--- ray/doc/man/man1/rcollate.1 2013/09/05 18:50:30 1.2 +++ ray/doc/man/man1/rcollate.1 2019/11/11 18:38:41 1.12 @@ -1,14 +1,16 @@ -.\" RCSid "$Id: rcollate.1,v 1.2 2013/09/05 18:50:30 greg Exp $" +.\" RCSid "$Id: rcollate.1,v 1.12 2019/11/11 18:38:41 greg Exp $" .TH RCOLLATE 1 7/8/97 RADIANCE .SH NAME rcollate - resize or transpose matrix data .SH SYNOPSIS .B rcollate [ -.B \-h +.B \-h[io] ][ -.B \-f[afdb][N]] +.B \-w ][ +.B \-f[afdb][N] +][ .B \-t ][ .B "\-ic in_col" @@ -18,6 +20,8 @@ rcollate - resize or transpose matrix data .B "\-oc out_col" ][ .B "\-or out_row" +][ +.B "\-o RxC[xR1xC2..]" ] [ .B input.dat @@ -28,10 +32,34 @@ reads in a single matrix file (table) and reshapes it the number of columns specified by the .I \-oc option. +The number of rows may be specified with a +.I \-or +option, or may be determined automatically from the size of the input if +it is an even multiple of the number of columns (as it should be). +Alternatively, both may be specified using a +.I \-o +option with the number of rows and columns separated by an 'x', as in "30x14" +for 30 rows by 14 columns. +.I Rcollate +can also reorder the input into nested blocks by continuing the output size +string. +For example, "3x10X7x2" would order output data with a 3x10 super-array of +7x2 subblocks. +This type of block hierarchy is convenient for visualizing tensor data. +.PP By default, the file is assumed to include an information header, which -is copied to the standard output along with the command name, but the +is copied to the standard output along with the command name. +The +.I \-hi +option may be used to turn off the expectation of a header on input. +The +.I \-ho +option turns off header output, and .I \-h -option may be used to turn this behavior off. +by itself turns off both input and output headers. +The +.I \-w +option turns off non-fatal warning messages, such as unexpected EOD. .PP The input format is assumed to be ASCII, with three white-space separated words (typically numbers) in each record. @@ -64,6 +92,16 @@ Note that the lack of row separators in binary files m does not actually do anything for binary files unless the transpose option is given, also. .PP +If an input header is present, it may contain the format, number of components +and matrix dimensions. +In such cases, the +.I \-ic, +.I \-ir +and +.I \-f +options are not required, but will be checked against the header +information if provided. +.PP The transpose option, .I \-t swaps rows and columns on the input. @@ -83,8 +121,13 @@ For large transpose operations on Unix systems, it is to specify the input file on the command line, rather than reading from the standard input, since .I rcollate -can map the file directly into memory. -.SH EXAMPLE +can map the file directly into virtual memory. +If the +.I \-o +option is also given with multiple block levels, the transpose operation +will logically precede the reblocking operation, regardless of the order +they are given on the command line. +.SH EXAMPLES To change put 8760 color triplets per row in a matrix with no header: .IP "" .2i rcollate -h \-oc 8760 input.dat > col8760.dat @@ -92,6 +135,16 @@ rcollate -h \-oc 8760 input.dat > col8760.dat To transpose a binary file with 145 float triplets per input row: .IP "" .2i rcollate -ff3 -ic 145 -t orig.flt > transpose.flt +.PP +To create an appropriate header for a binary float matrix as required by +.I rmtxop(1)\: +.IP "" .2i +rcollate -hi -ff3 -or 145 -oc 8760 input.smx | rmtxop dcoef.dmx - > res.txt +.PP +To visualize a Shirley-Chiu BTDF matrix where the interior resolution is +64x64 and the exterior resolution is 32x32: +.IP "" .2i +rcollate -o 64x64X32x32 s-c_bsdf.mtx | rmtxop -fc - > s-c_bsdf.hdr .SH AUTHOR Greg Ward .SH NOTES @@ -109,4 +162,5 @@ without a transpose, .I rcollate issues a warning and simply copies its input to its standard output. .SH "SEE ALSO" -cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), tabfunc(1), total(1) +cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), rmtxop(1), +rsplit(1), tabfunc(1), total(1)
