--- ray/doc/man/man1/rcollate.1 2014/05/31 21:33:21 1.7 +++ ray/doc/man/man1/rcollate.1 2019/11/11 18:38:41 1.12 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcollate.1,v 1.7 2014/05/31 21:33:21 greg Exp $" +.\" RCSid "$Id: rcollate.1,v 1.12 2019/11/11 18:38:41 greg Exp $" .TH RCOLLATE 1 7/8/97 RADIANCE .SH NAME rcollate - resize or transpose matrix data @@ -20,6 +20,8 @@ rcollate - resize or transpose matrix data .B "\-oc out_col" ][ .B "\-or out_row" +][ +.B "\-o RxC[xR1xC2..]" ] [ .B input.dat @@ -30,6 +32,21 @@ reads in a single matrix file (table) and reshapes it the number of columns specified by the .I \-oc option. +The number of rows may be specified with a +.I \-or +option, or may be determined automatically from the size of the input if +it is an even multiple of the number of columns (as it should be). +Alternatively, both may be specified using a +.I \-o +option with the number of rows and columns separated by an 'x', as in "30x14" +for 30 rows by 14 columns. +.I Rcollate +can also reorder the input into nested blocks by continuing the output size +string. +For example, "3x10X7x2" would order output data with a 3x10 super-array of +7x2 subblocks. +This type of block hierarchy is convenient for visualizing tensor data. +.PP By default, the file is assumed to include an information header, which is copied to the standard output along with the command name. The @@ -105,7 +122,12 @@ to specify the input file on the command line, rather from the standard input, since .I rcollate can map the file directly into virtual memory. -.SH EXAMPLE +If the +.I \-o +option is also given with multiple block levels, the transpose operation +will logically precede the reblocking operation, regardless of the order +they are given on the command line. +.SH EXAMPLES To change put 8760 color triplets per row in a matrix with no header: .IP "" .2i rcollate -h \-oc 8760 input.dat > col8760.dat @@ -118,6 +140,11 @@ To create an appropriate header for a binary float mat .I rmtxop(1)\: .IP "" .2i rcollate -hi -ff3 -or 145 -oc 8760 input.smx | rmtxop dcoef.dmx - > res.txt +.PP +To visualize a Shirley-Chiu BTDF matrix where the interior resolution is +64x64 and the exterior resolution is 32x32: +.IP "" .2i +rcollate -o 64x64X32x32 s-c_bsdf.mtx | rmtxop -fc - > s-c_bsdf.hdr .SH AUTHOR Greg Ward .SH NOTES @@ -135,4 +162,5 @@ without a transpose, .I rcollate issues a warning and simply copies its input to its standard output. .SH "SEE ALSO" -cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), rmtxop(1), tabfunc(1), total(1) +cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), rmtxop(1), +rsplit(1), tabfunc(1), total(1)
