--- ray/doc/man/man1/rcollate.1 2013/09/05 18:50:30 1.2 +++ ray/doc/man/man1/rcollate.1 2013/09/06 21:34:38 1.3 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcollate.1,v 1.2 2013/09/05 18:50:30 greg Exp $" +.\" RCSid "$Id: rcollate.1,v 1.3 2013/09/06 21:34:38 greg Exp $" .TH RCOLLATE 1 7/8/97 RADIANCE .SH NAME rcollate - resize or transpose matrix data @@ -7,6 +7,8 @@ rcollate - resize or transpose matrix data [ .B \-h ][ +.B \-w +][ .B \-f[afdb][N]] ][ .B \-t @@ -32,6 +34,9 @@ By default, the file is assumed to include an informat is copied to the standard output along with the command name, but the .I \-h option may be used to turn this behavior off. +The +.I \-w +option turns off non-fatal warning messages, such as unexpected EOD. .PP The input format is assumed to be ASCII, with three white-space separated words (typically numbers) in each record.
