root/radiance/ray/doc/man/man1/rcomb.1
Revision: 1.10
Committed: Fri Jun 28 21:04:49 2024 UTC (11 months, 3 weeks ago) by greg
Changes since 1.9: +5 -5 lines
docs(rcomb): Replaced .spc suffix with proper .hsr one
1 .\" RCSid "$Id: rcomb.1,v 1.9 2024/05/22 16:49:19 greg Exp $"
2 .TH RCOMB 12/5/2023 RADIANCE
3 .SH NAME
4 rcomb - combine and convert matrices a row at a time
5 .SH SYNOPSIS
6 .B rcomb
7 [
8 .B \-h
9 ][
10 .B \-w
11 ][
12 .B \-f[afdc]
13 ][
14 .B "\-n nproc"
15 ][
16 .B "\-f file"
17 ][
18 .B "\-e expr"
19 ][
20 .B "\-C {symbols|file}"
21 ][
22 .B "\-c ce .."
23 ][
24 .B "\-s sf .."
25 ]
26 .B "m1 .."
27 [
28 .B "\-m mcat"
29 ]
30 .SH DESCRIPTION
31 .I Rcomb
32 combines inputs given on the command line,
33 one matrix row or picture scanline at a time.
34 By default, the result is a linear combination of
35 the matrix elements or pixels transformed by
36 .I \-c
37 specifications and scaled by
38 .I \-s
39 coefficients, but an arbitrary mapping can be assigned with the
40 .I \-e
41 and
42 .I \-f
43 options, similar to the
44 .I pcomb(1)
45 and
46 .I rcalc(1)
47 commands.
48 (The definitions in each
49 .I \-f source
50 file are read and compiled from the RADIANCE library where it is found.)\0
51 .PP
52 If any
53 .I \-c
54 or
55 .I \-s
56 options follow the last input matrix, output results will be transformed
57 and/or scaled accordingly.
58 These operations are discussed in greater detail below.
59 A single concatenation matrix may be applied after element operations
60 using the
61 .I \-m
62 option.
63 Matrix concatenation will happen before or after any trailing
64 operations, depending on relative command line placement.
65 .PP
66 Each input file must have a header containing the following metadata:
67 .sp
68 .nf
69 NROWS={number of rows}
70 NCOLS={number of columns}
71 NCOMP={number of components}
72 FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze|Radiance_spectra}
73 .fi
74 .sp
75 The number of components indicates that each matrix element is actually
76 composed of multiple channels, most commonly an RGB triple.
77 This is essentially dividing the matrix into planes, where each component
78 participates in a separate calculation.
79 If an appropriate header is not present, it may be added with a call to
80 .I rcollate(1).
81 A matrix may be read from the standard input using a hyphen by itself ('-')
82 in the appropriate place on the command line.
83 Similarly, any of the inputs may be read from a command
84 instead of a file by
85 using quotes and a beginning exclamation point ('!').
86 .PP
87 In the case of Radiance picture files,
88 the number of columns is the X-dimension of the picture, and
89 the number of rows is the Y-dimension.
90 The picture must be in standard pixel ordering, and the zeroeth row
91 is at the top with the zeroeth column on the left.
92 Any exposure changes that were applied to the pictures before
93 .I rcomb
94 will be undone, similar to the
95 .I "pcomb \-o"
96 option.
97 Radiance spectral pictures with more than 3 components are also supported.
98 These are typically produced by
99 .I rtpict(1)
100 or
101 .I rfluxmtx(1).
102 .PP
103 Before each input, the
104 .I \-c
105 and/or
106 .I \-s
107 options may be used to modify the matrix elements.
108 The
109 .I \-c
110 option can "transform" the element values, possibly changing
111 the number of components in the matrix.
112 For example, a 3-component matrix can be transformed into a single-component
113 matrix by using
114 .I \-c
115 with three coefficients.
116 A four-component matrix can be turned into a two-component matrix using 8
117 coefficients, where the first four coefficients will be used to compute
118 the first new component, and the second four coefficients
119 yield the second new component.
120 Note that the number of coefficients must be an even multiple of the number
121 of original components.
