root/radiance/ray/doc/man/man1/rcode_depth.1
Revision: 1.6
Committed: Wed Jun 4 20:32:24 2025 UTC (3 days, 13 hours ago) by greg
feat(rxpiece): Added rxpiece to standard distribution
# User Rev Content
1 greg 1.6 .\" RCSid "$Id: rcode_depth.1,v 1.5 2022/03/15 04:41:45 greg Exp $"
2 greg 1.1 .TH RCODE_DEPTH 1 7/19/2019 RADIANCE
3     .SH NAME
4     rcode_depth - encode/decode 16-bit depth map
5     .SH SYNOPSIS
6     .B rcode_depth
7     [
8     .B "-d ref_depth/unit"
9     ][
10     .B \-h[io]
11     ][
12     .B \-H[io]
13     ][
14     .B \-f[afd]
15 greg 1.3 ][
16     .B "-x xr -y yr"
17 greg 1.1 ]
18     [
19     input
20     [output.dpt]
21     ]
22     .br
23     .B rcode_depth
24     {
25     .B \-r
26     |
27     .B \-p
28     }
29     [
30     .B \-i
31     ][
32     .B \-u
33     ][
34     .B \-h[io]
35     ][
36     .B \-H[io]
37     ][
38     .B \-f[afd]
39     ]
40     [
41     input.dpt
42     [output]
43     ]
44     .SH DESCRIPTION
45     .I Rcode_depth
46     reads a map of depth values from 0 to infinity
47     and encodes them in an efficient 16-bit/pixel format for storage.
48     Input is taken from the first named file, or standard input if no
49     files are given.
50     Output is sent to the second named file, or standard output if none.
51     .PP
52     The
53     .I \-d
54     option specifies a reference distance with an optional unit
55     after a slash separator ('/').
56     (E.g., "1/meter" for diopters.)\0
57     This distance should roughly correspond to the average
58     depths on the input, as it sets the threshold between a linear
59     near-field and a reciprocal far-field range.
60     The default value is 1.0, with no specified units.
61     .PP
62     The
63     .I \-hi
64     option tells
65     .I rcode_depth
66     not to expect an information header on its input.
67     The
68     .I \-ho
69     option tells
70     .I rcode_depth
71     not to produce an information header on its output.
72     Specifying
73     .I \-h
74     turns both input and output headers off.
75     Similarly, the
76     .I \-Hi
77     option says not to expect an image resolution string on input, the
78     .I \-Ho
79     option says not to produce one on output, and
80     .I \-H
81     applies both.
82 greg 1.3 The
83     .I \-x
84     and
85     .I \-y
86     options give the horizontal and vertical map dimensions, respectively.
87     If provided, then an input resolution string will not be expected.
88 greg 1.1 .PP
89     The default input format is ASCII (user-readable) real values,
90     corresponding to the
91     .I \-fa
92     option.
93     The
94     .I \-ff
95     option tells
96     .I rcode_depth
97     to expect binary, 32-bit floating-point values per
98     depth on its input, instead.
99     The
100     .I \-fd
101     option tells it to expect 64-bit/pixel binary input.
102     .PP
103     The second form applies either the
104     .I \-r
105     option to decode from 16-bit depths to the desired format, or the
106     .I \-p
107     option to compute world intersection points from
108     view parameters in the encoded depth file header.
109     The output format is specified with the
110     .I \-f
111     option as described above.
112     The
113     .I \-h
114     and
115     .I \-H
116     options have the same behavior as before.
117     .PP
118     When decoding, the
119     .I \-i
120     option further tells
121     .I rcode_depth
122     to produce one depth or world point
123     for each integer input pair specifying
124     the horizontal and vertical coordinates of a particular pixel,
125     where x is measured from 0 on the left and y from 0 at the bottom
126     in the standard orientation.
127     Note that
128     .I \-i
129 greg 1.4 requires that an encoded depth file name be given on the command
130 greg 1.1 line, since the pixel coordinates are read from the standard input.
131     Also, the
132     .I \-H
133     option is not supported with
134     .I \-i,
135     since the map dimensions are required on the
136     input and not copied to the output.
137     If the
138     .I \-u
139     option is also given, output will be flushed after each coordinate pair.
140     .SH EXAMPLES
141     To store first surface intersection distances out of rtrace:
142     .IP "" .2i
143     rtrace -ff < rays.flt -x 512 -y 400 -oL octree | rcode_depth -ff > first.dpt
144     .PP
145     To query world intersection points using ximage with the 't' command:
146     .IP "" .2i
147     ximage -op render.hdr | rcode_depth -i -p first.dpt
148     .SH AUTHOR
149     Greg Ward
150     .SH "SEE ALSO"
151 greg 1.2 rcalc(1), rcode_ident(1), rcode_norm(1), rcode2bmp(1),
152 greg 1.6 rcrop(1), rlam(1), rsplit(1), rtpict(1), rxpiece(1)
