root/radiance/ray/doc/man/man1/rcode_depth.1
Revision: 1.6
Committed: Wed Jun 4 20:32:24 2025 UTC (2 weeks ago) by greg
feat(rxpiece): Added rxpiece to standard distribution
1 .\" RCSid "$Id: rcode_depth.1,v 1.5 2022/03/15 04:41:45 greg Exp $"
2 .TH RCODE_DEPTH 1 7/19/2019 RADIANCE
3 .SH NAME
4 rcode_depth - encode/decode 16-bit depth map
5 .SH SYNOPSIS
6 .B rcode_depth
7 [
8 .B "-d ref_depth/unit"
9 ][
10 .B \-h[io]
11 ][
12 .B \-H[io]
13 ][
14 .B \-f[afd]
15 ][
16 .B "-x xr -y yr"
17 ]
18 [
19 input
20 [output.dpt]
21 ]
22 .br
23 .B rcode_depth
24 {
25 .B \-r
26 |
27 .B \-p
28 }
29 [
30 .B \-i
31 ][
32 .B \-u
33 ][
34 .B \-h[io]
35 ][
36 .B \-H[io]
37 ][
38 .B \-f[afd]
39 ]
40 [
41 input.dpt
42 [output]
43 ]
44 .SH DESCRIPTION
45 .I Rcode_depth
46 reads a map of depth values from 0 to infinity
47 and encodes them in an efficient 16-bit/pixel format for storage.
48 Input is taken from the first named file, or standard input if no
49 files are given.
50 Output is sent to the second named file, or standard output if none.
51 .PP
52 The
53 .I \-d
54 option specifies a reference distance with an optional unit
55 after a slash separator ('/').
56 (E.g., "1/meter" for diopters.)\0
57 This distance should roughly correspond to the average
58 depths on the input, as it sets the threshold between a linear
59 near-field and a reciprocal far-field range.
60 The default value is 1.0, with no specified units.
61 .PP
62 The
63 .I \-hi
64 option tells
65 .I rcode_depth
66 not to expect an information header on its input.
67 The
68 .I \-ho
69 option tells
70 .I rcode_depth
71 not to produce an information header on its output.
72 Specifying
73 .I \-h
74 turns both input and output headers off.
75 Similarly, the
76 .I \-Hi
77 option says not to expect an image resolution string on input, the
78 .I \-Ho
79 option says not to produce one on output, and
80 .I \-H
81 applies both.
82 The
83 .I \-x
84 and
85 .I \-y
86 options give the horizontal and vertical map dimensions, respectively.
87 If provided, then an input resolution string will not be expected.
88 .PP
89 The default input format is ASCII (user-readable) real values,
90 corresponding to the
91 .I \-fa
92 option.
93 The
94 .I \-ff
95 option tells
96 .I rcode_depth
97 to expect binary, 32-bit floating-point values per
98 depth on its input, instead.
99 The
100 .I \-fd
101 option tells it to expect 64-bit/pixel binary input.
102 .PP
103 The second form applies either the
104 .I \-r
105 option to decode from 16-bit depths to the desired format, or the
106 .I \-p
107 option to compute world intersection points from
108 view parameters in the encoded depth file header.
109 The output format is specified with the
110 .I \-f
111 option as described above.
112 The
113 .I \-h
114 and
115 .I \-H
116 options have the same behavior as before.
117 .PP
118 When decoding, the
119 .I \-i
120 option further tells
121 .I rcode_depth
122 to produce one depth or world point
123 for each integer input pair specifying
124 the horizontal and vertical coordinates of a particular pixel,
125 where x is measured from 0 on the left and y from 0 at the bottom
126 in the standard orientation.
127 Note that
128 .I \-i
129 requires that an encoded depth file name be given on the command
130 line, since the pixel coordinates are read from the standard input.
131 Also, the
132 .I \-H
133 option is not supported with
134 .I \-i,
135 since the map dimensions are required on the
136 input and not copied to the output.
137 If the
138 .I \-u
139 option is also given, output will be flushed after each coordinate pair.
140 .SH EXAMPLES
141 To store first surface intersection distances out of rtrace:
142 .IP "" .2i
143 rtrace -ff < rays.flt -x 512 -y 400 -oL octree | rcode_depth -ff > first.dpt
144 .PP
145 To query world intersection points using ximage with the 't' command:
146 .IP "" .2i
147 ximage -op render.hdr | rcode_depth -i -p first.dpt
148 .SH AUTHOR
149 Greg Ward
150 .SH "SEE ALSO"
151 rcalc(1), rcode_ident(1), rcode_norm(1), rcode2bmp(1),
152 rcrop(1), rlam(1), rsplit(1), rtpict(1), rxpiece(1)
