1 |
.\" RCSid "$Id: rcode_ident.1,v 1.4 2019/08/26 19:23:51 greg Exp $" |
2 |
.TH RCODE_IDENT 1 7/19/2019 RADIANCE |
3 |
.SH NAME |
4 |
rcode_ident - store identifiers in an indexed map and retrieve from same |
5 |
.SH SYNOPSIS |
6 |
.B rcode_ident |
7 |
8 |
.I "-8 | -16 | -24" |
9 |
10 |
.B \-h |
11 |
12 |
.B \-tS |
13 |
14 |
.B "-x xr -y yr" |
15 |
16 |
17 |
input.txt |
18 |
[output.idx] |
19 |
20 |
.br |
21 |
.B "rcode_ident -r" |
22 |
23 |
.B \-i |
24 |
25 |
.B \-u |
26 |
27 |
.B \-h |
28 |
29 |
.B \-H |
30 |
31 |
.B \-l |
32 |
33 |
.B \-n |
34 |
35 |
.B \-tS |
36 |
37 |
38 |
input.idx |
39 |
[output.txt] |
40 |
41 |
.SH DESCRIPTION |
42 |
.I Rcode_ident |
43 |
takes a list of ASCII identifiers on the input and encodes them |
44 |
as a 16-bit index to a table appended to the output. |
45 |
This default index size can hold up to 65 thousand unique IDs, |
46 |
which is suitable for most applications. |
47 |
The |
48 |
.I \-8 |
49 |
option may be used to specify an 8-bit index, which saves space |
50 |
if 256 or fewer unique identifiers appear on the input. |
51 |
The |
52 |
.I \-24 |
53 |
option creates a 24-bit index that can record over 16 million |
54 |
unique identifiers. |
55 |
.PP |
56 |
Identifiers are separated by newlines by default, but any single-character |
57 |
separator may be given with the |
58 |
.I \-tS |
59 |
option. |
60 |
Note there is no space between this option and its argument. |
61 |
Leading and trailing white space is eliminated from each identifier, |
62 |
and the maximum ID length is 255 characters. |
63 |
.PP |
64 |
Input is taken from the first named file, or standard input if no |
65 |
files are given. |
66 |
Output is sent to the second named file, or standard output if none. |
67 |
.PP |
68 |
The |
69 |
.I \-h |
70 |
option tells |
71 |
.I rcode_ident |
72 |
not to expect an information header on its input. |
73 |
The |
74 |
.I \-x |
75 |
and |
76 |
.I \-y |
77 |
options give the horizontal and vertical map dimensions, respectively. |
78 |
If these are not specified, then a resolution string must be |
79 |
included on the header, as produced by |
80 |
.I rtrace(1) |
81 |
when both resolutions are specified. |
82 |
.PP |
83 |
The second form applies the |
84 |
.I \-r |
85 |
option to read an indexed id file and produce the original |
86 |
identifiers for each pixel position on the output. |
87 |
The |
88 |
.I \-h |
89 |
and |
90 |
.I \-H |
91 |
options may be used to leave off the header and resolution |
92 |
string, respectively. |
93 |
The |
94 |
.I \-tS |
95 |
option specifies an alternate ID separator instead of the default newline. |
96 |
The |
97 |
.I \-l |
98 |
option tells |
99 |
.I rcode_ident |
100 |
to list identifiers following the header information (if present). |
101 |
The |
102 |
.I \-n |
103 |
option prints identifier table indexes rather than the strings themselves. |
104 |
Indexing starts from 0 for the first table entry. |
105 |
.PP |
106 |
When decoding, the |
107 |
.I \-i |
108 |
option tells |
109 |
.I rcode_ident |
110 |
to produce an identifier for each integer input pair specifying |
111 |
the horizontal and vertical coordinates of a particular pixel, |
112 |
where x is measured from 0 on the left and y from 0 at the bottom |
113 |
in the standard orientation. |
114 |
Note that |
115 |
.I \-i |
116 |
implies that an indexed ID file is explicitly given on the command |
117 |
line, since the pixel coordinates are read from the standard input. |
118 |
If the |
119 |
.I \-u |
120 |
option is also given, output will be flushed after each identifier |
121 |
.SH EXAMPLES |
122 |
To store modifier IDs out of rtrace: |
123 |
.IP "" .2i |
124 |
rtrace -ffa < rays.flt -x 512 -y 400 -om octree | rcode_ident > mods.idx |
125 |
.PP |
126 |
To query specific modifiers using ximage with the 't' command: |
127 |
.IP "" .2i |
128 |
ximage -op render.hdr | rcode_ident -i -r mods.idx |
129 |
.PP |
130 |
To only print out the list of unique identifiers: |
131 |
.IP "" .2i |
132 |
rcode_ident -r -h -H -i -l mods.idx < /dev/null |
133 |
.SH AUTHOR |
134 |
Greg Ward |
135 |
.SH "SEE ALSO" |
136 |
rcalc(1), rcode_depth(1), rcode_norm(1), rcode2bmp(1), |
137 |
rlam(1), rsplit(1), rtpict(1) |
