root/radiance/ray/doc/man/man1/rcomb.1
Revision: 1.14
Committed: Thu Jun 19 22:36:53 2025 UTC (2 days, 11 hours ago) by greg
Changes since 1.13: +5 -2 lines
feat(rcomb): Added -mt option to transpose concatenation matrix after load
1 .\" RCSid "$Id: rcomb.1,v 1.13 2025/04/04 18:06:48 greg Exp $"
2 .TH RCOMB 12/5/2023 RADIANCE
3 .SH NAME
4 rcomb - combine and convert matrices a row at a time
5 .SH SYNOPSIS
6 .B rcomb
7 [
8 .B \-h
9 ][
10 .B \-w
11 ][
12 .B \-f[afdc]
13 ][
14 .B "\-n nproc"
15 ][
16 .B "\-f file"
17 ][
18 .B "\-e expr"
19 ][
20 .B "\-C {symbols|file}"
21 ][
22 .B "\-c ce .."
23 ][
24 .B "\-s sf .."
25 ]
26 .B "m1 .."
27 [
28 .B "\-m[t] mcat"
29 ]
30 .SH DESCRIPTION
31 .I Rcomb
32 combines inputs given on the command line,
33 one matrix row or picture scanline at a time.
34 By default, the result is a linear combination of
35 the matrix elements or pixels transformed by
36 .I \-c
37 specifications and scaled by
38 .I \-s
39 coefficients, but an arbitrary mapping can be assigned with the
40 .I \-e
41 and
42 .I \-f
43 options, similar to the
44 .I pcomb(1)
45 and
46 .I rcalc(1)
47 commands.
48 (The definitions in each
49 .I \-f source
50 file are read and compiled from the RADIANCE library where it is found.)\0
51 .PP
52 If any
53 .I \-c
54 or
55 .I \-s
56 options follow the last input matrix, output results will be transformed
57 and/or scaled accordingly.
58 These operations are discussed in greater detail below.
59 A single concatenation matrix may be applied after element operations
60 using the
61 .I \-m
62 option.
63 If the option is given as
64 .I \-mt
65 then the concatenation matrix will be transposed before it is applied.
66 Matrix concatenation will happen before or after any trailing
67 operations, depending on relative command line placement.
68 .PP
69 Each input file must have a header containing the following metadata:
70 .sp
71 .nf
72 NROWS={number of rows}
73 NCOLS={number of columns}
74 NCOMP={number of components}
75 FORMAT={ascii|float|double|32-bit_rle_rgbe|32-bit_rle_xyze|Radiance_spectra}
76 .fi
77 .sp
78 The number of components indicates that each matrix element is actually
79 composed of multiple channels, most commonly an RGB triple.
80 This is essentially dividing the matrix into planes, where each component
81 participates in a separate calculation.
82 If an appropriate header is not present, it may be added with a call to
83 .I rcollate(1).
84 A matrix may be read from the standard input using a hyphen by itself ('-')
85 in the appropriate place on the command line.
86 Similarly, any of the inputs may be read from a command
87 instead of a file by
88 using quotes and a beginning exclamation point ('!').
89 .PP
90 In the case of Radiance picture files,
91 the number of columns is the X-dimension of the picture, and
92 the number of rows is the Y-dimension.
93 The picture must be in standard pixel ordering, and the zeroeth row
94 is at the top with the zeroeth column on the left.
95 Any exposure changes that were applied to the pictures before
96 .I rcomb
97 will be undone, similar to the
98 .I "pcomb \-o"
99 option.
100 Radiance spectral pictures with more than 3 components are also supported.
101 These are typically produced by
102 .I rtpict(1)
103 or
104 .I rfluxmtx(1).
105 .PP
106 Before each input, the
107 .I \-c
108 and/or
109 .I \-s
110 options may be used to modify the matrix elements.
111 The
112 .I \-c
113 option can "transform" the element values, possibly changing
114 the number of components in the matrix.
115 For example, a 3-component matrix can be transformed into a single-component
116 matrix by using
117 .I \-c
118 with three coefficients.
119 A four-component matrix can be turned into a two-component matrix using 8
120 coefficients, where the first four coefficients will be used to compute
121 the first new component, and the second four coefficients
122 yield the second new component.
123 Note that the number of coefficients must be an even multiple of the number
124 of original components.
