1 |
.\" RCSid "$Id: rcollate.1,v 1.6 2014/05/30 16:50:43 greg Exp $" |
2 |
.TH RCOLLATE 1 7/8/97 RADIANCE |
3 |
.SH NAME |
4 |
rcollate - resize or transpose matrix data |
5 |
.SH SYNOPSIS |
6 |
.B rcollate |
7 |
8 |
.B \-h[io] |
9 |
10 |
.B \-w |
11 |
12 |
.B \-f[afdb][N] |
13 |
14 |
.B \-t |
15 |
16 |
.B "\-ic in_col" |
17 |
18 |
.B "\-ir in_row" |
19 |
20 |
.B "\-oc out_col" |
21 |
22 |
.B "\-or out_row" |
23 |
24 |
25 |
.B input.dat |
26 |
27 |
.SH DESCRIPTION |
28 |
.I Rcollate |
29 |
reads in a single matrix file (table) and reshapes it to have |
30 |
the number of columns specified by the |
31 |
.I \-oc |
32 |
option. |
33 |
By default, the file is assumed to include an information header, which |
34 |
is copied to the standard output along with the command name. |
35 |
The |
36 |
.I \-hi |
37 |
option may be used to turn off the expectation of a header on input. |
38 |
The |
39 |
.I \-ho |
40 |
option turns off header output, and |
41 |
.I \-h |
42 |
by itself turns off both input and output headers. |
43 |
The |
44 |
.I \-w |
45 |
option turns off non-fatal warning messages, such as unexpected EOD. |
46 |
.PP |
47 |
The input format is assumed to be ASCII, with three white-space separated words |
48 |
(typically numbers) in each record. |
49 |
A different input format may be specified with the |
50 |
.I \-f |
51 |
option. |
52 |
The suboptions are |
53 |
.I \-fa, |
54 |
.I \-ff, |
55 |
.I \-fd, |
56 |
and |
57 |
.I \-fb |
58 |
for ASCII, float, double, and binary, respectively. |
59 |
An optional count may be attached to specify the number of data elements per |
60 |
record, which defaults to 1. |
61 |
Thus, the default setting is |
62 |
.I \-fa3. |
63 |
Since |
64 |
.I rcollate |
65 |
does not interpret the fields, all binary options of the same |
66 |
length have the same result. |
67 |
On most architectures, |
68 |
.I \-ff6, |
69 |
.I \-fd3, |
70 |
and |
71 |
.I \-fb24 |
72 |
would all be equivalent. |
73 |
Note that the lack of row separators in binary files means that |
74 |
.I rcollate |
75 |
does not actually do anything for binary files unless the transpose |
76 |
option is given, also. |
77 |
.PP |
78 |
If an input header is present, it may contain the format, number of components |
79 |
and matrix dimensions. |
80 |
In such cases, the |
81 |
.I \-ic, |
82 |
.I \-ir |
83 |
and |
84 |
.I \-f |
85 |
options are not required, but will be checked against the header |
86 |
information if provided. |
87 |
.PP |
88 |
The transpose option, |
89 |
.I \-t |
90 |
swaps rows and columns on the input. |
91 |
For binary files, the user must specify at least one input or output |
92 |
dimension to define the matrix size. |
93 |
For ASCII files, |
94 |
.I rcollate |
95 |
will automatically determine the number of columns based on the |
96 |
position of the first EOL (end-of-line) character, and the number |
97 |
of rows based on the total count of records in the file. |
98 |
The user may override these determinations, allowing the matrix to |
99 |
be resized as well as transposed. |
100 |
If input and output dimensions are given, the number of input rows |
101 |
must equal the number of output columns, |
102 |
and the number of input columns must equal the number of output rows. |
103 |
For large transpose operations on Unix systems, it is most efficient |
104 |
to specify the input file on the command line, rather than reading |
105 |
from the standard input, since |
106 |
.I rcollate |
107 |
can map the file directly into virtual memory. |
108 |
.SH EXAMPLE |
109 |
To change put 8760 color triplets per row in a matrix with no header: |
110 |
.IP "" .2i |
111 |
rcollate -h \-oc 8760 input.dat > col8760.dat |
112 |
.PP |
113 |
To transpose a binary file with 145 float triplets per input row: |
114 |
.IP "" .2i |
115 |
rcollate -ff3 -ic 145 -t orig.flt > transpose.flt |
116 |
.PP |
117 |
To create an appropriate header for a binary float matrix as required by |
118 |
.I rmtxop(1)\: |
119 |
.IP "" .2i |
120 |
rcollate -hi -ff3 -or 145 -oc 8760 input.smx | rmtxop dcoef.dmx - > res.txt |
121 |
.SH AUTHOR |
122 |
Greg Ward |
123 |
.SH NOTES |
124 |
The |
125 |
.I rcollate |
126 |
command is rather inflexible when it comes to output field and record |
127 |
separators for ASCII data. |
128 |
It accepts any amount of white space between fields |
129 |
on input, but only produces spaces as field separators |
130 |
between words and tabs as record separators on output. |
131 |
Output row separtors will always be an EOL, which may differ between systems. |
132 |
.PP |
133 |
If no options are given on the command line, or a binary file is specified |
134 |
without a transpose, |
135 |
.I rcollate |
136 |
issues a warning and simply copies its input to its standard output. |
137 |
.SH "SEE ALSO" |
138 |
cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), rmtxop(1), tabfunc(1), total(1) |
