root/Development/ray/doc/man/man1/rcontrib.1
Thu Nov 13 20:31:53 2025 UTC (4 weeks, 2 days ago) by greg
Diff to previous 1.27 , to selected 1.15
docs(rcontrib): New wording clarification
Thu Oct 23 23:34:59 2025 UTC (7 weeks, 2 days ago) by greg
Changes since 1.26: +2 -6 lines
Diff to previous 1.26 , to selected 1.15
docs: Added rxfluxmtx man page and updated others accordingly
Wed Apr 23 15:09:03 2025 UTC (7 months, 3 weeks ago) by greg
CVS Tags: rad6R0
Changes since 1.25: +12 -4 lines
Diff to previous 1.25 , to selected 1.15
docs: Wording fixes to man pages regarding -e and -f options
Thu Mar 27 01:26:55 2025 UTC (8 months, 2 weeks ago) by greg
Changes since 1.24: +3 -3 lines
Diff to previous 1.24 , to selected 1.15
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
Wed Oct 23 23:51:20 2024 UTC (13 months, 3 weeks ago) by greg
Changes since 1.23: +6 -2 lines
Diff to previous 1.23 , to selected 1.15
fix(rcontrib): Added a check that the number of color samples doesn't change after the first modifier is specified
Tue Dec 12 16:31:45 2023 UTC (2 years ago) by greg
Diff to previous 1.22 , to selected 1.15
Wed Dec 6 01:27:00 2023 UTC (2 years ago) by greg
Changes since 1.21: +3 -3 lines
Diff to previous 1.21 , to selected 1.15
docs(rmtxcomb): Added man page for new rmtxcomb tool
Wed Oct 19 21:25:20 2022 UTC (3 years, 1 month ago) by greg
Changes since 1.20: +3 -1 lines
Diff to previous 1.20 , to selected 1.15
Wed Oct 19 18:23:14 2022 UTC (3 years, 1 month ago) by greg
Diff to previous 1.19 , to selected 1.15
docs: made use of "virtual" and "secondary" sources more consistent
Thu Sep 10 17:52:46 2020 UTC (5 years, 3 months ago) by greg
Changes since 1.18: +16 -1 lines
Diff to previous 1.18 , to selected 1.15
doc(rcontrib): Clarified -x and -y settings and interactions with -c, -t
Wed Sep 9 21:28:19 2020 UTC (5 years, 3 months ago) by greg
Changes since 1.17: +8 -1 lines
Diff to previous 1.17 , to selected 1.15
Sat Mar 14 16:25:46 2020 UTC (5 years, 9 months ago) by greg
Diff to previous 1.16 , to selected 1.15
Allow for colon as separator in parameter settings
Fri Feb 22 19:42:27 2019 UTC (6 years, 9 months ago) by greg
Changes since 1.15: +6 -1 lines
Diff to previous 1.15
Added warning for contribution coefficient calculation with participating media
Revision 1.15 - (view) (download) (annotate) - [selected]
Fri Jan 26 18:31:23 2018 UTC (7 years, 10 months ago) by rschregle
Changes since 1.14: +5 -3 lines
Diff to previous 1.14
Referred to rtrace for pmap settings
Fri Jan 26 18:11:50 2018 UTC (7 years, 10 months ago) by rschregle
Changes since 1.13: +2 -3 lines
Diff to previous 1.13 , to selected 1.15
Revised documentation of rcontrib's photon mapping mode; Promoted from
experimental (to semi-mature? ;^)
Mon Sep 12 20:31:34 2016 UTC (9 years, 3 months ago) by greg
Changes since 1.12: +5 -2 lines
Diff to previous 1.12 , to selected 1.15
Tue Feb 24 19:39:26 2015 UTC (10 years, 9 months ago) by greg
Changes since 1.11: +29 -4 lines
Diff to previous 1.11 , to selected 1.15
Tue Jul 22 21:55:31 2014 UTC (11 years, 4 months ago) by greg
Diff to previous 1.10 , to selected 1.15
Sat Jul 19 18:19:33 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.9: +9 -1 lines
Diff to previous 1.9 , to selected 1.15
Sat Jul 19 00:07:03 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.8: +2 -1 lines
Diff to previous 1.8 , to selected 1.15
Silently ignore negative bin values.
Fri Jul 11 01:52:38 2014 UTC (11 years, 5 months ago) by greg
Changes since 1.7: +5 -3 lines
Diff to previous 1.7 , to selected 1.15
Corrected errors in description
Fri Nov 1 15:32:58 2013 UTC (12 years, 1 month ago) by greg
Diff to previous 1.6 , to selected 1.15
Corrected errors in final example mentioned by Lars Grobe
Thu Nov 15 19:41:03 2012 UTC (13 years, 1 month ago) by greg
Changes since 1.5: +10 -9 lines
Diff to previous 1.5 , to selected 1.15
Thu Jun 14 22:51:04 2012 UTC (13 years, 6 months ago) by greg
Diff to previous 1.4 , to selected 1.15
Added -bn requirement
Thu Jun 14 22:49:34 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.3: +4 -9 lines
Diff to previous 1.3 , to selected 1.15
Removed inaccurate references to rtrace subprocesses.
Thu Jun 14 22:45:23 2012 UTC (13 years, 6 months ago) by greg
Diff to previous 1.2 , to selected 1.15
Missed a couple of other name changes
Thu Jun 14 22:44:50 2012 UTC (13 years, 6 months ago) by greg
Diff to previous 1.1 , to selected 1.15
Missed one name change
Thu Jun 14 22:42:21 2012 UTC (13 years, 6 months ago) by greg
Diff to selected 1.15
