root/radiance/ray/doc/man/man1/rcomb.1
Revision: 1.13
Committed: Fri Apr 4 18:06:48 2025 UTC (6 weeks, 5 days ago) by greg
Changes since 1.12: +9 -1 lines
# User Rev Content
1 greg 1.13 .\" RCSid "$Id: rcomb.1,v 1.12 2025/03/27 01:26:55 greg Exp $"
2 greg 1.1 .TH RCOMB 12/5/2023 RADIANCE
3     .SH NAME
4     rcomb - combine and convert matrices a row at a time
5     .SH SYNOPSIS
6     .B rcomb
7     [
8     .B \-h
9     ][
10     .B \-w
11     ][
12     .B \-f[afdc]
13     ][
14 greg 1.8 .B "\-n nproc"
15     ][
16 greg 1.1 .B "\-f file"
17     ][
18     .B "\-e expr"
19     ][
20     .B "\-C {symbols|file}"
21     ][
22     .B "\-c ce .."
23     ][
24     .B "\-s sf .."
25     ]
26     .B "m1 .."
27     [
28     .B "\-m mcat"
29     ]
30     .SH DESCRIPTION
31     .I Rcomb
32     combines inputs given on the command line,
33     one matrix row or picture scanline at a time.
34     By default, the result is a linear combination of
35     the matrix elements or pixels transformed by
36     .I \-c
37     specifications and scaled by
38     .I \-s
39     coefficients, but an arbitrary mapping can be assigned with the
40     .I \-e
41     and
42     .I \-f
43     options, similar to the
44     .I pcomb(1)
45     and
46     .I rcalc(1)
47     commands.
48     (The definitions in each
49     .I \-f source
50     file are read and compiled from the RADIANCE library where it is found.)\0
51     .PP
52     If any
53     .I \-c
54     or
55     .I \-s
56     options follow the last input matrix, output results will be transformed
57     and/or scaled accordingly.
58 greg 1.7 These operations are discussed in greater detail below.
59 greg 1.1 A single concatenation matrix may be applied after element operations
60     using the
61     .I \-m
62     option.
63     Matrix concatenation will happen before or after any trailing
64     operations, depending on relative command line placement.
65     .PP
66     Each input file must have a header containing the following metadata:
67     .sp
68     .nf
69     NROWS={number of rows}
70     NCOLS={number of columns}
71     NCOMP={number of components}
72     FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze|Radiance_spectra}
73     .fi
74     .sp
75     The number of components indicates that each matrix element is actually
76 greg 1.7 composed of multiple channels, most commonly an RGB triple.
77 greg 1.1 This is essentially dividing the matrix into planes, where each component
78     participates in a separate calculation.
79     If an appropriate header is not present, it may be added with a call to
80     .I rcollate(1).
81     A matrix may be read from the standard input using a hyphen by itself ('-')
82     in the appropriate place on the command line.
83     Similarly, any of the inputs may be read from a command
84     instead of a file by
85     using quotes and a beginning exclamation point ('!').
86     .PP
87     In the case of Radiance picture files,
88     the number of columns is the X-dimension of the picture, and
89     the number of rows is the Y-dimension.
90     The picture must be in standard pixel ordering, and the zeroeth row
91     is at the top with the zeroeth column on the left.
92     Any exposure changes that were applied to the pictures before
93     .I rcomb
94     will be undone, similar to the
95     .I "pcomb \-o"
96     option.
97     Radiance spectral pictures with more than 3 components are also supported.
98     These are typically produced by
99 greg 1.5 .I rtpict(1)
100 greg 1.1 or
101     .I rfluxmtx(1).
102     .PP
103     Before each input, the
104     .I \-c
105     and/or
106     .I \-s
107     options may be used to modify the matrix elements.
108     The
109     .I \-c
110     option can "transform" the element values, possibly changing
111     the number of components in the matrix.
112     For example, a 3-component matrix can be transformed into a single-component
113     matrix by using
114     .I \-c
115     with three coefficients.
116     A four-component matrix can be turned into a two-component matrix using 8
117     coefficients, where the first four coefficients will be used to compute
118     the first new component, and the second four coefficients
119     yield the second new component.
120     Note that the number of coefficients must be an even multiple of the number
121     of original components.
