| 1 |
.\" RCSid "$Id: rcollate.1,v 1.3 2013/09/06 21:34:38 greg Exp $"
| 2 |
.TH RCOLLATE 1 7/8/97 RADIANCE
| 3 |
.SH NAME
| 4 |
rcollate - resize or transpose matrix data
| 5 |
.SH SYNOPSIS
| 6 |
.B rcollate
| 7 |
| 8 |
.B \-h
| 9 |
| 10 |
.B \-w
| 11 |
| 12 |
.B \-f[afdb][N]]
| 13 |
| 14 |
.B \-t
| 15 |
| 16 |
.B "\-ic in_col"
| 17 |
| 18 |
.B "\-ir in_row"
| 19 |
| 20 |
.B "\-oc out_col"
| 21 |
| 22 |
.B "\-or out_row"
| 23 |
| 24 |
| 25 |
.B input.dat
| 26 |
| 27 |
.SH DESCRIPTION
| 28 |
.I Rcollate
| 29 |
reads in a single matrix file (table) and reshapes it to have
| 30 |
the number of columns specified by the
| 31 |
.I \-oc
| 32 |
option.
| 33 |
By default, the file is assumed to include an information header, which
| 34 |
is copied to the standard output along with the command name, but the
| 35 |
.I \-h
| 36 |
option may be used to turn this behavior off.
| 37 |
The
| 38 |
.I \-w
| 39 |
option turns off non-fatal warning messages, such as unexpected EOD.
| 40 |
.PP
| 41 |
The input format is assumed to be ASCII, with three white-space separated words
| 42 |
(typically numbers) in each record.
| 43 |
A different input format may be specified with the
| 44 |
.I \-f
| 45 |
option.
| 46 |
The suboptions are
| 47 |
.I \-fa,
| 48 |
.I \-ff,
| 49 |
.I \-fd,
| 50 |
and
| 51 |
.I \-fb
| 52 |
for ASCII, float, double, and binary, respectively.
| 53 |
An optional count may be attached to specify the number of data elements per
| 54 |
record, which defaults to 1.
| 55 |
Thus, the default setting is
| 56 |
.I \-fa3.
| 57 |
Since
| 58 |
.I rcollate
| 59 |
does not interpret the fields, all binary options of the same
| 60 |
length have the same result.
| 61 |
On most architectures,
| 62 |
.I \-ff6,
| 63 |
.I \-fd3,
| 64 |
and
| 65 |
.I \-fb24
| 66 |
would all be equivalent.
| 67 |
Note that the lack of row separators in binary files means that
| 68 |
.I rcollate
| 69 |
does not actually do anything for binary files unless the transpose
| 70 |
option is given, also.
| 71 |
.PP
| 72 |
The transpose option,
| 73 |
.I \-t
| 74 |
swaps rows and columns on the input.
| 75 |
For binary files, the user must specify at least one input or output
| 76 |
dimension to define the matrix size.
| 77 |
For ASCII files,
| 78 |
.I rcollate
| 79 |
will automatically determine the number of columns based on the
| 80 |
position of the first EOL (end-of-line) character, and the number
| 81 |
of rows based on the total count of records in the file.
| 82 |
The user may override these determinations, allowing the matrix to
| 83 |
be resized as well as transposed.
| 84 |
If input and output dimensions are given, the number of input rows
| 85 |
must equal the number of output columns,
| 86 |
and the number of input columns must equal the number of output rows.
| 87 |
For large transpose operations on Unix systems, it is most efficient
| 88 |
to specify the input file on the command line, rather than reading
| 89 |
from the standard input, since
| 90 |
.I rcollate
| 91 |
can map the file directly into virtual memory.
| 92 |
.SH EXAMPLE
| 93 |
To change put 8760 color triplets per row in a matrix with no header:
| 94 |
.IP "" .2i
| 95 |
rcollate -h \-oc 8760 input.dat > col8760.dat
| 96 |
.PP
| 97 |
To transpose a binary file with 145 float triplets per input row:
| 98 |
.IP "" .2i
| 99 |
rcollate -ff3 -ic 145 -t orig.flt > transpose.flt
| 100 |
.SH AUTHOR
| 101 |
Greg Ward
| 102 |
.SH NOTES
| 103 |
The
| 104 |
.I rcollate
| 105 |
command is rather inflexible when it comes to output field and record
| 106 |
separators for ASCII data.
| 107 |
It accepts any amount of white space between fields
| 108 |
on input, but only produces spaces as field separators
| 109 |
between words and tabs as record separators on output.
| 110 |
Output row separtors will always be an EOL, which may differ between systems.
| 111 |
.PP
| 112 |
If no options are given on the command line, or a binary file is specified
| 113 |
without a transpose,
| 114 |
.I rcollate
| 115 |
issues a warning and simply copies its input to its standard output.
| 116 |
.SH "SEE ALSO"
| 117 |
cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), tabfunc(1), total(1)