125 .PP
126 Alternatively, a set of symbolic output components may be given to the
127 .I \-c
128 option, with the following definitions:
129 .sp
130 .nf
131 R - red channel
132 G - green channel
133 B - blue channel
134 X - CIE X channel
135 Y - CIE Y channel (aka., luminance or illuminance)
136 Z - CIE Z channel
137 S - scotopic luminance or illuminance
138 M - melanopic luminance or illuminance
139 A - average component value
140 .fi
141 .sp
142 These letters may be given in any order as a single string, and if
143 .I "-c RGB"
144 or
145 .I "-c XYZ"
146 is specified for an input picture or the
147 .I "-fc"
148 option is given, the output will be written as a RGBE or XYZE picture.
149 Note that conversion from a float or RGBE color space applies an efficacy factor
150 of 179 lumens/watt (for CIE or melanopic output) or 412 (for scotopic output),
151 and the inverse happens for conversion from XYZE input to RGB or RGBE output.
152 Lower case versions of all these components are also supported, the only
153 difference being that the efficacy factors are ignored.
154 .PP
155 If a matrix or picture file path is given to the
156 .I \-c
157 option, then the color space of that file will be used, instead.
158 .PP
159 The
160 .I \-C
161 option takes either a symbolic color space or an input file, and will be
162 applied to all subsequent matrices that do not have their own associated
163 .I \-c
164 option.
165 .PP
166 Additionally, the
167 .I \-s
168 option applies the given scalar factor(s) to the elements of the matrix.
169 If only one factor is provided,
170 it will be used for all components.
171 If multiple factors are given, their number must match the number of matrix
172 components
173 .I after
174 application of any
175 .I \-c
176 option for this input matrix or picture, even if the
177 .I \-s
178 option appears first.
179 .PP
180 The number of components in all input
181 matrices after applying any
182 .I -c
183 transform must agree.
184 Similarly, the number of rows and columns of all results must match
185 exactly.
186 (The
187 .I rcrop(1)
188 utility may be used to trim inputs if necessary.)\0
189 .PP
190 If the
191 .I \-e
192 or
193 .I \-f
194 options are used to define a "co" variable or "co(p)" function,
195 which will be evaluated for each output
196 component from the current element.
197 The "co" variable defines identical operations for all components,
198 whereas "co(p)" may specify different operations for each component.
199 The element position is defined
200 by the "r" and "c" variables, where
201 .I r
202 goes from 0 to "nrows" minus one, and
203 .I c
204 goes from 0 to "ncols" minus one.
205 (Note that "nrows" may be zero if unspecified in inputs, and this
206 is a unique capability of
207 .I rcomb
208 to handle these.)\0
209 Component p from input i is accessed with the "ci(i,p)" function,
210 and the number of components is defined by the "ncomp" constant.
211 If given as "ci(i)", the function returns the current component
212 being evaluated by
213 .I rcomb.
214 A different component may be referenced using the second argument.
215 For example, "ci(1,2)" accesses
216 the second component from the first input.
217 If the input is a picture, the the constants "R", "G", and "B"
218 are conveniently defined as the channel numbers 1, 2, and 3,
219 respectively.
220 For color or spectral inputs, the function "wl(p)" gives the
221 central wavelength for channel
222 .I p
223 in nanometers.
224 For convenience and compatibility with
225 .I pcomb,
226 the functions "ri(i)", "gi(i)", and "bi(i)" are predefined as
227 "ci(i,R)", "ci(i,G)", and "ci(i,B)", respectively.
228 Accordingly, the "ro", "go", and "bo"
229 variables may be used in place of "co(R)", "co(G)", and "co(B)",
230 but all three must be defined for this substitution to take place.
231 Finally, the total number of input files is set in the constant "nfiles".
232 .PP
233 Results are sent to the standard output.
234 By default, the values will be written in the lowest precision format
235 among the inputs, but the
236 .I \-f[adfc]
237 option may be used to explicitly output components
238 as ASCII (-fa), binary doubles (-fd), floats (-ff), or common-exponent
239 colors/spectra (-fc).
240 In the latter case, the actual matrix dimensions are written in the resolution string rather than the header.
241 Also, matrix results will be written as standard
242 Radiance pictures if they have either one
243 or three components.
244 In the one-component case, the output is written as grayscale.
245 If more than 3 components are in the final matrix and
246 .I -fc
247 is specified, the output will be a Radiance spectral picture.
248 .PP
249 The
250 .I \-h
251 option may be used to reduce the information header size, which
252 can grow disproportionately, otherwise.
