1 |
.\" RCSid "$Id: rcomb.1,v 1.2 2023/12/18 23:04:05 greg Exp $" |
2 |
.TH RCOMB 12/5/2023 RADIANCE |
3 |
.SH NAME |
4 |
rcomb - combine and convert matrices a row at a time |
5 |
.SH SYNOPSIS |
6 |
.B rcomb |
7 |
8 |
.B \-h |
9 |
10 |
.B \-w |
11 |
12 |
.B \-f[afdc] |
13 |
14 |
.B "\-f file" |
15 |
16 |
.B "\-e expr" |
17 |
18 |
.B "\-C {symbols|file}" |
19 |
20 |
.B "\-c ce .." |
21 |
22 |
.B "\-s sf .." |
23 |
24 |
.B "m1 .." |
25 |
26 |
.B "\-m mcat" |
27 |
28 |
.SH DESCRIPTION |
29 |
.I Rcomb |
30 |
combines inputs given on the command line, |
31 |
one matrix row or picture scanline at a time. |
32 |
By default, the result is a linear combination of |
33 |
the matrix elements or pixels transformed by |
34 |
.I \-c |
35 |
specifications and scaled by |
36 |
.I \-s |
37 |
coefficients, but an arbitrary mapping can be assigned with the |
38 |
.I \-e |
39 |
and |
40 |
.I \-f |
41 |
options, similar to the |
42 |
.I pcomb(1) |
43 |
and |
44 |
.I rcalc(1) |
45 |
commands. |
46 |
(The definitions in each |
47 |
.I \-f source |
48 |
file are read and compiled from the RADIANCE library where it is found.)\0 |
49 |
.PP |
50 |
If any |
51 |
.I \-c |
52 |
or |
53 |
.I \-s |
54 |
options follow the last input matrix, output results will be transformed |
55 |
and/or scaled accordingly. |
56 |
These operations are discussed in greater detail further on. |
57 |
A single concatenation matrix may be applied after element operations |
58 |
using the |
59 |
.I \-m |
60 |
option. |
61 |
Matrix concatenation will happen before or after any trailing |
62 |
operations, depending on relative command line placement. |
63 |
.PP |
64 |
Each input file must have a header containing the following metadata: |
65 |
.sp |
66 |
.nf |
67 |
NROWS={number of rows} |
68 |
NCOLS={number of columns} |
69 |
NCOMP={number of components} |
70 |
FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze|Radiance_spectra} |
71 |
.fi |
72 |
.sp |
73 |
The number of components indicates that each matrix element is actually |
74 |
composed of multiple elements, most commonly an RGB triple. |
75 |
This is essentially dividing the matrix into planes, where each component |
76 |
participates in a separate calculation. |
77 |
If an appropriate header is not present, it may be added with a call to |
78 |
.I rcollate(1). |
79 |
A matrix may be read from the standard input using a hyphen by itself ('-') |
80 |
in the appropriate place on the command line. |
81 |
Similarly, any of the inputs may be read from a command |
82 |
instead of a file by |
83 |
using quotes and a beginning exclamation point ('!'). |
84 |
.PP |
85 |
In the case of Radiance picture files, |
86 |
the number of columns is the X-dimension of the picture, and |
87 |
the number of rows is the Y-dimension. |
88 |
The picture must be in standard pixel ordering, and the zeroeth row |
89 |
is at the top with the zeroeth column on the left. |
90 |
Any exposure changes that were applied to the pictures before |
91 |
.I rcomb |
92 |
will be undone, similar to the |
93 |
.I "pcomb \-o" |
94 |
option. |
95 |
Radiance spectral pictures with more than 3 components are also supported. |
96 |
These are typically produced by |
97 |
.I rtrace(1) |
98 |
or |
99 |
.I rfluxmtx(1). |
100 |
.PP |
101 |
Before each input, the |
102 |
.I \-c |
103 |
and/or |
104 |
.I \-s |
105 |
options may be used to modify the matrix elements. |
106 |
The |
107 |
.I \-c |
108 |
option can "transform" the element values, possibly changing |
109 |
the number of components in the matrix. |
110 |
For example, a 3-component matrix can be transformed into a single-component |
111 |
matrix by using |
112 |
.I \-c |
113 |
with three coefficients. |
114 |
A four-component matrix can be turned into a two-component matrix using 8 |
115 |
coefficients, where the first four coefficients will be used to compute |
116 |
the first new component, and the second four coefficients |
117 |
yield the second new component. |
118 |
Note that the number of coefficients must be an even multiple of the number |
119 |
of original components. |
120 |
.PP |
121 |
Alternatively, a set of symbolic output components may be given to the |
122 |
.I \-c |
123 |
option, with the following definitions: |
124 |
.sp |
125 |
.nf |
126 |
R - red channel |
127 |
G - green channel |
128 |
B - blue channel |
