--- ray/doc/man/man1/rcomb.1 2024/05/20 23:21:28 1.8 +++ ray/doc/man/man1/rcomb.1 2025/03/27 01:26:55 1.12 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcomb.1,v 1.8 2024/05/20 23:21:28 greg Exp $" +.\" RCSid "$Id: rcomb.1,v 1.12 2025/03/27 01:26:55 greg Exp $" .TH RCOMB 12/5/2023 RADIANCE .SH NAME rcomb - combine and convert matrices a row at a time @@ -143,12 +143,11 @@ or is specified for an input picture or the .I "-fc" option is given, the output will be written as a RGBE or XYZE picture. -Note that conversion from a float or RGBE color space applies a conversion +Note that conversion from a float or RGBE color space applies an efficacy factor of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output), -and the reverse happens for conversion from XYZE input to RGB or RGBE output. +and the inverse happens for conversion from XYZE input to RGB or RGBE output. Lower case versions of all these components are also supported, the only -difference is that the aforementioned efficacy factors -will be left out of the conversion. +difference being that the efficacy factors are ignored. .PP If a matrix or picture file path is given to the .I \-c @@ -260,10 +259,10 @@ which may improve performance on multi-core architectu especially for matrix multiplication and complex operations on long input rows. .SH EXAMPLES -To convert two hyperspectral inputs to RGB color space, +To convert two hyperspectral pictures to RGB color space, average them together, and write them out as a RADIANCE picture: .IP "" .2i -rcomb -C RGB -s .5 img1.spc -s .5 img2.spc > avg.hdr +rcomb -C RGB -s .5 img1.hsr -s .5 -fc img2.hsr > avg.hdr .PP Divide one set of matrix elements by the Euclidean sum of two others: .IP "" .2i @@ -273,9 +272,9 @@ inp2.mtx inp3.mtx > out.mtx Compute the absolute and relative differences between melanopic and photopic values in a spectral image: .IP "" .2i -rcomb -fa -C MY -e "abs(x):if(x,x,-x)" +rcomb -C MY -e "abs(x):if(x,x,-x)" -e "co(p)=select(p,abs(ci(1,1)-ci(1,2)),(ci(1,1)-ci(1,2))/ci(1,2))" -input_spec.hsr > compare.mtx +input_spec.hsr -fa > compare.mtx .PP Concatenate a spectral flux coefficient matrix with a spectral sky matrix to compute a set of melanopic lux values: @@ -350,6 +349,6 @@ circumstances where it would make sense to. Greg Ward .SH "SEE ALSO" dctimestep(1), icalc(1), getinfo(1), pcomb(1), pfilt(1), -ra_xyze(1), rcalc(1), +pvsum(1), ra_rgbe(1), ra_xyze(1), rcalc(1), rcollate(1), rcontrib(1), rcrop(1), rfluxmtx(1), rmtxop(1), rtpict(1), rtrace(1), vwrays(1)
