root/radiance/ray/doc/man/man1/rcollate.1
Revision: 1.15
Committed: Tue Mar 15 00:25:50 2022 UTC (3 years, 3 months ago) by greg
Changes since 1.14: +3 -3 lines
feat(rcrop): Created simple cropping utility for matrices and pictures
1 .\" RCSid "$Id: rcollate.1,v 1.14 2020/09/07 17:08:08 greg Exp $"
2 .TH RCOLLATE 1 9/5/2013 RADIANCE
3 .SH NAME
4 rcollate - resize or re-order matrix data
5 .SH SYNOPSIS
6 .B rcollate
7 [
8 .B \-h[io]
9 ][
10 .B \-w
11 ][
12 .B \-c
13 ][
14 .B \-f{a|f|d|b}[N]
15 ][
16 .B \-t
17 ][
18 .B "\-ic in_col"
19 ][
20 .B "\-ir in_row"
21 ][
22 .B "\-oc out_col"
23 ][
24 .B "\-or out_row"
25 ][
26 .B "\-o RxC[xR1xC2..]"
27 ]
28 [
29 .B input.dat
30 ]
31 .SH DESCRIPTION
32 .I Rcollate
33 reads in a single matrix file (table) and reshapes it to have
34 the number of columns specified by the
35 .I \-oc
36 option.
37 The number of rows may be specified with a
38 .I \-or
39 option, or may be determined automatically from the size of the input if
40 it is an even multiple of the number of columns (as it should be).
41 Alternatively, both may be specified using a
42 .I \-o
43 option with the number of rows and columns separated by an 'x', as in "30x14"
44 for 30 rows by 14 columns.
45 .I Rcollate
46 can also reorder the input into nested blocks by continuing the output size
47 string.
48 For example, "3x10X7x2" would order output data with a 3x10 super-array of
49 7x2 subblocks.
50 This type of block hierarchy is convenient for visualizing tensor data.
51 .PP
52 By default, the file is assumed to include an information header, which
53 is copied to the standard output along with the command name.
54 The
55 .I \-hi
56 option may be used to turn off the expectation of a header on input.
57 The
58 .I \-ho
59 option turns off header output, and
60 .I \-h
61 by itself turns off both input and output headers.
62 The
63 .I \-w
64 option turns off non-fatal warning messages, such as unexpected EOD.
65 .PP
66 Normally,
67 .I rcollate
68 detects whether any transformation is actually taking place, and will
69 reproduce the data verbatim if the input size and shape should be unaltered.
70 The
71 .I \-c
72 opiton forces the operation to proceed, even if it appears to be a no-op,
73 which can be useful to correct a misshapen input matrix or check that
74 the data is the proper size.
75 .PP
76 The input format is assumed to be ASCII, with three white-space separated words
77 (typically numbers) in each record.
78 A different input format may be specified with the
79 .I \-f
80 option.
81 The suboptions are
82 .I \-fa,
83 .I \-ff,
84 .I \-fd,
85 and
86 .I \-fb
87 for ASCII, float, double, and binary, respectively.
88 An optional count may be attached to specify the number of data elements per
89 record, which defaults to 1.
90 Thus, the default setting is
91 .I \-fa3.
92 Since
93 .I rcollate
94 does not interpret the fields, all binary options of the same
95 length have the same result.
96 On most architectures,
97 .I \-ff6,
98 .I \-fd3,
99 and
100 .I \-fb24
101 would all be equivalent.
102 Note that the lack of row separators in binary files means that
103 .I rcollate
104 does not actually do anything for binary files unless the data is being
105 re-ordered.
106 .PP
107 If an input header is present, it may contain the format, number of components
108 and matrix dimensions.
109 In such cases, the
110 .I \-ic,
111 .I \-ir
112 and
113 .I \-f
114 options are not required, but will be checked against the header
115 information if provided.
116 .PP
117 The transpose option,
118 .I \-t
119 swaps rows and columns on the input.
120 For binary files with no header information, the user must
121 specify at least one input or output dimension to define the matrix size.
122 For ASCII files,
123 .I rcollate
124 will automatically determine the number of columns based on the
125 position of the first EOL (end-of-line) character, and the number
126 of rows based on the total count of records in the file.
127 The user may override these determinations, allowing the matrix to
128 be resized or re-ordered as well as transposed.
129 If input and output dimensions are given and there is no block re-ordering,
130 the number of input rows must equal the number of output columns,
131 and the number of input columns must equal the number of output rows.
132 If the
133 .I \-o
134 option is also given with multiple block levels, the transpose operation
135 will logically precede the re-ordering operation, regardless of their
136 position on the command line.
137 .SH EXAMPLES
138 To change put 8760 color triplets per row in a matrix with no header:
139 .IP "" .2i
140 rcollate -h \-oc 8760 input.dat > col8760.dat
141 .PP
142 To transpose a binary file with 145 float triplets per input row:
143 .IP "" .2i
144 rcollate -ff3 -ic 145 -t orig.flt > transpose.flt
145 .PP
146 To create an appropriate header for a binary float matrix as required by
147 .I rmtxop(1)\:
148 .IP "" .2i
149 rcollate -hi -ff3 -or 145 -oc 8760 input.smx | rmtxop dcoef.dmx - > res.txt
150 .PP
151 To visualize a Shirley-Chiu BTDF matrix where the interior resolution is
152 64x64 and the exterior resolution is 32x32:
153 .IP "" .2i
154 rcollate -o 64x64X32x32 s-c_bsdf.mtx | rmtxop -fc - > s-c_bsdf.hdr
155 .SH AUTHOR
156 Greg Ward
157 .SH NOTES
158 For large transpose or re-ordering operations on Unix systems,
159 it is most efficient to specify the input file on the command line,
160 rather than reading from the standard input, since
161 .I rcollate
162 can map the file directly into virtual memory.
163 .PP
164 The
165 .I rcollate
166 command is rather inflexible when it comes to output field and record
167 separators for ASCII data.
168 It accepts any amount of white space between fields
169 on input, but only produces spaces as field separators
170 between words and tabs as record separators on output.
171 Output row separtors will always be an EOL, which may differ between systems.
172 .PP
173 If no options are given on the command line, or a binary file is specified
174 without a transpose or re-ordering,
175 .I rcollate
176 issues a warning and simply copies its input to its standard output.
177 .SH "SEE ALSO"
178 cnt(1), histo(1), neaten(1), rcalc(1), rcrop(1), rlam(1), rmtxop(1),
179 rsplit(1), tabfunc(1), total(1)