253 The
254 .I \-w
255 option turns off warnings about divide-by-zero and other non-fatal
256 calculation errors.
257 .PP
258 The
259 .I \-n
260 option specifies how many execution processes to employ,
261 which may improve performance on multi-core architectures,
262 especially for matrix multiplication
263 and complex operations on long input rows.
264 .SH EXAMPLES
265 To convert two hyperspectral pictures to RGB color space,
266 average them together, and write them out as a RADIANCE picture:
267 .IP "" .2i
268 rcomb -C RGB -s .5 img1.hsr -s .5 -fc img2.hsr > avg.hdr
269 .PP
270 Divide one set of matrix elements by the Euclidean sum of two others:
271 .IP "" .2i
272 rcomb -e "co=ci(1)/sqrt(ci(2)^2+ci(3)^2)" inp1.mtx
273 inp2.mtx inp3.mtx > out.mtx
274 .PP
275 Compute the absolute and relative differences between melanopic and photopic values
276 in a spectral image:
277 .IP "" .2i
278 rcomb -C MY -e "abs(x):if(x,x,-x)"
279 -e "co(p)=select(p,abs(ci(1,1)-ci(1,2)),(ci(1,1)-ci(1,2))/ci(1,2))"
280 input_spec.hsr -fa > compare.mtx
281 .PP
282 Concatenate a spectral flux coefficient matrix with a spectral sky
283 matrix to compute a set of melanopic lux values:
284 .IP "" .2i
285 rcomb view_spec.mtx -m sky_spec.mtx -c M > melux.mtx
286 .SH NOTES
287 The
288 .I rcomb
289 tool was created to overcome some limitations of
290 .I rmtxop
291 and
292 .I pcomb,
293 whose capabilities somewhat overlap.
294 The former loads each matrix into memory before operations,
295 and element components are stored as double-precision.
296 Very large matrices therefore present a problem with that tool.
297 Furthermore,
298 .I rmtxop
299 does not allow arbitrary expressions, limiting
300 what can be accomplished easily on the command-line.
301 In contrast,
302 .I pcomb
303 is fully programmable and operates on its input using a
304 scanline window, so it can handle much larger input dimensions.
305 It also handles single- and three-component float matrices on
306 input and output, but unlike
307 .I rmtxop,
308 .I pcomb
309 has not been extended to handle RADIANCE hyperspectral images
310 or more general matrix data.
311 .PP
312 The
313 .I rcomb
314 tool is a compromise that exceeds the capabilities of either of
315 its predecessors in certain circumstances.
316 In particular, very large matrices may be combined using
317 arbitrary, user-defined operations, and the convenient
318 color conversions of
319 .I rmtxop
320 are supported for both input and output.
321 Finally, a single matrix may be concatenated after operations,
322 permitting a flux transfer matrix with millions of rows to
323 pass through.
324 Generally speaking,
325 .I rcomb
326 should be preferred over
327 .I rmtxop
328 for any operations it can handle, which is everything except
329 multiple matrix concatenations and transpose
330 operations.
331 The latter may be handled more efficiently by
332 .I rcollate(1).
333 That said, there is no significant difference for
334 simple operations on small matrices, and only
335 .I rmtxop
336 and
337 .I dctimestep(1)
338 accept XML files as inputs.
339 Also note that the resizing function of
340 .I pcomb
341 is not supported in
342 .I rcomb,
343 and should instead be handled by
344 .I pfilt(1).
345 .PP
346 Similar to
347 .I rmtxop,
348 all calculations are peformed internally using 32-bit floating-point,
349 so there is little benefit in either reading or writing 64-bit double
350 data.
351 This may be overridden at compile time using the macro
352 "-DDTrmx_native=DTdouble".
353 .SH BUGS
354 The
355 .I rcomb
356 command currently ignores the "PRIMARIES" setting in input
357 headers, and does not produce any on output, even in
358 circumstances where it would make sense to.
359 .SH AUTHOR
360 Greg Ward
361 .SH "SEE ALSO"
362 dctimestep(1), icalc(1), getinfo(1), pcomb(1), pfilt(1),
363 pvsum(1), ra_rgbe(1), ra_xyze(1), rcalc(1),
364 rcollate(1), rcontrib(1), rcrop(1), rfluxmtx(1),
365 rmtxop(1), rtpict(1), rtrace(1), vwrays(1)
