root/Development/ray/doc/man/man1/rcontrib.1
Revision: 1.15
Committed: Fri Jan 26 18:31:23 2018 UTC (7 years, 10 months ago) by rschregle
Changes since 1.14: +5 -3 lines
Referred to rtrace for pmap settings
1 .\" RCSid "$Id: rcontrib.1,v 1.14 2018/01/26 18:11:50 rschregle Exp $"
2 .TH RCONTRIB 1 5/25/05 RADIANCE
3 .SH NAME
4 rcontrib - compute contribution coefficients in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B \-V
11 ][
12 .B "\-c count"
13 ][
14 .B \-fo
15 |
16 .B \-r
17 ][
18 .B "\-e expr"
19 ][
20 .B "\-f source"
21 ][
22 .B "\-o ospec"
23 ][
24 .B "\-p p1=V1,p2=V2"
25 ][
26 .B "\-b binv"
27 ][
28 .B "\-bn nbins"
29 ]
30 {
31 .B "\-m mod | \-M file"
32 }
33 ..
34 [
35 .B $EVAR
36 ]
37 [
38 .B @file
39 ]
40 [
41 rtrace options
42 ]
43 .B octree
44 .br
45 .B "rcontrib [ options ] \-defaults"
46 .SH DESCRIPTION
47 .I Rcontrib
48 computes ray coefficients
49 for objects whose modifiers are named in one or more
50 .I \-m
51 settings.
52 These modifiers are usually materials associated with
53 light sources or sky domes, and must directly modify some geometric
54 primitives to be considered in the output.
55 A modifier list may also be read from a file using the
56 .I \-M
57 option.
58 The RAYPATH environment variable determines directories to search for
59 this file.
60 (No search takes place if a file name begins with a '.', '/' or '~'
61 character.)\0
62 .PP
63 If the
64 .I \-n
65 option is specified with a value greater than 1, multiple
66 processes will be used to accelerate computation on a shared
67 memory machine.
68 Note that there is no benefit to using more processes
69 than there are local CPUs available to do the work, and the
70 .I rcontrib
71 process itself may use a considerable amount of CPU time.
72 .PP
73 By setting the boolean
74 .I \-V
75 option, you may instruct
76 .I rcontrib
77 to report the contribution from each material rather than the ray
78 coefficient.
79 This is particularly useful for light sources with directional output
80 distributions, whose value would otherwise be lost in the shuffle.
81 With the default
82 .I -V-
83 setting, the output of rcontrib is a coefficient that must be multiplied
84 by the radiance of each material to arrive at a final contribution.
85 This is more convenient for computing daylight coefficeints, or cases
86 where the actual radiance is not desired.
87 Use the
88 .I -V+
89 setting when you wish to simply sum together contributions
90 (with possible adjustment factors) to obtain a final radiance value.
91 Combined with the
92 .I \-i
93 or
94 .I \-I
95 option, irradiance contributions are reported by
96 .I \-V+
97 rather than radiance, and
98 .I \-V-
99 coefficients contain an additonal factor of PI.
100 .PP
101 The
102 .I \-c
103 option tells
104 .I rcontrib
105 how many rays to accumulate for each record.
106 The default value is one, meaning a full record will be produced for
107 each input ray.
108 For values greater than one, contributions will be averaged together
109 over the given number of input rays.
110 If set to zero, only a single record will be produced at the very
111 end, corresponding to the sum of all rays given on the input
112 (rather than the average).
113 This is equivalent to passing all the output records through a program like
114 .I total(1)
115 to sum RGB values together, but is much more efficient.
116 Using this option, it is possible to reverse sampling, sending rays from
117 a parallel source such as the sun to a diffuse surface, for example.
118 Note that output flushing via zero-direction rays is disabled with
119 .I \-c
120 set to zero.
121 .PP
122 The output of
123 .I rcontrib
124 has many potential uses.
125 Source contributions can be used as components in linear combination to
126 reproduce any desired variation, e.g., simulating lighting controls or
127 changing sky conditions via daylight coefficients.
