1 |
.\" RCSid "$Id: rcollate.1,v 1.2 2013/09/05 18:50:30 greg Exp $" |
2 |
.TH RCOLLATE 1 7/8/97 RADIANCE |
3 |
.SH NAME |
4 |
rcollate - resize or transpose matrix data |
5 |
.SH SYNOPSIS |
6 |
.B rcollate |
7 |
8 |
.B \-h |
9 |
10 |
.B \-w |
11 |
12 |
.B \-f[afdb][N]] |
13 |
14 |
.B \-t |
15 |
16 |
.B "\-ic in_col" |
17 |
18 |
.B "\-ir in_row" |
19 |
20 |
.B "\-oc out_col" |
21 |
22 |
.B "\-or out_row" |
23 |
24 |
25 |
.B input.dat |
26 |
27 |
.SH DESCRIPTION |
28 |
.I Rcollate |
29 |
reads in a single matrix file (table) and reshapes it to have |
30 |
the number of columns specified by the |
31 |
.I \-oc |
32 |
option. |
33 |
By default, the file is assumed to include an information header, which |
34 |
is copied to the standard output along with the command name, but the |
35 |
.I \-h |
36 |
option may be used to turn this behavior off. |
37 |
The |
38 |
.I \-w |
39 |
option turns off non-fatal warning messages, such as unexpected EOD. |
40 |
.PP |
41 |
The input format is assumed to be ASCII, with three white-space separated words |
42 |
(typically numbers) in each record. |
43 |
A different input format may be specified with the |
44 |
.I \-f |
45 |
option. |
46 |
The suboptions are |
47 |
.I \-fa, |
48 |
.I \-ff, |
49 |
.I \-fd, |
50 |
and |
51 |
.I \-fb |
52 |
for ASCII, float, double, and binary, respectively. |
53 |
An optional count may be attached to specify the number of data elements per |
54 |
record, which defaults to 1. |
55 |
Thus, the default setting is |
56 |
.I \-fa3. |
57 |
Since |
58 |
.I rcollate |
59 |
does not interpret the fields, all binary options of the same |
60 |
length have the same result. |
61 |
On most architectures, |
62 |
.I \-ff6, |
63 |
.I \-fd3, |
64 |
and |
65 |
.I \-fb24 |
66 |
would all be equivalent. |
67 |
Note that the lack of row separators in binary files means that |
68 |
.I rcollate |
69 |
does not actually do anything for binary files unless the transpose |
70 |
option is given, also. |
71 |
.PP |
72 |
The transpose option, |
73 |
.I \-t |
74 |
swaps rows and columns on the input. |
75 |
For binary files, the user must specify at least one input or output |
76 |
dimension to define the matrix size. |
77 |
For ASCII files, |
78 |
.I rcollate |
79 |
will automatically determine the number of columns based on the |
80 |
position of the first EOL (end-of-line) character, and the number |
81 |
of rows based on the total count of records in the file. |
82 |
The user may override these determinations, allowing the matrix to |
83 |
be resized as well as transposed. |
84 |
If input and output dimensions are given, the number of input rows |
85 |
must equal the number of output columns, |
86 |
and the number of input columns must equal the number of output rows. |
87 |
For large transpose operations on Unix systems, it is most efficient |
88 |
to specify the input file on the command line, rather than reading |
89 |
from the standard input, since |
90 |
.I rcollate |
91 |
can map the file directly into memory. |
92 |
.SH EXAMPLE |
93 |
To change put 8760 color triplets per row in a matrix with no header: |
94 |
.IP "" .2i |
95 |
rcollate -h \-oc 8760 input.dat > col8760.dat |
96 |
.PP |
97 |
To transpose a binary file with 145 float triplets per input row: |
98 |
.IP "" .2i |
99 |
rcollate -ff3 -ic 145 -t orig.flt > transpose.flt |
100 |
.SH AUTHOR |
101 |
Greg Ward |
102 |
.SH NOTES |
103 |
The |
104 |
.I rcollate |
105 |
command is rather inflexible when it comes to output field and record |
106 |
separators for ASCII data. |
107 |
It accepts any amount of white space between fields |
108 |
on input, but only produces spaces as field separators |
109 |
between words and tabs as record separators on output. |
110 |
Output row separtors will always be an EOL, which may differ between systems. |
111 |
.PP |
112 |
If no options are given on the command line, or a binary file is specified |
113 |
without a transpose, |
114 |
.I rcollate |
115 |
issues a warning and simply copies its input to its standard output. |
116 |
.SH "SEE ALSO" |
117 |
cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), tabfunc(1), total(1) |