122 .PP
123 Alternatively, a set of symbolic output components may be given to the
124 .I \-c
125 option, with the following definitions:
126 .sp
127 .nf
128 R - red channel
129 G - green channel
130 B - blue channel
131 X - CIE X channel
132 Y - CIE Y channel (aka., luminance or illuminance)
133 Z - CIE Z channel
134 S - scotopic luminance or illuminance
135 M - melanopic luminance or illuminance
136 A - average component value
137 .fi
138 .sp
139 These letters may be given in any order as a single string, and if
140 .I "-c RGB"
141 or
142 .I "-c XYZ"
143 is specified for an input picture or the
144 .I "-fc"
145 option is given, the output will be written as a RGBE or XYZE picture.
146 Note that conversion from a float or RGBE color space applies an efficacy factor
147 of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output),
148 and the inverse happens for conversion from XYZE input to RGB or RGBE output.
149 Lower case versions of all these components are also supported, the only
150 difference being that the efficacy factors are ignored.
151 .PP
152 If a matrix or picture file path is given to the
153 .I \-c
154 option, then the color space of that file will be used, instead.
155 .PP
156 The
157 .I \-C
158 option takes either a symbolic color space or an input file, and will be
159 applied to all subsequent matrices that do not have their own associated
160 .I \-c
161 option.
162 .PP
163 Additionally, the
164 .I \-s
165 option applies the given scalar factor(s) to the elements of the matrix.
166 If only one factor is provided,
167 it will be used for all components.
168 If multiple factors are given, their number must match the number of matrix
169 components
170 .I after
171 application of any
172 .I \-c
173 option for this input matrix or picture, even if the
174 .I \-s
175 option appears first.
176 .PP
177 The number of components in all input
178 matrices after applying any
179 .I -c
180 transform must agree.
181 Similarly, the number of rows and columns of all results must match
182 exactly.
183 (The
184 .I rcrop(1)
185 utility may be used to trim inputs if necessary.)\0
186 .PP
187 If the
188 .I \-e
189 or
190 .I \-f
191 options are used to define a "co" variable or "co(p)" function,
192 which will be evaluated for each output
193 component from the current element.
194 The "co" variable defines identical operations for all components,
195 whereas "co(p)" may specify different operations for each component.
196 The element position is defined
197 by the "r" and "c" variables, where
198 .I r
199 goes from 0 to "nrows" minus one, and
200 .I c
201 goes from 0 to "ncols" minus one.
202 (Note that "nrows" may be zero if unspecified in inputs, and this
203 is a unique capability of
204 .I rcomb
205 to handle these.)\0
206 Component p from input i is accessed with the "ci(i,p)" function,
207 and the number of components is defined by the "ncomp" constant.
208 If given as "ci(i)", the function returns the current component
209 being evaluated by
210 .I rcomb.
211 A different component may be referenced using the second argument.
212 For example, "ci(1,2)" accesses
213 the second component from the first input.
214 If the input is a picture, the the constants "R", "G", and "B"
215 are conveniently defined as the channel numbers 1, 2, and 3,
216 respectively.
217 For color or spectral inputs, the function "wl(p)" gives the
218 central wavelength for channel
219 .I p
220 in nanometers.
221 For convenience and compatibility with
222 .I pcomb,
223 the functions "ri(i)", "gi(i)", and "bi(i)" are predefined as
224 "ci(i,R)", "ci(i,G)", and "ci(i,B)", respectively.
225 Accordingly, the "ro", "go", and "bo"
226 variables may be used in place of "co(R)", "co(G)", and "co(B)",
227 but all three must be defined for this substitution to take place.
228 Finally, the total number of input files is set in the constant "nfiles".
229 .PP
230 Results are sent to the standard output.
231 By default, the values will be written in the lowest precision format
232 among the inputs, but the
233 .I \-f[adfc]
234 option may be used to explicitly output components
235 as ASCII (-fa), binary doubles (-fd), floats (-ff), or common-exponent
236 colors/spectra (-fc).
237 In the latter case, the actual matrix dimensions are written in the resolution string rather than the header.
238 Also, matrix results will be written as standard
239 Radiance pictures if they have either one
240 or three components.
241 In the one-component case, the output is written as grayscale.
242 If more than 3 components are in the final matrix and
243 .I -fc
244 is specified, the output will be a Radiance spectral picture.