122     .PP
123     Alternatively, a set of symbolic output components may be given to the
124     .I \-c
125     option, with the following definitions:
126     .sp
127     .nf
128     R - red channel
129     G - green channel
130     B - blue channel
131     X - CIE X channel
132     Y - CIE Y channel (aka., luminance or illuminance)
133     Z - CIE Z channel
134     S - scotopic luminance or illuminance
135     M - melanopic luminance or illuminance
136     A - average component value
137     .fi
138     .sp
139     These letters may be given in any order as a single string, and if
140     .I "-c RGB"
141     or
142     .I "-c XYZ"
143     is specified for an input picture or the
144     .I "-fc"
145     option is given, the output will be written as a RGBE or XYZE picture.
146 greg 1.9 Note that conversion from a float or RGBE color space applies an efficacy factor
147 greg 1.1 of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output),
148 greg 1.9 and the inverse happens for conversion from XYZE input to RGB or RGBE output.
149 greg 1.3 Lower case versions of all these components are also supported, the only
150 greg 1.9 difference being that the efficacy factors are ignored.
151 greg 1.1 .PP
152     If a matrix or picture file path is given to the
153     .I \-c
154     option, then the color space of that file will be used, instead.
155     .PP
156     The
157     .I \-C
158     option takes either a symbolic color space or an input file, and will be
159     applied to all subsequent matrices that do not have their own associated
160     .I \-c
161     option.
162     .PP
163     Additionally, the
164     .I \-s
165     option applies the given scalar factor(s) to the elements of the matrix.
166     If only one factor is provided,
167     it will be used for all components.
168     If multiple factors are given, their number must match the number of matrix
169     components
170     .I after
171     application of any
172     .I \-c
173     option for this input matrix or picture, even if the
174     .I \-s
175     option appears first.
176     .PP
177     The number of components in all input
178     matrices after applying any
179     .I -c
180     transform must agree.
181     Similarly, the number of rows and columns of all results must match
182     exactly.
183     (The
184     .I rcrop(1)
185     utility may be used to trim inputs if necessary.)\0
186     .PP
187     If the
188     .I \-e
189     or
190     .I \-f
191     options are used to define a "co" variable or "co(p)" function,
192 greg 1.7 which will be evaluated for each output
193     component from the current element.
194 greg 1.1 The "co" variable defines identical operations for all components,
195     whereas "co(p)" may specify different operations for each component.
196     The element position is defined
197     by the "r" and "c" variables, where
198     .I r
199     goes from 0 to "nrows" minus one, and
200     .I c
201     goes from 0 to "ncols" minus one.
202 greg 1.2 (Note that "nrows" may be zero if unspecified in inputs, and this
203     is a unique capability of
204     .I rcomb
205     to handle these.)\0
206 greg 1.1 Component p from input i is accessed with the "ci(i,p)" function,
207     and the number of components is defined by the "ncomp" constant.
208     If given as "ci(i)", the function returns the current component
209     being evaluated by
210     .I rcomb.
211 greg 1.6 A different component may be referenced using the second argument.
212 greg 1.1 For example, "ci(1,2)" accesses
213     the second component from the first input.
214     If the input is a picture, the the constants "R", "G", and "B"
215     are conveniently defined as the channel numbers 1, 2, and 3,
216     respectively.
217     For color or spectral inputs, the function "wl(p)" gives the
218     central wavelength for channel
219     .I p
220     in nanometers.
221     For convenience and compatibility with
222     .I pcomb,
223     the functions "ri(i)", "gi(i)", and "bi(i)" are predefined as
224     "ci(i,R)", "ci(i,G)", and "ci(i,B)", respectively.
225     Accordingly, the "ro", "go", and "bo"
226 greg 1.6 variables may be used in place of "co(R)", "co(G)", and "co(B)",
227     but all three must be defined for this substitution to take place.
228 greg 1.1 Finally, the total number of input files is set in the constant "nfiles".
229     .PP
230     Results are sent to the standard output.
231     By default, the values will be written in the lowest precision format
232     among the inputs, but the
233     .I \-f[adfc]
234     option may be used to explicitly output components
235     as ASCII (-fa), binary doubles (-fd), floats (-ff), or common-exponent
236     colors/spectra (-fc).
237     In the latter case, the actual matrix dimensions are written in the resolution string rather than the header.
238     Also, matrix results will be written as standard
239     Radiance pictures if they have either one
240     or three components.
241     In the one-component case, the output is written as grayscale.
242     If more than 3 components are in the final matrix and
243     .I -fc
244     is specified, the output will be a Radiance spectral picture.
245     .PP
246     The
247     .I \-h
248     option may be used to reduce the information header size, which
249     can grow disproportionately, otherwise.
250     The
251     .I \-w
252     option turns off warnings about divide-by-zero and other non-fatal
253     calculation errors.
