root/radiance/ray/doc/man/man1/rcode_ident.1
Revision: 1.2
Committed: Tue Jul 23 17:20:20 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.1: +18 -1 lines
Added -l and -n options to rcode_ident
1 .\" RCSid "$Id: rcode_ident.1,v 1.1 2019/07/20 02:07:23 greg Exp $"
2 .TH RCODE_IDENT 1 7/19/2019 RADIANCE
3 .SH NAME
4 rcode_ident - store identifiers in an indexed map and retrieve from same
5 .SH SYNOPSIS
6 .B rcode_ident
7 [
8 .I "-8 | -16 | -24"
9 ][
10 .B \-h
11 ][
12 .B \-tS
13 ][
14 .B "-x xr -y yr"
15 ]
16 [
17 input.txt
18 [output.idx]
19 ]
20 .br
21 .B "rcode_ident -r"
22 [
23 .B \-i
24 ][
25 .B \-u
26 ][
27 .B \-h
28 ][
29 .B \-H
30 ][
31 .B \-l
32 ][
33 .B \-n
34 ][
35 .B \-tS
36 ]
37 [
38 input.idx
39 [output.txt]
40 ]
41 .SH DESCRIPTION
42 .I Rcode_ident
43 Takes a list of ASCII identifiers on the input and encodes them
44 as a 16-bit index to a table appended to the output.
45 This default index size can hold up to 65 thousand unique IDs,
46 which is suitable for most applications.
47 The
48 .I \-8
49 option may be used to specify an 8-bit index, which saves space
50 if 256 or fewer unique identifiers appear on the input.
51 The
52 .I \-24
53 option creates a 24-bit index can record over 16 million
54 unique identifiers.
55 .PP
56 Identifiers are separated by newlines by default, but any single-character
57 separator may be given with the
58 .I \-tS
59 option.
60 Note there is no space between this option and its argument.
61 Leading and trailing white space is eliminated from each identifier,
62 and the maximum ID length is 255 characters.
63 .PP
64 Input is taken from the first named file, or standard input if no
65 files are given.
66 Output is sent to the second named file, or standard output if none.
67 .PP
68 The
69 .I \-h
70 option tells
71 .I rcode_ident
72 not to expect an information header on its input.
73 The
74 .I \-x
75 and
76 .I \-y
77 options give the horizontal and vertical map dimensions, respectively.
78 If these are not specified, then a resolution string must be
79 included on the header, as produced by
80 .I rtrace(1)
81 when both resolutions are specified.
82 .PP
83 The second form applies the
84 .I \-r
85 option to read an indexed id file and produce the original
86 identifiers for each pixel position on the output.
87 The
88 .I \-h
89 and
90 .I \-H
91 options may be used to leave off the header and resolution
92 string, respectively.
93 The
94 .I \-tS
95 option specifies an alternate ID separator instead of the default newline.
96 The
97 .I \-l
98 option tells
99 .I rcode_ident
100 to list identifiers following the header information (if present).
101 The
102 .I \-n
103 option prints identifier table indexes rather than the strings themselves.
104 Indexing starts from 0 for the first table entry.
105 .PP
106 When decoding, the
107 .I \-i
108 option tells
109 .I rcode_ident
110 to produce an identifier for each integer input pair specifying
111 the horizontal and vertical coordinates of a particular pixel,
112 where x is measured from 0 on the left and y from 0 at the bottom
113 in the standard orientation.
114 Note that
115 .I \-i
116 implies that an indexed ID file is explicitly given on the command
117 line, since the pixel coordinates are read from the standard input.
118 If the
119 .I \-u
120 option is also given, output will be flushed after each identifier
121 .SH EXAMPLES
122 To store modifier IDs out of rtrace:
123 .IP "" .2i
124 rtrace -ffa < rays.flt -x 512 -y 400 -om octree | rcode_ident > mods.idx
125 .PP
126 To query specific modifiers using ximage with the 't' command:
127 .IP "" .2i
128 ximage -op render.hdr | rcode_ident -i -r mods.idx
129 .PP
130 To only print out the list of unique identifiers:
131 .IP "" .2i
132 rcode_ident -r -h -H -i -l mods.idx < /dev/null
133 .SH AUTHOR
134 Greg Ward
135 .SH "SEE ALSO"
136 rcalc(1), rcode_depth(1), rcode_norm(1), rlam(1), rsplit(1), rtpict(1)