245 .PP
246 The
247 .I \-h
248 option may be used to reduce the information header size, which
249 can grow disproportionately, otherwise.
250 The
251 .I \-w
252 option turns off warnings about divide-by-zero and other non-fatal
253 calculation errors.
254 .PP
255 The
256 .I \-n
257 option specifies how many execution processes to employ,
258 which may improve performance on multi-core architectures,
259 especially for matrix multiplication
260 and complex operations on long input rows.
261 .SH EXAMPLES
262 To convert two hyperspectral pictures to RGB color space,
263 average them together, and write them out as a RADIANCE picture:
264 .IP "" .2i
265 rcomb -C RGB -s .5 img1.hsr -s .5 -fc img2.hsr > avg.hdr
266 .PP
267 Divide one set of matrix elements by the Euclidean sum of two others:
268 .IP "" .2i
269 rcomb -e "co=ci(1)/sqrt(ci(2)^2+ci(3)^2)" inp1.mtx
270 inp2.mtx inp3.mtx > out.mtx
271 .PP
272 Compute the absolute and relative differences between melanopic and photopic values
273 in a spectral image:
274 .IP "" .2i
275 rcomb -C MY -e "abs(x):if(x,x,-x)"
276 -e "co(p)=select(p,abs(ci(1,1)-ci(1,2)),(ci(1,1)-ci(1,2))/ci(1,2))"
277 input_spec.hsr -fa > compare.mtx
278 .PP
279 Concatenate a spectral flux coefficient matrix with a spectral sky
280 matrix to compute a set of melanopic lux values:
281 .IP "" .2i
282 rcomb view_spec.mtx -m sky_spec.mtx -c M > melux.mtx
283 .SH NOTES
284 The
285 .I rcomb
286 tool was created to overcome some limitations of
287 .I rmtxop
288 and
289 .I pcomb,
290 whose capabilities somewhat overlap.
291 The former loads each matrix into memory before operations,
292 and element components are stored as double-precision.
293 Very large matrices therefore present a problem with that tool.
294 Furthermore,
295 .I rmtxop
296 does not allow arbitrary expressions, limiting
297 what can be accomplished easily on the command-line.
298 In contrast,
299 .I pcomb
300 is fully programmable and operates on its input using a
301 scanline window, so it can handle much larger input dimensions.
302 It also handles single- and three-component float matrices on
303 input and output, but unlike
304 .I rmtxop,
305 .I pcomb
306 has not been extended to handle RADIANCE hyperspectral images
307 or more general matrix data.
308 .PP
309 The
310 .I rcomb
311 tool is a compromise that exceeds the capabilities of either of
312 its predecessors in certain circumstances.
313 In particular, very large matrices may be combined using
314 arbitrary, user-defined operations, and the convenient
315 color conversions of
316 .I rmtxop
317 are supported for both input and output.
318 Finally, a single matrix may be concatenated after operations,
319 permitting a flux transfer matrix with millions of rows to
320 pass through.
321 Generally speaking,
322 .I rcomb
323 should be preferred over
324 .I rmtxop
325 for any operations it can handle, which is everything except
326 multiple matrix concatenations and transpose
327 operations.
328 The latter may be handled more efficiently by
329 .I rcollate(1).
330 That said, there is no significant difference for
331 simple operations on small matrices, and only
332 .I rmtxop
333 and
334 .I dctimestep(1)
335 accept XML files as inputs.
336 Also note that the resizing function of
337 .I pcomb
338 is not supported in
339 .I rcomb,
340 and should instead be handled by
341 .I pfilt(1).
342 .SH BUGS
343 The
344 .I rcomb
345 command currently ignores the "PRIMARIES" setting in input
346 headers, and does not produce any on output, even in
347 circumstances where it would make sense to.
348 .SH AUTHOR
349 Greg Ward
350 .SH "SEE ALSO"
351 dctimestep(1), icalc(1), getinfo(1), pcomb(1), pfilt(1),
352 ra_xyze(1), rcalc(1),
353 rcollate(1), rcontrib(1), rcrop(1), rfluxmtx(1),
354 rmtxop(1), rtpict(1), rtrace(1), vwrays(1)