254 greg 1.8 .PP
255     The
256     .I \-n
257     option specifies how many execution processes to employ,
258     which may improve performance on multi-core architectures,
259     especially for matrix multiplication
260     and complex operations on long input rows.
261 greg 1.1 .SH EXAMPLES
262 greg 1.10 To convert two hyperspectral pictures to RGB color space,
263 greg 1.1 average them together, and write them out as a RADIANCE picture:
264     .IP "" .2i
265 greg 1.10 rcomb -C RGB -s .5 img1.hsr -s .5 -fc img2.hsr > avg.hdr
266 greg 1.1 .PP
267     Divide one set of matrix elements by the Euclidean sum of two others:
268     .IP "" .2i
269     rcomb -e "co=ci(1)/sqrt(ci(2)^2+ci(3)^2)" inp1.mtx
270     inp2.mtx inp3.mtx > out.mtx
271     .PP
272     Compute the absolute and relative differences between melanopic and photopic values
273     in a spectral image:
274     .IP "" .2i
275 greg 1.10 rcomb -C MY -e "abs(x):if(x,x,-x)"
276 greg 1.1 -e "co(p)=select(p,abs(ci(1,1)-ci(1,2)),(ci(1,1)-ci(1,2))/ci(1,2))"
277 greg 1.10 input_spec.hsr -fa > compare.mtx
278 greg 1.1 .PP
279     Concatenate a spectral flux coefficient matrix with a spectral sky
280     matrix to compute a set of melanopic lux values:
281     .IP "" .2i
282     rcomb view_spec.mtx -m sky_spec.mtx -c M > melux.mtx
283     .SH NOTES
284     The
285     .I rcomb
286     tool was created to overcome some limitations of
287     .I rmtxop
288     and
289     .I pcomb,
290     whose capabilities somewhat overlap.
291     The former loads each matrix into memory before operations,
292 greg 1.7 and element components are stored as double-precision.
293 greg 1.1 Very large matrices therefore present a problem with that tool.
294     Furthermore,
295     .I rmtxop
296     does not allow arbitrary expressions, limiting
297     what can be accomplished easily on the command-line.
298     In contrast,
299     .I pcomb
300     is fully programmable and operates on its input using a
301     scanline window, so it can handle much larger input dimensions.
302     It also handles single- and three-component float matrices on
303     input and output, but unlike
304     .I rmtxop,
305     .I pcomb
306     has not been extended to handle RADIANCE hyperspectral images
307     or more general matrix data.
308     .PP
309     The
310     .I rcomb
311     tool is a compromise that exceeds the capabilities of either of
312     its predecessors in certain circumstances.
313     In particular, very large matrices may be combined using
314     arbitrary, user-defined operations, and the convenient
315     color conversions of
316     .I rmtxop
317     are supported for both input and output.
318     Finally, a single matrix may be concatenated after operations,
319     permitting a flux transfer matrix with millions of rows to
320     pass through.
321     Generally speaking,
322     .I rcomb
323     should be preferred over
324     .I rmtxop
325 greg 1.7 for any operations it can handle, which is everything except
326 greg 1.1 multiple matrix concatenations and transpose
327 greg 1.7 operations.
328     The latter may be handled more efficiently by
329     .I rcollate(1).
330 greg 1.1 That said, there is no significant difference for
331 greg 1.7 simple operations on small matrices, and only
332 greg 1.1 .I rmtxop
333     and
334     .I dctimestep(1)
335 greg 1.7 accept XML files as inputs.
336     Also note that the resizing function of
337 greg 1.1 .I pcomb
338     is not supported in
339     .I rcomb,
340     and should instead be handled by
341     .I pfilt(1).
342 greg 1.13 .PP
343     Similar to
344     .I rmtxop,
345     all calculations are peformed internally using 32-bit floating-point,
346     so there is little benefit in either reading or writing 64-bit double
347     data.
348     This may be overridden at compile time using the macro
349     "-DDTrmx_native=DTdouble".
350 greg 1.4 .SH BUGS
351     The
352     .I rcomb
353     command currently ignores the "PRIMARIES" setting in input
354     headers, and does not produce any on output, even in
355     circumstances where it would make sense to.
356 greg 1.1 .SH AUTHOR
357     Greg Ward
358     .SH "SEE ALSO"
359     dctimestep(1), icalc(1), getinfo(1), pcomb(1), pfilt(1),
360 greg 1.12 pvsum(1), ra_rgbe(1), ra_xyze(1), rcalc(1),
361 greg 1.1 rcollate(1), rcontrib(1), rcrop(1), rfluxmtx(1),
362     rmtxop(1), rtpict(1), rtrace(1), vwrays(1)