128 More generally,
129 .I rcontrib
130 can be used to compute arbitrary input-output relationships in optical
131 systems, such as luminaires, light pipes, and shading devices.
132 .PP
133 .I Rcontrib
134 sends the accumulated rays tallies
135 to one or more destinations according to the given
136 .I \-o
137 specification.
138 If a destination begins with an exclamation mark ('!'), then
139 a pipe is opened to a command and data is sent to its standard input.
140 Otherwise, the destination is treated as a file.
141 An existing file of the same name will not be clobbered, unless the
142 .I \-fo
143 option is given.
144 If instead the
145 .I \-r
146 option is specified, data recovery is attempted on existing files.
147 (If
148 .I "\-c 0"
149 is used together with the
150 .I \-r
151 option, existing files are read in and new ray evaluations are added
152 to the previous results, providing a convenient means for
153 progressive simulation.)\0
154 If an output specification contains a "%s" format, this will be
155 replaced by the modifier name.
156 The
157 .I \-b
158 option may be used to further define
159 a "bin number" within each object if finer resolution is needed, and
160 this will be applied to a "%d" format in the output file
161 specification if present.
162 (The final integer will be offset incrementally
163 if the output is a RADIANCE picture and more than one modifier has
164 the same format specification.)\0
165 The actual bin number is computed at run time based on ray direction
166 and surface intersection, as described below.
167 The number of bins must be specified in advance with the
168 .I \-bn
169 option, and this is critical for output files containing multiple values
170 per record.
171 A variable or constant name may be given for this parameter if
172 it has been defined via a previous
173 .I \-f
174 or
175 .I \-e
176 option.
177 Since bin numbers start from zero, the bin count is always equal to
178 the last bin plus one.
179 The most recent
180 .I \-p,
181 .I \-b,
182 .I \-bn
183 and
184 .I \-o
185 options to the left of each
186 .I \-m
187 setting are the ones used for that modifier.
188 The ordering of other options is unimportant, except for
189 .I \-x
190 and
191 .I \-y
192 if the
193 .I \-c
194 is zero, when they control the resolution string
195 produced in the corresponding output.
196 .PP
197 If a
198 .I \-b
199 expression is defined for a particular modifier,
200 the bin number will be evaluated at run time for each
201 ray contribution.
202 Specifically, each ray's world intersection point will be assigned to
203 the variables Px, Py, and Pz, and the normalized ray direction
204 will be assigned to Dx, Dy, and Dz.
205 These parameters may be combined with definitions given in
206 .I \-e
207 arguments and files read using the
208 .I \-f
209 option.
210 Additional parameter values that apply only to this modifier may be specified
211 with a
212 .I \-p
213 option, which contains a list of variable names and assigned values, separated
214 by commas or semicolons.
215 The computed bin value will be
216 rounded to the nearest whole number.
217 (Negative bin values will be silently ignored.)\0
218 For a single bin, you may specify
219 .I "\-b 0",
220 which is the default.
221 This mechanism allows the user to define precise regions or directions
222 they wish to accumulate, such as the Tregenza sky discretization,
223 which would be otherwise impossible to specify
224 as a set of RADIANCE primitives.
225 The rules and predefined functions available for these expressions are
226 described in the
227 .I rcalc(1)
228 man page.
230 .I rcalc,
231 .I rcontrib
232 will search the RADIANCE library directories for each file given in a
233 .I \-f
234 option.
235 .PP
236 If no
237 .I \-o
238 specification is given, results are written on the standard output in order
239 of modifier (as given on the command line) then bin number.
240 Concatenated data is also sent to a single destination (i.e., an initial
241 .I \-o
242 specification without formatting strings).
243 If a "%s" format appears but no "%d" in the
244 .I \-o
245 specification, then each modifier will have its own output file, with
246 multiple values per record in the case of a non-zero
247 .I \-b
248 definition.
