root/Development/ray/doc/man/man1/rcode_ident.1
Revision: 1.6
Committed: Wed Feb 2 22:25:24 2022 UTC (3 years, 7 months ago) by greg
docs(rcode_ident): corrected information about file requirements for -r option
1 .\" RCSid "$Id: rcode_ident.1,v 1.5 2021/04/28 19:15:09 greg Exp $"
2 .TH RCODE_IDENT 1 7/19/2019 RADIANCE
3 .SH NAME
4 rcode_ident - store identifiers in an indexed map and retrieve from same
5 .SH SYNOPSIS
6 .B rcode_ident
7 [
8 .I "-8 | -16 | -24"
9 ][
10 .B \-h
11 ][
12 .B \-tS
13 ][
14 .B "-x xr -y yr"
15 ]
16 [
17 input.txt
18 [output.idx]
19 ]
20 .br
21 .B "rcode_ident -r"
22 [
23 .B \-i
24 ][
25 .B \-u
26 ][
27 .B \-h
28 ][
29 .B \-H
30 ][
31 .B \-l
32 ][
33 .B \-n
34 ][
35 .B \-tS
36 ]
37 input.idx
38 [output.txt]
39 .SH DESCRIPTION
40 .I Rcode_ident
41 takes a list of ASCII identifiers on the input and encodes them
42 as a 16-bit index to a table appended to the output.
43 This default index size can hold up to 65 thousand unique IDs,
44 which is suitable for most applications.
45 The
46 .I \-8
47 option may be used to specify an 8-bit index, which saves space
48 if 256 or fewer unique identifiers appear on the input.
49 The
50 .I \-24
51 option creates a 24-bit index that can record over 16 million
52 unique identifiers.
53 .PP
54 Identifiers are separated by newlines by default, but any single-character
55 separator may be given with the
56 .I \-tS
57 option.
58 Note there is no space between this option and its argument.
59 Leading and trailing white space is eliminated from each identifier,
60 and the maximum ID length is 255 characters.
61 .PP
62 Input is taken from the first named file, or standard input if no
63 files are given.
64 (Input file is required for
65 .I \-r
66 option.)
67 Output is sent to the second named file, or standard output if none.
68 .PP
69 The
70 .I \-h
71 option tells
72 .I rcode_ident
73 not to expect an information header on its input.
74 The
75 .I \-x
76 and
77 .I \-y
78 options give the horizontal and vertical map dimensions, respectively.
79 If these are not specified, then a resolution string must be
80 included on the header, as produced by
81 .I rtrace(1)
82 when both resolutions are specified.
83 .PP
84 The second form applies the
85 .I \-r
86 option to read an indexed id file and produce the original
87 identifiers for each pixel position on the output.
88 The
89 .I \-h
90 and
91 .I \-H
92 options may be used to leave off the header and resolution
93 string, respectively.
94 The
95 .I \-tS
96 option specifies an alternate ID separator instead of the default newline.
97 The
98 .I \-l
99 option tells
100 .I rcode_ident
101 to list identifiers following the header information (if present).
102 The
103 .I \-n
104 option prints identifier table indexes rather than the strings themselves.
105 Indexing starts from 0 for the first table entry.
106 .PP
107 When decoding, the
108 .I \-i
109 option tells
110 .I rcode_ident
111 to produce an identifier for each integer input pair specifying
112 the horizontal and vertical coordinates of a particular pixel,
113 where x is measured from 0 on the left and y from 0 at the bottom
114 in the standard orientation.
115 Note that
116 .I \-i
117 implies that an indexed ID file is explicitly given on the command
118 line, since the pixel coordinates are read from the standard input.
119 If the
120 .I \-u
121 option is also given, output will be flushed after each identifier
122 .SH EXAMPLES
123 To store modifier IDs out of rtrace:
124 .IP "" .2i
125 rtrace -ffa < rays.flt -x 512 -y 400 -om octree | rcode_ident > mods.idx
126 .PP
127 To query specific modifiers using ximage with the 't' command:
128 .IP "" .2i
129 ximage -op render.hdr | rcode_ident -i -r mods.idx
130 .PP
131 To only print out the list of unique identifiers:
132 .IP "" .2i
133 rcode_ident -r -h -H -i -l mods.idx < /dev/null
134 .SH AUTHOR
135 Greg Ward
136 .SH "SEE ALSO"
137 rcalc(1), rcode_depth(1), rcode_norm(1), rcode2bmp(1),
138 rlam(1), rsplit(1), rtpict(1)
