root/Development/ray/doc/man/man1/rcode_ident.1
Revision: 1.7
Committed: Wed Aug 24 19:34:07 2022 UTC (3 years, 1 month ago) by greg
CVS Tags: rad6R0, rad5R4, HEAD
Changes since 1.6: +3 -5 lines
docs(rcode_ident): Clarified wording regarding -r option
1 .\" RCSid "$Id: rcode_ident.1,v 1.6 2022/02/02 22:25:24 greg Exp $"
2 .TH RCODE_IDENT 1 7/19/2019 RADIANCE
3 .SH NAME
4 rcode_ident - store identifiers in an indexed map and retrieve from same
5 .SH SYNOPSIS
6 .B rcode_ident
7 [
8 .I "-8 | -16 | -24"
9 ][
10 .B \-h
11 ][
12 .B \-tS
13 ][
14 .B "-x xr -y yr"
15 ]
16 [
17 input.txt
18 [output.idx]
19 ]
20 .br
21 .B "rcode_ident -r"
22 [
23 .B \-i
24 ][
25 .B \-u
26 ][
27 .B \-h
28 ][
29 .B \-H
30 ][
31 .B \-l
32 ][
33 .B \-n
34 ][
35 .B \-tS
36 ]
37 input.idx
38 [output.txt]
39 .SH DESCRIPTION
40 .I Rcode_ident
41 takes a list of ASCII identifiers on the input and encodes them
42 as a 16-bit index to a table appended to the output.
43 This default index size can hold up to 65 thousand unique IDs,
44 which is suitable for most applications.
45 The
46 .I \-8
47 option may be used to specify an 8-bit index, which saves space
48 if 256 or fewer unique identifiers appear on the input.
49 The
50 .I \-24
51 option creates a 24-bit index that can record over 16 million
52 unique identifiers.
53 .PP
54 Identifiers are separated by newlines by default, but any single-character
55 separator may be given with the
56 .I \-tS
57 option.
58 Note there is no space between this option and its argument.
59 Leading and trailing white space is eliminated from each identifier,
60 and the maximum ID length is 255 characters.
61 .PP
62 Input is taken from the first named file, or standard input if no
63 files are given.
64 (Input file is required for
65 .I \-r
66 option.)
67 Output is sent to the second named file, or standard output if none.
68 .PP
69 The
70 .I \-h
71 option tells
72 .I rcode_ident
73 not to expect an information header on its input.
74 The
75 .I \-x
76 and
77 .I \-y
78 options give the horizontal and vertical map dimensions, respectively.
79 If these are not specified, then a resolution string must be
80 included on the header, as produced by
81 .I rtrace(1)
82 when both resolutions are specified.
83 .PP
84 The second form applies the
85 .I \-r
86 option to read an indexed id file and produce the original
87 identifiers for each pixel position on the output.
88 With this option, the ID file must be given on the
89 command line and cannot be read from the standard input.
90 The
91 .I \-h
92 and
93 .I \-H
94 options may be used to leave off the header and resolution
95 string, respectively.
96 The
97 .I \-tS
98 option specifies an alternate ID separator instead of the default newline.
99 The
100 .I \-l
101 option tells
102 .I rcode_ident
103 to list identifiers following the header information (if present).
104 The
105 .I \-n
106 option prints identifier table indexes rather than the strings themselves.
107 Indexing starts from 0 for the first table entry.
108 .PP
109 When decoding, the
110 .I \-i
111 option tells
112 .I rcode_ident
113 to produce an identifier for each integer input pair specifying
114 the horizontal and vertical coordinates of a particular pixel,
115 where x is measured from 0 on the left and y from 0 at the bottom
116 in the standard orientation.
117 If the
118 .I \-u
119 option is also given, output will be flushed after each identifier
120 .SH EXAMPLES
121 To store modifier IDs out of rtrace:
122 .IP "" .2i
123 rtrace -ffa < rays.flt -x 512 -y 400 -om octree | rcode_ident > mods.idx
124 .PP
125 To query specific modifiers using ximage with the 't' command:
126 .IP "" .2i
127 ximage -op render.hdr | rcode_ident -i -r mods.idx
128 .PP
129 To only print out the list of unique identifiers:
130 .IP "" .2i
131 rcode_ident -r -h -H -i -l mods.idx < /dev/null
132 .SH AUTHOR
133 Greg Ward
134 .SH "SEE ALSO"
135 rcalc(1), rcode_depth(1), rcode_norm(1), rcode2bmp(1),
136 rlam(1), rsplit(1), rtpict(1)