129 |
X - CIE X channel |
130 |
Y - CIE Y channel (aka., luminance or illuminance) |
131 |
Z - CIE Z channel |
132 |
S - scotopic luminance or illuminance |
133 |
M - melanopic luminance or illuminance |
134 |
A - average component value |
135 |
.fi |
136 |
.sp |
137 |
These letters may be given in any order as a single string, and if |
138 |
.I "-c RGB" |
139 |
or |
140 |
.I "-c XYZ" |
141 |
is specified for an input picture or the |
142 |
.I "-fc" |
143 |
option is given, the output will be written as a RGBE or XYZE picture. |
144 |
Note that conversion from a float or RGBE color space applies a conversion |
145 |
of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output), |
146 |
and the reverse happens for conversion from XYZE input to RGB or RGBE output. |
147 |
Lower case versions of all these components are also supported, the only |
148 |
difference is that the aforementioned efficacy factors |
149 |
will be left out of the conversion. |
150 |
.PP |
151 |
If a matrix or picture file path is given to the |
152 |
.I \-c |
153 |
option, then the color space of that file will be used, instead. |
154 |
.PP |
155 |
The |
156 |
.I \-C |
157 |
option takes either a symbolic color space or an input file, and will be |
158 |
applied to all subsequent matrices that do not have their own associated |
159 |
.I \-c |
160 |
option. |
161 |
.PP |
162 |
Additionally, the |
163 |
.I \-s |
164 |
option applies the given scalar factor(s) to the elements of the matrix. |
165 |
If only one factor is provided, |
166 |
it will be used for all components. |
167 |
If multiple factors are given, their number must match the number of matrix |
168 |
components |
169 |
.I after |
170 |
application of any |
171 |
.I \-c |
172 |
option for this input matrix or picture, even if the |
173 |
.I \-s |
174 |
option appears first. |
175 |
.PP |
176 |
The number of components in all input |
177 |
matrices after applying any |
178 |
.I -c |
179 |
transform must agree. |
180 |
Similarly, the number of rows and columns of all results must match |
181 |
exactly. |
182 |
(The |
183 |
.I rcrop(1) |
184 |
utility may be used to trim inputs if necessary.)\0 |
185 |
.PP |
186 |
If the |
187 |
.I \-e |
188 |
or |
189 |
.I \-f |
190 |
options are used to define a "co" variable or "co(p)" function, |
191 |
this will be evaluated at each output |
192 |
component for the current element. |
193 |
The "co" variable defines identical operations for all components, |
194 |
whereas "co(p)" may specify different operations for each component. |
195 |
The element position is defined |
196 |
by the "r" and "c" variables, where |
197 |
.I r |
198 |
goes from 0 to "nrows" minus one, and |
199 |
.I c |
200 |
goes from 0 to "ncols" minus one. |
201 |
(Note that "nrows" may be zero if unspecified in inputs, and this |
202 |
is a unique capability of |
203 |
.I rcomb |
204 |
to handle these.)\0 |
205 |
Component p from input i is accessed with the "ci(i,p)" function, |
206 |
and the number of components is defined by the "ncomp" constant. |
207 |
If given as "ci(i)", the function returns the current component |
208 |
being evaluated by |
209 |
.I rcomb. |
210 |
A different component may be referenced using th second argument. |
211 |
For example, "ci(1,2)" accesses |
212 |
the second component from the first input. |
213 |
If the input is a picture, the the constants "R", "G", and "B" |
214 |
are conveniently defined as the channel numbers 1, 2, and 3, |
215 |
respectively. |
216 |
For color or spectral inputs, the function "wl(p)" gives the |
217 |
central wavelength for channel |
218 |
.I p |
219 |
in nanometers. |
220 |
For convenience and compatibility with |
221 |
.I pcomb, |
222 |
the functions "ri(i)", "gi(i)", and "bi(i)" are predefined as |
223 |
"ci(i,R)", "ci(i,G)", and "ci(i,B)", respectively. |
224 |
Accordingly, the "ro", "go", and "bo" |
225 |
variables may be used in place of "co(R)", "co(G)", and "co(B)". |
226 |
Finally, the total number of input files is set in the constant "nfiles". |
227 |
.PP |
228 |
Results are sent to the standard output. |
229 |
By default, the values will be written in the lowest precision format |
230 |
among the inputs, but the |
231 |
.I \-f[adfc] |
232 |
option may be used to explicitly output components |
233 |
