root/Development/ray/doc/man/man1/rcollate.1
Revision: 1.1
Committed: Thu Sep 5 17:53:22 2013 UTC (12 years, 3 months ago) by greg
1 .\" RCSid "$Id: rlam.1,v 1.7 2010/06/18 21:22:49 greg Exp $"
2 .TH RCOLLATE 1 7/8/97 RADIANCE
3 .SH NAME
4 rcollate - resize or transpose matrix data
5 .SH SYNOPSIS
6 .B rcollate
7 [
8 .B \-h
9 ][
10 .B \-f[afdb][N]]
11 ][
12 .B \-t
13 ][
14 .B "\-ic in_col"
15 ][
16 .B "\-ir in_row"
17 ][
18 .B "\-oc out_col"
19 ][
20 .B "\-or out_row"
21 ]
22 [
23 .B input.dat
24 ]
25 .SH DESCRIPTION
26 .I Rcollate
27 reads in a single matrix file (table) and reshapes it to have
28 the number of columns specified by the
29 .I \-oc
30 option.
31 By default, the file is assumed to include an information header, which
32 is copied to the standard output along with the command name, but the
33 .I \-h
34 option may be used to turn this behavior off.
35 .PP
36 The input format is assumed to be ASCII, with three white-space separated words
37 (typically numbers) in each record.
38 A different input format may be specified with the
39 .I \-f
40 option.
41 The suboptions are
42 .I \-fa,
43 .I \-ff,
44 .I \-fd,
45 and
46 .I \-fb
47 for ASCII, float, double, and binary, respectively.
48 An optional count may be attached to specify the number of data elements per
49 record, which defaults to 1.
50 Thus, the default setting is
51 .I \-fa3.
52 Since
53 .I rcollate
54 does not interpret the fields, all binary options of the same
55 length have the same result.
56 On most architectures,
57 .I \-ff6,
58 .I \-fd3,
59 and
60 .I \-fb24
61 would all be equivalent.
62 Note also that the lack of row separators in binary files means that
63 .I rcollate
64 does not actually do anything for binary files unless the transpose
65 .I \(\-t\)
66 option is given, also.
67 .PP
68 The transpose option,
69 .I \-t
70 swaps rows and columns on the input.
71 For binary files, the user must specify at least one input or output
72 dimension to define the matrix size.
73 For ASCII files,
74 .I rcollate
75 will automatically determine the number of columns based on the
76 position of the first EOL (end-of-line) character, and the number
77 of rows based on the count of records in the file.
78 The user may override these determinations, allowing the matrix to
79 be resized as well as transposed.
80 If input and output dimensions are given, the number of input rows
81 must equal the number of output columns,
82 and the number of input columns must equal the number of output rows
83 with the
84 .I \-t
85 option.
86 For large transpose operations on Unix systems, it is much more efficient
87 to specify the input file on the command line, rather than reading
88 from the standard input, since
89 .I rcollate
90 can map the file directly into memory.
91 .SH EXAMPLE
92 To change put 8760 color triplets per row in a matrix with no header:
93 .IP "" .2i
94 rcollate -h \-oc 8760 input.dat > col8760.dat
95 .PP
96 To transpose a binary file with 145 float triplets per input row:
97 .IP "" .2i
98 rcollate -ff3 -ic 145 -t orig.flt > transpose.flt
99 .SH AUTHOR
100 Greg Ward
101 .SH NOTES
102 The
103 .I rcollate
104 command is rather inflexible when it comes to output field and record
105 separators for ASCII data.
106 It accepts any number or type of white space between input fields
107 on input, but only produces spaces as field separators
108 between words and tabs as record separators.
109 Output row separtors will always be an EOL, which may differ between systems.
110 .PP
111 If no options are given on the command line, or a binary file is specified
112 without a transpose,
113 .I rcollate
114 issues a warning and simply copies its input to the standard output.
115 .SH "SEE ALSO"
116 cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), tabfunc(1), total(1)
