m
53 settings.
54 These modifiers are usually materials associated with
55 light sources or sky domes, and must directly modify some geometric
56 primitives to be considered in the output.
57 A modifier list may also be read from a file using the
58 .I \-M
59 option.
60 The RAYPATH environment variable determines directories to search for
61 this file.
62 (No search takes place if a file name begins with a '.', '/' or '~'
63 character.)\0
64 .PP
65 If the
66 .I \-n
67 option is specified with a value greater than 1, multiple
68 processes will be used to accelerate computation on a shared
69 memory machine.
70 Note that there is no benefit to using more processes
71 than there are local CPUs available to do the work, and the
72 .I rcontrib
73 process itself may use a considerable amount of CPU time.
74 .PP
75 By setting the boolean
76 .I \-V
77 option, you may instruct
78 .I rcontrib
79 to report the contribution from each material rather than the ray
80 coefficient.
81 This is particularly useful for light sources with directional output
82 distributions, whose value would otherwise be lost in the shuffle.
83 With the default
84 .I -V-
85 setting, the output of rcontrib is a coefficient that must be multiplied
86 by the radiance of each material to arrive at a final contribution.
87 This is more convenient for computing daylight coefficeints, or cases
88 where the actual radiance is not desired.
89 Use the
90 .I -V+
91 setting when you wish to simply sum together contributions
92 (with possible adjustment factors) to obtain a final radiance value.
93 Combined with the
94 .I \-i
95 or
96 .I \-I
97 option, irradiance contributions are reported by
98 .I \-V+
99 rather than radiance, and
100 .I \-V-
101 coefficients contain an additonal factor of PI.
102 .PP
103 The
104 .I \-c
105 option tells
106 .I rcontrib
107 how many rays to accumulate for each record.
108 The default value is one, meaning a full record will be produced for
109 each input ray.
110 For values greater than one, contributions will be averaged together
111 over the given number of input rays.
112 If set to zero, only a single record will be produced at the very
113 end, corresponding to the sum of all rays given on the input
114 (rather than the average).
115 This is equivalent to passing all the output records through a program like
116 .I total(1)
117 to sum RGB values together, but is much more efficient.
118 Using this option, it is possible to reverse sampling, sending rays from
119 a parallel source such as the sun to a diffuse surface, for example.
120 Note that output flushing via zero-direction rays is disabled with
121 .I \-c
122 set to zero.
123 .PP
124 If progress reports are desired, the
125 .I \-t
126 option specifies a time interval in seconds for reports sent to
127 standard error.
128 .PP
129 The output of
130 .I rcontrib
131 has many potential uses.
132 Source contributions can be used as components in linear combination to
133 reproduce any desired variation, e.g., simulating lighting controls or
134 changing sky conditions via daylight coefficients.
135 More generally,
136 .I rcontrib
137 can be used to compute arbitrary input-output relationships in optical
138 systems, such as luminaires, light pipes, and shading devices.
139 .PP
140 .I Rcontrib
141 sends the accumulated rays tallies
142 to one or more destinations according to the given
143 .I \-o
144 specification.
145 If a destination begins with an exclamation mark ('!'), then
146 a pipe is opened to a command and data is sent to its standard input.
147 Otherwise, the destination is treated as a file.
148 An existing file of the same name will not be clobbered, unless the
149 .I \-fo
150 option is given.
151 If instead the
152 .I \-r
153 option is specified, data recovery is attempted on existing files.
154 (If
155 .I "\-c 0"
156 is used together with the
157 .I \-r
158 option, existing files are read in and new ray evaluations are added
159 to the previous results, providing a convenient means for
160 progressive simulation.)\0
161 If an output specification contains a "%s" format, this will be
162 replaced by the modifier name.
163 The
164 .I \-b
165 option may be used to further define
166 a "bin number" within each object if finer resolution is needed, and
167 this will be applied to a "%d" format in the output file
168 specification if present.
169 (The final integer will be offset incrementally
170 if the output is a RADIANCE picture and more than one modifier has
171 the same format specification.)\0
172 The actual bin number is computed at run time based on ray direction
173 and surface intersection, as described below.
174 The number of bins must be specified in advance with the
175 .I \-bn
176 option, and this is critical for output files containing multiple values
177 per record.
178 A variable or constant name may be given for this parameter if
179 it has been defined via a previous
180 .I \-f
181 or
182 .I \-e
183 option.
184 Since bin numbers start from zero, the bin count is always equal to
185 the last bin plus one.
186 The most recent
187 .I \-p,
188 .I \-b,
189 .I \-bn
190 and
191 .I \-o
192 options to the left of each
193 .I \-m
194 setting are the ones used for that modifier.
195 The ordering of other options is unimportant, except for
196 .I \-x
197 and
198 .I \-y
199 if the
200 .I \-c
201 is zero, when they control the resolution string
202 produced in the corresponding output.
203 .PP
204 If a
205 .I \-b
206 expression is defined for a particular modifier,
207 the bin number will be evaluated at run time for each
208 ray contribution.
209 Specifically, each ray's world intersection point will be assigned to
210 the variables Px, Py, and Pz, and the normalized ray direction
211 will be assigned to Dx, Dy, and Dz.
212 These parameters may be combined with definitions given in
213 .I \-e
214 arguments and files read using the
215 .I \-f
216 option.
