--- ray/doc/man/man1/rcollate.1 2013/09/18 21:24:36 1.4 +++ ray/doc/man/man1/rcollate.1 2014/05/31 21:33:21 1.7 @@ -1,15 +1,15 @@ -.\" RCSid "$Id: rcollate.1,v 1.4 2013/09/18 21:24:36 greg Exp $" +.\" RCSid "$Id: rcollate.1,v 1.7 2014/05/31 21:33:21 greg Exp $" .TH RCOLLATE 1 7/8/97 RADIANCE .SH NAME rcollate - resize or transpose matrix data .SH SYNOPSIS .B rcollate [ -.B \-h +.B \-h[io] ][ .B \-w ][ -.B \-f[afdb][N]] +.B \-f[afdb][N] ][ .B \-t ][ @@ -31,9 +31,15 @@ the number of columns specified by the .I \-oc option. By default, the file is assumed to include an information header, which -is copied to the standard output along with the command name, but the +is copied to the standard output along with the command name. +The +.I \-hi +option may be used to turn off the expectation of a header on input. +The +.I \-ho +option turns off header output, and .I \-h -option may be used to turn this behavior off. +by itself turns off both input and output headers. The .I \-w option turns off non-fatal warning messages, such as unexpected EOD. @@ -69,6 +75,16 @@ Note that the lack of row separators in binary files m does not actually do anything for binary files unless the transpose option is given, also. .PP +If an input header is present, it may contain the format, number of components +and matrix dimensions. +In such cases, the +.I \-ic, +.I \-ir +and +.I \-f +options are not required, but will be checked against the header +information if provided. +.PP The transpose option, .I \-t swaps rows and columns on the input. @@ -97,6 +113,11 @@ rcollate -h \-oc 8760 input.dat > col8760.dat To transpose a binary file with 145 float triplets per input row: .IP "" .2i rcollate -ff3 -ic 145 -t orig.flt > transpose.flt +.PP +To create an appropriate header for a binary float matrix as required by +.I rmtxop(1)\: +.IP "" .2i +rcollate -hi -ff3 -or 145 -oc 8760 input.smx | rmtxop dcoef.dmx - > res.txt .SH AUTHOR Greg Ward .SH NOTES @@ -114,4 +135,4 @@ without a transpose, .I rcollate issues a warning and simply copies its input to its standard output. .SH "SEE ALSO" -cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), tabfunc(1), total(1) +cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), rmtxop(1), tabfunc(1), total(1)
