root/Development/ray/doc/man/man1/rcollate.1
Revision: 1.13
Committed: Mon Nov 11 18:50:07 2019 UTC (5 years, 10 months ago) by greg
Changes since 1.12: +18 -17 lines
Further wording improvments and details
1 .\" RCSid "$Id: rcollate.1,v 1.12 2019/11/11 18:38:41 greg Exp $"
2 .TH RCOLLATE 1 7/8/97 RADIANCE
3 .SH NAME
4 rcollate - resize or re-order matrix data
5 .SH SYNOPSIS
6 .B rcollate
7 [
8 .B \-h[io]
9 ][
10 .B \-w
11 ][
12 .B \-f[afdb][N]
13 ][
14 .B \-t
15 ][
16 .B "\-ic in_col"
17 ][
18 .B "\-ir in_row"
19 ][
20 .B "\-oc out_col"
21 ][
22 .B "\-or out_row"
23 ][
24 .B "\-o RxC[xR1xC2..]"
25 ]
26 [
27 .B input.dat
28 ]
29 .SH DESCRIPTION
30 .I Rcollate
31 reads in a single matrix file (table) and reshapes it to have
32 the number of columns specified by the
33 .I \-oc
34 option.
35 The number of rows may be specified with a
36 .I \-or
37 option, or may be determined automatically from the size of the input if
38 it is an even multiple of the number of columns (as it should be).
39 Alternatively, both may be specified using a
40 .I \-o
41 option with the number of rows and columns separated by an 'x', as in "30x14"
42 for 30 rows by 14 columns.
43 .I Rcollate
44 can also reorder the input into nested blocks by continuing the output size
45 string.
46 For example, "3x10X7x2" would order output data with a 3x10 super-array of
47 7x2 subblocks.
48 This type of block hierarchy is convenient for visualizing tensor data.
49 .PP
50 By default, the file is assumed to include an information header, which
51 is copied to the standard output along with the command name.
52 The
53 .I \-hi
54 option may be used to turn off the expectation of a header on input.
55 The
56 .I \-ho
57 option turns off header output, and
58 .I \-h
59 by itself turns off both input and output headers.
60 The
61 .I \-w
62 option turns off non-fatal warning messages, such as unexpected EOD.
63 .PP
64 The input format is assumed to be ASCII, with three white-space separated words
65 (typically numbers) in each record.
66 A different input format may be specified with the
67 .I \-f
68 option.
69 The suboptions are
70 .I \-fa,
71 .I \-ff,
72 .I \-fd,
73 and
74 .I \-fb
75 for ASCII, float, double, and binary, respectively.
76 An optional count may be attached to specify the number of data elements per
77 record, which defaults to 1.
78 Thus, the default setting is
79 .I \-fa3.
80 Since
81 .I rcollate
82 does not interpret the fields, all binary options of the same
83 length have the same result.
84 On most architectures,
85 .I \-ff6,
86 .I \-fd3,
87 and
88 .I \-fb24
89 would all be equivalent.
90 Note that the lack of row separators in binary files means that
91 .I rcollate
92 does not actually do anything for binary files unless the data is being
93 re-ordered.
94 .PP
95 If an input header is present, it may contain the format, number of components
96 and matrix dimensions.
97 In such cases, the
98 .I \-ic,
99 .I \-ir
100 and
101 .I \-f
102 options are not required, but will be checked against the header
103 information if provided.
104 .PP
105 The transpose option,
106 .I \-t
107 swaps rows and columns on the input.
108 For binary files with no header information, the user must
109 specify at least one input or output dimension to define the matrix size.
110 For ASCII files,
111 .I rcollate
112 will automatically determine the number of columns based on the
113 position of the first EOL (end-of-line) character, and the number
114 of rows based on the total count of records in the file.
115 The user may override these determinations, allowing the matrix to
116 be resized or re-ordered as well as transposed.
117 If input and output dimensions are given and there is no block re-ordering,
118 the number of input rows must equal the number of output columns,
119 and the number of input columns must equal the number of output rows.
120 If the
121 .I \-o
122 option is also given with multiple block levels, the transpose operation
123 will logically precede the re-ordering operation, regardless of their
124 position on the command line.
125 .SH EXAMPLES
126 To change put 8760 color triplets per row in a matrix with no header:
127 .IP "" .2i
128 rcollate -h \-oc 8760 input.dat > col8760.dat
129 .PP
130 To transpose a binary file with 145 float triplets per input row:
131 .IP "" .2i
132 rcollate -ff3 -ic 145 -t orig.flt > transpose.flt
133 .PP
134 To create an appropriate header for a binary float matrix as required by
135 .I rmtxop(1)\:
136 .IP "" .2i
137 rcollate -hi -ff3 -or 145 -oc 8760 input.smx | rmtxop dcoef.dmx - > res.txt
138 .PP
139 To visualize a Shirley-Chiu BTDF matrix where the interior resolution is
140 64x64 and the exterior resolution is 32x32:
141 .IP "" .2i
142 rcollate -o 64x64X32x32 s-c_bsdf.mtx | rmtxop -fc - > s-c_bsdf.hdr
143 .SH AUTHOR
144 Greg Ward
145 .SH NOTES
146 For large transpose or re-ordering operations on Unix systems,
147 it is most efficient to specify the input file on the command line,
148 rather than reading from the standard input, since
149 .I rcollate
150 can map the file directly into virtual memory.
151 .PP
152 The
153 .I rcollate
154 command is rather inflexible when it comes to output field and record
155 separators for ASCII data.
156 It accepts any amount of white space between fields
157 on input, but only produces spaces as field separators
158 between words and tabs as record separators on output.
159 Output row separtors will always be an EOL, which may differ between systems.
160 .PP
161 If no options are given on the command line, or a binary file is specified
162 without a transpose or re-ordering,
163 .I rcollate
164 issues a warning and simply copies its input to its standard output.
165 .SH "SEE ALSO"
166 cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), rmtxop(1),
167 rsplit(1), tabfunc(1), total(1)