217 Additional parameter values that apply only to this modifier may be specified
218 with a
219 .I \-p
220 option, which contains a list of variable names and assigned values, separated
221 by commas, colons, or semicolons.
222 The computed bin value will be
223 rounded to the nearest whole number.
224 (Negative bin values will be silently ignored.)\0
225 For a single bin, you may specify
226 .I "\-b 0",
227 which is the default.
228 This mechanism allows the user to define precise regions or directions
229 they wish to accumulate, such as the Tregenza sky discretization,
230 which would be otherwise impossible to specify
231 as a set of RADIANCE primitives.
232 The rules and predefined functions available for these expressions are
233 described in the
234 .I rcalc(1)
235 man page.
237 .I rcalc,
238 .I rcontrib
239 will search the RADIANCE library directories for each file given in a
240 .I \-f
241 option.
242 .PP
243 If no
244 .I \-o
245 specification is given, results are written on the standard output in order
246 of modifier (as given on the command line) then bin number.
247 Concatenated data is also sent to a single destination (i.e., an initial
248 .I \-o
249 specification without formatting strings).
250 If a "%s" format appears but no "%d" in the
251 .I \-o
252 specification, then each modifier will have its own output file, with
253 multiple values per record in the case of a non-zero
254 .I \-b
255 definition.
256 If a "%d" format appears but no "%s", then each bin will get its own
257 output file, with modifiers output in order in each record.
258 For text output, each RGB coefficient triple is separated by a tab,
259 with a newline at the end of each ray record.
260 For binary output formats, there is no such delimiter to mark
261 the end of each record.
262 .PP
263 Input and output format defaults to plain text, where each ray's
264 origin and direction (6 real values) are given on input,
265 and one line is produced per output file per ray.
266 Alternative data representations may be specified by the
267 .I \-f[io]
268 option, which is described in the
269 .I rtrace
270 man page along with the associated
271 .I \-x
272 and
273 .I \-y
274 resolution settings.
275 In particular, the color ('c') output data representation
276 together with positive dimensions for
277 .I \-x
278 and
279 .I \-y
280 will produce an uncompressed RADIANCE picture,
281 suitable for manipulation with
282 .I pcomb(1)
283 and related tools.
284 .PP
285 Options may be given on the command line and/or read from the
286 environment and/or read from a file.
287 A command argument beginning with a dollar sign ('$') is immediately
288 replaced by the contents of the given environment variable.
289 A command argument beginning with an at sign ('@') is immediately
290 replaced by the contents of the given file.
291 .PP
292 .I Rcontrib
293 supports light source contributions from photon maps generated by
294 .I mkpmap(1)
295 with its
296 .I -apC
297 option. Enabling photon mapping is described in the
298 .I rtrace
299 man page along with its relevant settings. In photon mapping mode,
300 .I rcontrib
301 only supports contributions from light sources, not arbitrary modifiers.
302 The
303 .I -b
304 option is supported along with its associated ray variables, as
305 discussed above. Ray coefficients are also supported via the
306 .I \-V-
307 option. Using fewer photons than there are light sources for the photon
308 density estimates results in omitted contributions, thus the bandwidth
309 is clamped accordingly and a warning is issued.
310 .SH EXAMPLES
311 To compute the proportional contributions from sources modified
312 by "light1" vs. "light2" on a set of illuminance values:
313 .IP "" .2i
314 rcontrib \-I+ @render.opt \-o c_%s.dat \-m light1 \-m light2 scene.oct < test.dat
315 .PP
316 To generate a pair of images corresponding to these two lights'
317 contributions:
318 .IP "" .2i
319 vwrays \-ff \-x 1024 \-y 1024 \-vf best.vf |
320 rcontrib \-ffc `vwrays \-d \-x 1024 \-y 1024 \-vf best.vf`
321 @render.opt \-o c_%s.hdr \-m light1 \-m light2 scene.oct
322 .PP
323 These images may then be recombined using the desired outputs
324 of light1 and light2:
325 .IP "" .2i
326 pcomb \-c 100 90 75 c_light1.hdr \-c 50 55 57 c_light2.hdr > combined.hdr
327 .PP
328 To compute an array of illuminance contributions according to a Tregenza sky:
329 .IP "" .2i
330 rcontrib \-I+ \-f tregenza.cal \-b tbin \-bn Ntbins \-o sky.dat \-m skyglow
331 \-b 0 \-o ground.dat \-m groundglow @render.opt scene.oct < test.dat
332 .PP
333 To perform an annual simulation of 365 daily sun positions in photon mapping
334 mode:
335 .IP "" .2i
336 rcontrib \-I+ \-h \-V \-fo \-o c_%s.dat \-M lights \-ap contrib.pm 365
337 scene.oct < test.dat,
338 .SH ENVIRONMENT
339 RAYPATH path to search for \-f and \-M files
340 .SH BUGS
341 We do not currently compute contributions or coefficients properly
342 in scenes with participating media.
343 A single warning will be issued if a scattering or absorbing medium
344 is detected.
345 .SH AUTHOR
346 Greg Ward
347 .SH "SEE ALSO"
348 cnt(1), genklemsamp(1), getinfo(1), mkpmap(1), pcomb(1), pfilt(1),
349 ra_rgbe(1), rcalc(1), rfluxmtx(1), rmtxop(1), rpict(1), rsensor(1),
350 rtrace(1), total(1), vwrays(1), ximage(1)
351