as ASCII (-fa), binary doubles (-fd), floats (-ff), or common-exponent |
234 |
colors/spectra (-fc). |
235 |
In the latter case, the actual matrix dimensions are written in the resolution string rather than the header. |
236 |
Also, matrix results will be written as standard |
237 |
Radiance pictures if they have either one |
238 |
or three components. |
239 |
In the one-component case, the output is written as grayscale. |
240 |
If more than 3 components are in the final matrix and |
241 |
.I -fc |
242 |
is specified, the output will be a Radiance spectral picture. |
243 |
.PP |
244 |
The |
245 |
.I \-h |
246 |
option may be used to reduce the information header size, which |
247 |
can grow disproportionately, otherwise. |
248 |
The |
249 |
.I \-w |
250 |
option turns off warnings about divide-by-zero and other non-fatal |
251 |
calculation errors. |
252 |
.SH EXAMPLES |
253 |
To convert two hyperspectral inputs to RGB color space, |
254 |
average them together, and write them out as a RADIANCE picture: |
255 |
.IP "" .2i |
256 |
rcomb -C RGB -s .5 img1.spc -s .5 img2.spc > avg.hdr |
257 |
.PP |
258 |
Divide one set of matrix elements by the Euclidean sum of two others: |
259 |
.IP "" .2i |
260 |
rcomb -e "co=ci(1)/sqrt(ci(2)^2+ci(3)^2)" inp1.mtx |
261 |
inp2.mtx inp3.mtx > out.mtx |
262 |
.PP |
263 |
Compute the absolute and relative differences between melanopic and photopic values |
264 |
in a spectral image: |
265 |
.IP "" .2i |
266 |
rcomb -fa -C MY -e "abs(x):if(x,x,-x)" |
267 |
-e "co(p)=select(p,abs(ci(1,1)-ci(1,2)),(ci(1,1)-ci(1,2))/ci(1,2))" |
268 |
input_spec.hsr > compare.mtx |
269 |
.PP |
270 |
Concatenate a spectral flux coefficient matrix with a spectral sky |
271 |
matrix to compute a set of melanopic lux values: |
272 |
.IP "" .2i |
273 |
rcomb view_spec.mtx -m sky_spec.mtx -c M > melux.mtx |
274 |
.SH NOTES |
275 |
The |
276 |
.I rcomb |
277 |
tool was created to overcome some limitations of |
278 |
.I rmtxop |
279 |
and |
280 |
.I pcomb, |
281 |
whose capabilities somewhat overlap. |
282 |
The former loads each matrix into memory before operations, |
283 |
and element components take 8 bytes apiece, adding up quickly. |
284 |
Very large matrices therefore present a problem with that tool. |
285 |
Furthermore, |
286 |
.I rmtxop |
287 |
does not allow arbitrary expressions, limiting |
288 |
what can be accomplished easily on the command-line. |
289 |
In contrast, |
290 |
.I pcomb |
291 |
is fully programmable and operates on its input using a |
292 |
scanline window, so it can handle much larger input dimensions. |
293 |
It also handles single- and three-component float matrices on |
294 |
input and output, but unlike |
295 |
.I rmtxop, |
296 |
.I pcomb |
297 |
has not been extended to handle RADIANCE hyperspectral images |
298 |
or more general matrix data. |
299 |
.PP |
300 |
The |
301 |
.I rcomb |
302 |
tool is a compromise that exceeds the capabilities of either of |
303 |
its predecessors in certain circumstances. |
304 |
In particular, very large matrices may be combined using |
305 |
arbitrary, user-defined operations, and the convenient |
306 |
color conversions of |
307 |
.I rmtxop |
308 |
are supported for both input and output. |
309 |
Finally, a single matrix may be concatenated after operations, |
310 |
permitting a flux transfer matrix with millions of rows to |
311 |
pass through. |
312 |
Generally speaking, |
313 |
.I rcomb |
314 |
should be preferred over |
315 |
.I rmtxop |
316 |
for any operations in can handle, which is everything except |
317 |
multiple matrix concatenations and transpose |
318 |
operations, which are handled more efficiently by |
319 |
.I rcollate(1) |
320 |
in any case. |
321 |
That said, there is no significant difference for |
322 |
simple operations on smallish matrices, and note that only |
323 |
.I rmtxop |
324 |
and |
325 |
.I dctimestep(1) |
326 |
currently accept XML files as inputs. |
327 |
Also, the resizing function of |
328 |
.I pcomb |
329 |
is not supported in |
330 |
.I rcomb, |
331 |
and should instead be handled by |
332 |
.I pfilt(1). |
333 |
.SH AUTHOR |
334 |
Greg Ward |
335 |
.SH "SEE ALSO" |
336 |
dctimestep(1), icalc(1), getinfo(1), pcomb(1), pfilt(1), |
337 |
ra_xyze(1), rcalc(1), |
338 |
rcollate(1), rcontrib(1), rcrop(1), rfluxmtx(1), |
339 |
rmtxop(1), rtpict(1), rtrace(1), vwrays(1) |
