root/Development/ray/doc/man/man1/rcomb.1
Thu Oct 23 23:34:59 2025 UTC (2 months ago) by greg
Changes since 1.14: +2 -2 lines
Diff to previous 1.14 , to selected 1.6
docs: Added rxfluxmtx man page and updated others accordingly
Thu Jun 19 22:36:53 2025 UTC (6 months, 1 week ago) by greg
CVS Tags: rad6R0
Changes since 1.13: +5 -2 lines
Diff to previous 1.13 , to selected 1.6
feat(rcomb): Added -mt option to transpose concatenation matrix after load
Fri Apr 4 18:06:48 2025 UTC (8 months, 3 weeks ago) by greg
Changes since 1.12: +9 -1 lines
Diff to previous 1.12 , to selected 1.6
Thu Mar 27 01:26:55 2025 UTC (9 months ago) by greg
Diff to previous 1.11 , to selected 1.6
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
Tue Oct 1 01:16:26 2024 UTC (14 months, 3 weeks ago) by greg
Diff to previous 1.10 , to selected 1.6
feat(ra_xyze): added accurate conversion of hyperspectral pictures on input
Fri Jun 28 21:04:49 2024 UTC (17 months, 4 weeks ago) by greg
Changes since 1.9: +5 -5 lines
Diff to previous 1.9 , to selected 1.6
docs(rcomb): Replaced .spc suffix with proper .hsr one
Wed May 22 16:49:19 2024 UTC (19 months ago) by greg
Changes since 1.8: +4 -5 lines
Diff to previous 1.8 , to selected 1.6
docs(rcomb): Wording fixes
Mon May 20 23:21:28 2024 UTC (19 months, 1 week ago) by greg
Changes since 1.7: +10 -1 lines
Diff to previous 1.7 , to selected 1.6
Tue May 7 17:15:31 2024 UTC (19 months, 2 weeks ago) by greg
Changes since 1.6: +13 -13 lines
Diff to previous 1.6
docs: Minor wording fixes
Revision 1.6 - (view) (download) (annotate) - [selected]
Sat Feb 10 19:32:32 2024 UTC (22 months, 2 weeks ago) by greg
Diff to previous 1.5
docs: typo fix plus clarification
Wed Jan 17 21:50:15 2024 UTC (23 months, 1 week ago) by greg
Diff to previous 1.4 , to selected 1.6
docs: changed mention to rtpict rather than rtrace
Mon Dec 25 16:29:56 2023 UTC (2 years ago) by greg
Changes since 1.3: +7 -1 lines
Diff to previous 1.3 , to selected 1.6
docs(rcomb,rmtxop): Added BUGS section
Tue Dec 19 00:39:03 2023 UTC (2 years ago) by greg
Changes since 1.2: +4 -1 lines
Diff to previous 1.2 , to selected 1.6
feat(rmtxop,rcomb): Added lower-case versions of component outputs w/o efficacy conversions
Mon Dec 18 23:04:05 2023 UTC (2 years ago) by greg
Changes since 1.1: +5 -1 lines
Diff to previous 1.1 , to selected 1.6
fix(rcomb): Fixed handling of matrix inputs where NROWS is unspecified
Tue Dec 12 16:31:45 2023 UTC (2 years ago) by greg
Diff to selected 1.6