249 If a "%d" format appears but no "%s", then each bin will get its own
250 output file, with modifiers output in order in each record.
251 For text output, each RGB coefficient triple is separated by a tab,
252 with a newline at the end of each ray record.
253 For binary output formats, there is no such delimiter to mark
254 the end of each record.
255 .PP
256 Input and output format defaults to plain text, where each ray's
257 origin and direction (6 real values) are given on input,
258 and one line is produced per output file per ray.
259 Alternative data representations may be specified by the
260 .I \-f[io]
261 option, which is described in the
262 .I rtrace
263 man page along with the associated
264 .I \-x
265 and
266 .I \-y
267 resolution settings.
268 In particular, the color ('c') output data representation
269 together with positive dimensions for
270 .I \-x
271 and
272 .I \-y
273 will produce an uncompressed RADIANCE picture,
274 suitable for manipulation with
275 .I pcomb(1)
276 and related tools.
277 .PP
278 Options may be given on the command line and/or read from the
279 environment and/or read from a file.
280 A command argument beginning with a dollar sign ('$') is immediately
281 replaced by the contents of the given environment variable.
282 A command argument beginning with an at sign ('@') is immediately
283 replaced by the contents of the given file.
284 .PP
285 .I Rcontrib
286 supports light source contributions from photon maps generated by
287 .I mkpmap(1)
288 with its
289 .I -apC
290 option. Enabling photon mapping is described in the
291 .I rtrace
292 man page along with its relevant settings. In photon mapping mode,
293 .I rcontrib
294 only supports contributions from light sources, not arbitrary modifiers.
295 The
296 .I -b
297 option is supported along with its associated ray variables, as
298 discussed above. Ray coefficients are also supported via the
299 .I \-V-
300 option. Using fewer photons than there are light sources for the photon
301 density estimates results in omitted contributions, thus the bandwidth
302 is clamped accordingly and a warning is issued.
303 .SH EXAMPLES
304 To compute the proportional contributions from sources modified
305 by "light1" vs. "light2" on a set of illuminance values:
306 .IP "" .2i
307 rcontrib \-I+ @render.opt \-o c_%s.dat \-m light1 \-m light2 scene.oct < test.dat
308 .PP
309 To generate a pair of images corresponding to these two lights'
310 contributions:
311 .IP "" .2i
312 vwrays \-ff \-x 1024 \-y 1024 \-vf best.vf |
313 rcontrib \-ffc `vwrays \-d \-x 1024 \-y 1024 \-vf best.vf`
314 @render.opt \-o c_%s.hdr \-m light1 \-m light2 scene.oct
315 .PP
316 These images may then be recombined using the desired outputs
317 of light1 and light2:
318 .IP "" .2i
319 pcomb \-c 100 90 75 c_light1.hdr \-c 50 55 57 c_light2.hdr > combined.hdr
320 .PP
321 To compute an array of illuminance contributions according to a Tregenza sky:
322 .IP "" .2i
323 rcontrib \-I+ \-f tregenza.cal \-b tbin \-bn Ntbins \-o sky.dat \-m skyglow
324 \-b 0 \-o ground.dat \-m groundglow @render.opt scene.oct < test.dat
325 .PP
326 To perform an annual simulation of 365 daily sun positions in photon mapping
327 mode:
328 .IP "" .2i
329 rcontrib \-I+ \-h \-V \-fo \-o c_%s.dat \-M lights \-ap contrib.pm 365
330 scene.oct < test.dat,
331 .SH ENVIRONMENT
332 RAYPATH path to search for \-f and \-M files
333 .SH AUTHOR
334 Greg Ward
335 .SH "SEE ALSO"
336 cnt(1), genklemsamp(1), getinfo(1), mkpmap(1), pcomb(1), pfilt(1),
337 ra_rgbe(1), rcalc(1), rfluxmtx(1), rmtxop(1), rpict(1), rsensor(1),
338 rtrace(1), total(1), vwrays(1), ximage(1)
339
