| 1 |
.\" RCSid "$Id: rcode_norm.1,v 1.4 2021/04/28 19:15:09 greg Exp $"
| 2 |
.TH RCODE_NORM 1 7/19/2019 RADIANCE
| 3 |
.SH NAME
| 4 |
rcode_norm - encode/decode 32-bit surface normal map
| 5 |
.SH SYNOPSIS
| 6 |
.B rcode_norm
| 7 |
| 8 |
.B \-h[io]
| 9 |
| 10 |
.B \-H[io]
| 11 |
| 12 |
.B \-f[afd]
| 13 |
| 14 |
.B "-x xr -y yr"
| 15 |
| 16 |
| 17 |
input
| 18 |
[output.nrm]
| 19 |
| 20 |
.br
| 21 |
.B "rcode_norm -r"
| 22 |
| 23 |
.B \-i
| 24 |
| 25 |
.B \-u
| 26 |
| 27 |
.B \-h[io]
| 28 |
| 29 |
.B \-H[io]
| 30 |
| 31 |
.B \-f[afd]
| 32 |
| 33 |
| 34 |
input.nrm
| 35 |
[output]
| 36 |
| 37 |
.SH DESCRIPTION
| 38 |
.I Rcode_norm
| 39 |
reads a map of direction vectors
| 40 |
and encodes them in an efficient 32-bit/pixel format.
| 41 |
Input is taken from the first named file, or standard input if no
| 42 |
files are given.
| 43 |
Output is sent to the second named file, or standard output if none.
| 44 |
.PP
| 45 |
The
| 46 |
.I \-hi
| 47 |
option tells
| 48 |
.I rcode_norm
| 49 |
not to expect an information header on its input.
| 50 |
The
| 51 |
.I \-ho
| 52 |
option tells
| 53 |
.I rcode_norm
| 54 |
not to produce an information header on its output.
| 55 |
Specifying
| 56 |
.I \-h
| 57 |
turns both input and output headers off.
| 58 |
Similarly, the
| 59 |
.I \-Hi
| 60 |
option says not to expect an image resolution string on input, the
| 61 |
.I \-Ho
| 62 |
option says not to produce one on output, and
| 63 |
.I \-H
| 64 |
applies both.
| 65 |
The
| 66 |
.I \-x
| 67 |
and
| 68 |
.I \-y
| 69 |
options give the horizontal and vertical map dimensions, respectively.
| 70 |
If provided, then an input resolution string will not be expected.
| 71 |
.PP
| 72 |
The default input format is ASCII (user-readable) real triplets,
| 73 |
corresponding to the
| 74 |
.I \-fa
| 75 |
option.
| 76 |
The
| 77 |
.I \-ff
| 78 |
option tells
| 79 |
.I rcode_norm
| 80 |
to expect three binary, 32-bit floating-point values per
| 81 |
normal on its input, instead.
| 82 |
The
| 83 |
.I \-fd
| 84 |
option tells it to expect 64-bit/component vectors.
| 85 |
.PP
| 86 |
The second form applies the
| 87 |
.I \-r
| 88 |
option to perform a reverse conversion, decoding 32-bit normal directions
| 89 |
on the input and producing one of the above formats on output.
| 90 |
The
| 91 |
.I \-h
| 92 |
and
| 93 |
.I \-H
| 94 |
options have the same behavior as before.
| 95 |
.PP
| 96 |
When decoding, the
| 97 |
.I \-i
| 98 |
option tells
| 99 |
.I rcode_norm
| 100 |
to produce one depth or world point
| 101 |
for each integer input pair specifying
| 102 |
the horizontal and vertical coordinates of a particular pixel,
| 103 |
where x is measured from 0 on the left and y from 0 at the bottom
| 104 |
in the standard orientation.
| 105 |
Note that
| 106 |
.I \-i
| 107 |
implies that an encoded normal file is explicitly given on the command
| 108 |
line, since the pixel coordinates are read from the standard input.
| 109 |
Also, the
| 110 |
.I \-H
| 111 |
option is not supported with
| 112 |
.I \-i,
| 113 |
since the map dimensions are required on the
| 114 |
input and not copied to the output.
| 115 |
If the
| 116 |
.I \-u
| 117 |
option is also given, output will be flushed after each normal.
| 118 |
.SH EXAMPLES
| 119 |
To store float surface normals out of rtrace:
| 120 |
.IP "" .2i
| 121 |
rtrace -ff < rays.flt -x 512 -y 400 -oN octree | rcode_norm -ff > norms.nrm
| 122 |
.PP
| 123 |
To query specific normals using ximage with the 't' command:
| 124 |
.IP "" .2i
| 125 |
ximage -op render.hdr | rcode_norm -i -r norms.nrm
| 126 |
.SH AUTHOR
| 127 |
Greg Ward
| 128 |
.SH "SEE ALSO"
| 129 |
rcalc(1), rcode_depth(1), rcode_ident(1), rcode2bmp(1),
| 130 |
rcrop(1), rlam(1), rsplit(1), rtpict(1)
