1 |
.\" RCSid "$Id: rcode_norm.1,v 1.1 2019/07/20 02:07:23 greg Exp $" |
2 |
.TH RCODE_NORM 1 7/19/2019 RADIANCE |
3 |
.SH NAME |
4 |
rcode_norm - encode/decode 32-bit surface normal map |
5 |
.SH SYNOPSIS |
6 |
.B rcode_norm |
7 |
8 |
.B \-h[io] |
9 |
10 |
.B \-H[io] |
11 |
12 |
.B \-f[afd] |
13 |
14 |
15 |
input |
16 |
[output.nrm] |
17 |
18 |
.br |
19 |
.B "rcode_norm -r" |
20 |
21 |
.B \-i |
22 |
23 |
.B \-u |
24 |
25 |
.B \-h[io] |
26 |
27 |
.B \-H[io] |
28 |
29 |
.B \-f[afd] |
30 |
31 |
32 |
input.nrm |
33 |
[output] |
34 |
35 |
.SH DESCRIPTION |
36 |
.I Rcode_norm |
37 |
reads a map of normaled direction vectors |
38 |
and encodes them in an efficient 32-bit/pixel format for storage. |
39 |
Input is taken from the first named file, or standard input if no |
40 |
files are given. |
41 |
Output is sent to the second named file, or standard output if none. |
42 |
.PP |
43 |
The |
44 |
.I \-hi |
45 |
option tells |
46 |
.I rcode_norm |
47 |
not to expect an information header on its input. |
48 |
The |
49 |
.I \-ho |
50 |
option tells |
51 |
.I rcode_norm |
52 |
not to produce an information header on its output. |
53 |
Specifying |
54 |
.I \-h |
55 |
turns both input and output headers off. |
56 |
Similarly, the |
57 |
.I \-Hi |
58 |
option says not to expect an image resolution string on input, the |
59 |
.I \-Ho |
60 |
option says not to produce one on output, and |
61 |
.I \-H |
62 |
applies both. |
63 |
.PP |
64 |
The default input format is ASCII (user-readable) real triplets, |
65 |
corresponding to the |
66 |
.I \-fa |
67 |
option. |
68 |
The |
69 |
.I \-ff |
70 |
option tells |
71 |
.I rcode_norm |
72 |
to expect three binary, 32-bit floating-point values per |
73 |
normal on its input, instead. |
74 |
The |
75 |
.I \-fd |
76 |
option tells it to expect 64-bit/component vectors. |
77 |
.PP |
78 |
The second form applies the |
79 |
.I \-r |
80 |
option to perform a reverse conversion, decoding 32-bit normal directions |
81 |
on the input and producing one of the above formats on output. |
82 |
The |
83 |
.I \-h |
84 |
and |
85 |
.I \-H |
86 |
options have the same behavior as before. |
87 |
.PP |
88 |
When decoding, the |
89 |
.I \-i |
90 |
option tells |
91 |
.I rcode_norm |
92 |
to produce one depth or world point |
93 |
for each integer input pair specifying |
94 |
the horizontal and vertical coordinates of a particular pixel, |
95 |
where x is measured from 0 on the left and y from 0 at the bottom |
96 |
in the standard orientation. |
97 |
Note that |
98 |
.I \-i |
99 |
implies that an encoded normal file is explicitly given on the command |
100 |
line, since the pixel coordinates are read from the standard input. |
101 |
Also, the |
102 |
.I \-H |
103 |
option is not supported with |
104 |
.I \-i, |
105 |
since the map dimensions are required on the |
106 |
input and not copied to the output. |
107 |
If the |
108 |
.I \-u |
109 |
option is also given, output will be flushed after each normal. |
110 |
.SH EXAMPLES |
111 |
To store float surface normals out of rtrace: |
112 |
.IP "" .2i |
113 |
rtrace -ff < rays.flt -x 512 -y 400 -oN octree | rcode_norm -ff > norms.nrm |
114 |
.PP |
115 |
To query specific normals using ximage with the 't' command: |
116 |
.IP "" .2i |
117 |
ximage -op render.hdr | rcode_norm -i -r norms.nrm |
118 |
.SH AUTHOR |
119 |
Greg Ward |
120 |
.SH "SEE ALSO" |
121 |
rcalc(1), rcode_depth(1), rcode_ident(1), rcode2bmp(1), |
122 |
rlam(1), rsplit(1), rtpict(1) |
