root/radiance/ray/doc/man/man1/rcollate.1
Revision: 1.10
Committed: Fri Nov 8 05:39:05 2019 UTC (5 years, 7 months ago) by greg
Changes since 1.9: +5 -1 lines
Fixing minor issues with new -o code
1 .\" RCSid "$Id: rcollate.1,v 1.9 2019/11/08 02:10:38 greg Exp $"
2 .TH RCOLLATE 1 7/8/97 RADIANCE
3 .SH NAME
4 rcollate - resize or transpose matrix data
5 .SH SYNOPSIS
6 .B rcollate
7 [
8 .B \-h[io]
9 ][
10 .B \-w
11 ][
12 .B \-f[afdb][N]
13 ][
14 .B \-t
15 ][
16 .B "\-ic in_col"
17 ][
18 .B "\-ir in_row"
19 ][
20 .B "\-oc out_col"
21 ][
22 .B "\-or out_row"
23 ][
24 .B "\-o RxC[xR1xC2..]"
25 ]
26 [
27 .B input.dat
28 ]
29 .SH DESCRIPTION
30 .I Rcollate
31 reads in a single matrix file (table) and reshapes it to have
32 the number of columns specified by the
33 .I \-oc
34 option.
35 The number of rows may be specified with a
36 .I \-or
37 option, or may be determined automatically from the size of the input if
38 it is an even multiple of the number of columns (as it should be).
39 Alternatively, both may be specified using a
40 .I \-o
41 option with the number of rows and columns separated by an 'x', as in "30x14"
42 for 30 rows by 14 columns.
43 .I Rcollate
44 can also reorder the input into nested blocks by continuing the output size
45 string, "3x10X7x2" would order output data with a 3x10 super-array of 7x2
46 subblocks.
47 This is a convenient way to visualize tensor data.
48 .PP
49 By default, the file is assumed to include an information header, which
50 is copied to the standard output along with the command name.
51 The
52 .I \-hi
53 option may be used to turn off the expectation of a header on input.
54 The
55 .I \-ho
56 option turns off header output, and
57 .I \-h
58 by itself turns off both input and output headers.
59 The
60 .I \-w
61 option turns off non-fatal warning messages, such as unexpected EOD.
62 .PP
63 The input format is assumed to be ASCII, with three white-space separated words
64 (typically numbers) in each record.
65 A different input format may be specified with the
66 .I \-f
67 option.
68 The suboptions are
69 .I \-fa,
70 .I \-ff,
71 .I \-fd,
72 and
73 .I \-fb
74 for ASCII, float, double, and binary, respectively.
75 An optional count may be attached to specify the number of data elements per
76 record, which defaults to 1.
77 Thus, the default setting is
78 .I \-fa3.
79 Since
80 .I rcollate
81 does not interpret the fields, all binary options of the same
82 length have the same result.
83 On most architectures,
84 .I \-ff6,
85 .I \-fd3,
86 and
87 .I \-fb24
88 would all be equivalent.
89 Note that the lack of row separators in binary files means that
90 .I rcollate
91 does not actually do anything for binary files unless the transpose
92 option is given, also.
93 .PP
94 If an input header is present, it may contain the format, number of components
95 and matrix dimensions.
96 In such cases, the
97 .I \-ic,
98 .I \-ir
99 and
100 .I \-f
101 options are not required, but will be checked against the header
102 information if provided.
103 .PP
104 The transpose option,
105 .I \-t
106 swaps rows and columns on the input.
107 For binary files, the user must specify at least one input or output
108 dimension to define the matrix size.
109 For ASCII files,
110 .I rcollate
111 will automatically determine the number of columns based on the
112 position of the first EOL (end-of-line) character, and the number
113 of rows based on the total count of records in the file.
114 The user may override these determinations, allowing the matrix to
115 be resized as well as transposed.
116 If input and output dimensions are given, the number of input rows
117 must equal the number of output columns,
118 and the number of input columns must equal the number of output rows.
119 For large transpose operations on Unix systems, it is most efficient
120 to specify the input file on the command line, rather than reading
121 from the standard input, since
122 .I rcollate
123 can map the file directly into virtual memory.
124 If the
125 .I \-o
126 option is also given with multiple block levels, the transpose operation
127 will logically precede the reblocking operation.
128 .SH EXAMPLES
129 To change put 8760 color triplets per row in a matrix with no header:
130 .IP "" .2i
131 rcollate -h \-oc 8760 input.dat > col8760.dat
132 .PP
133 To transpose a binary file with 145 float triplets per input row:
134 .IP "" .2i
135 rcollate -ff3 -ic 145 -t orig.flt > transpose.flt
136 .PP
137 To create an appropriate header for a binary float matrix as required by
138 .I rmtxop(1)\:
139 .IP "" .2i
140 rcollate -hi -ff3 -or 145 -oc 8760 input.smx | rmtxop dcoef.dmx - > res.txt
141 .PP
142 To visualize a Shirley-Chiu BTDF matrix where the interior resolution is
143 64x64 and the exterior resolution is 32x32:
144 .IP "" .2i
145 rcollate -o 64x64X32x32 s-c_bsdf.mtx | rmtxop -fc - > s-c_bsdf.hdr
146 .SH AUTHOR
147 Greg Ward
148 .SH NOTES
149 The
150 .I rcollate
151 command is rather inflexible when it comes to output field and record
152 separators for ASCII data.
153 It accepts any amount of white space between fields
154 on input, but only produces spaces as field separators
155 between words and tabs as record separators on output.
156 Output row separtors will always be an EOL, which may differ between systems.
157 .PP
158 If no options are given on the command line, or a binary file is specified
159 without a transpose,
160 .I rcollate
161 issues a warning and simply copies its input to its standard output.
162 .SH "SEE ALSO"
163 cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), rmtxop(1),
164 rsplit(1), tabfunc(1), total(1)
