--- ray/doc/man/man1/rcomb.1 2024/02/10 19:32:32 1.6 +++ ray/doc/man/man1/rcomb.1 2025/06/19 22:36:53 1.14 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcomb.1,v 1.6 2024/02/10 19:32:32 greg Exp $" +.\" RCSid "$Id: rcomb.1,v 1.14 2025/06/19 22:36:53 greg Exp $" .TH RCOMB 12/5/2023 RADIANCE .SH NAME rcomb - combine and convert matrices a row at a time @@ -11,6 +11,8 @@ rcomb - combine and convert matrices a row at a time ][ .B \-f[afdc] ][ +.B "\-n nproc" +][ .B "\-f file" ][ .B "\-e expr" @@ -23,7 +25,7 @@ rcomb - combine and convert matrices a row at a time ] .B "m1 .." [ -.B "\-m mcat" +.B "\-m[t] mcat" ] .SH DESCRIPTION .I Rcomb @@ -53,11 +55,14 @@ or .I \-s options follow the last input matrix, output results will be transformed and/or scaled accordingly. -These operations are discussed in greater detail further on. +These operations are discussed in greater detail below. A single concatenation matrix may be applied after element operations using the .I \-m option. +If the option is given as +.I \-mt +then the concatenation matrix will be transposed before it is applied. Matrix concatenation will happen before or after any trailing operations, depending on relative command line placement. .PP @@ -71,7 +76,7 @@ FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_ .fi .sp The number of components indicates that each matrix element is actually -composed of multiple elements, most commonly an RGB triple. +composed of multiple channels, most commonly an RGB triple. This is essentially dividing the matrix into planes, where each component participates in a separate calculation. If an appropriate header is not present, it may be added with a call to @@ -141,12 +146,11 @@ or is specified for an input picture or the .I "-fc" option is given, the output will be written as a RGBE or XYZE picture. -Note that conversion from a float or RGBE color space applies a conversion +Note that conversion from a float or RGBE color space applies an efficacy factor of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output), -and the reverse happens for conversion from XYZE input to RGB or RGBE output. +and the inverse happens for conversion from XYZE input to RGB or RGBE output. Lower case versions of all these components are also supported, the only -difference is that the aforementioned efficacy factors -will be left out of the conversion. +difference being that the efficacy factors are ignored. .PP If a matrix or picture file path is given to the .I \-c @@ -188,8 +192,8 @@ If the or .I \-f options are used to define a "co" variable or "co(p)" function, -this will be evaluated at each output -component for the current element. +which will be evaluated for each output +component from the current element. The "co" variable defines identical operations for all components, whereas "co(p)" may specify different operations for each component. The element position is defined @@ -250,11 +254,18 @@ The .I \-w option turns off warnings about divide-by-zero and other non-fatal calculation errors. +.PP +The +.I \-n +option specifies how many execution processes to employ, +which may improve performance on multi-core architectures, +especially for matrix multiplication +and complex operations on long input rows. .SH EXAMPLES -To convert two hyperspectral inputs to RGB color space, +To convert two hyperspectral pictures to RGB color space, average them together, and write them out as a RADIANCE picture: .IP "" .2i -rcomb -C RGB -s .5 img1.spc -s .5 img2.spc > avg.hdr +rcomb -C RGB -s .5 img1.hsr -s .5 -fc img2.hsr > avg.hdr .PP Divide one set of matrix elements by the Euclidean sum of two others: .IP "" .2i @@ -264,9 +275,9 @@ inp2.mtx inp3.mtx > out.mtx Compute the absolute and relative differences between melanopic and photopic values in a spectral image: .IP "" .2i -rcomb -fa -C MY -e "abs(x):if(x,x,-x)" +rcomb -C MY -e "abs(x):if(x,x,-x)" -e "co(p)=select(p,abs(ci(1,1)-ci(1,2)),(ci(1,1)-ci(1,2))/ci(1,2))" -input_spec.hsr > compare.mtx +input_spec.hsr -fa > compare.mtx .PP Concatenate a spectral flux coefficient matrix with a spectral sky matrix to compute a set of melanopic lux values: @@ -281,7 +292,7 @@ and .I pcomb, whose capabilities somewhat overlap. The former loads each matrix into memory before operations, -and element components take 8 bytes apiece, adding up quickly. +and element components are stored as double-precision. Very large matrices therefore present a problem with that tool. Furthermore, .I rmtxop @@ -314,23 +325,31 @@ Generally speaking, .I rcomb should be preferred over .I rmtxop -for any operations in can handle, which is everything except +for any operations it can handle, which is everything except multiple matrix concatenations and transpose -operations, which are handled more efficiently by -.I rcollate(1) -in any case. +operations. +The latter may be handled more efficiently by +.I rcollate(1). That said, there is no significant difference for -simple operations on smallish matrices, and note that only +simple operations on small matrices, and only .I rmtxop and .I dctimestep(1) -currently accept XML files as inputs. -Also, the resizing function of +accept XML files as inputs. +Also note that the resizing function of .I pcomb is not supported in .I rcomb, and should instead be handled by .I pfilt(1). +.PP +Similar to +.I rmtxop, +all calculations are peformed internally using 32-bit floating-point, +so there is little benefit in either reading or writing 64-bit double +data. +This may be overridden at compile time using the macro +"-DDTrmx_native=DTdouble". .SH BUGS The .I rcomb @@ -341,6 +360,6 @@ circumstances where it would make sense to. Greg Ward .SH "SEE ALSO" dctimestep(1), icalc(1), getinfo(1), pcomb(1), pfilt(1), -ra_xyze(1), rcalc(1), +pvsum(1), ra_rgbe(1), ra_xyze(1), rcalc(1), rcollate(1), rcontrib(1), rcrop(1), rfluxmtx(1), rmtxop(1), rtpict(1), rtrace(1), vwrays(1)
