root/Development/ray/doc/man/man1/rcode_depth.1
Revision: 1.1
Committed: Sat Jul 20 02:07:23 2019 UTC (6 years, 4 months ago) by greg
Created man pages for rcode_depth, rcode_ident, and rcode_norm
1 .\" RCSid "$Id: rcollate.1,v 1.7 2014/05/31 21:33:21 greg Exp $"
2 .TH RCODE_DEPTH 1 7/19/2019 RADIANCE
3 .SH NAME
4 rcode_depth - encode/decode 16-bit depth map
5 .SH SYNOPSIS
6 .B rcode_depth
7 [
8 .B "-d ref_depth/unit"
9 ][
10 .B \-h[io]
11 ][
12 .B \-H[io]
13 ][
14 .B \-f[afd]
15 ]
16 [
17 input
18 [output.dpt]
19 ]
20 .br
21 .B rcode_depth
22 {
23 .B \-r
24 |
25 .B \-p
26 }
27 [
28 .B \-i
29 ][
30 .B \-u
31 ][
32 .B \-h[io]
33 ][
34 .B \-H[io]
35 ][
36 .B \-f[afd]
37 ]
38 [
39 input.dpt
40 [output]
41 ]
42 .SH DESCRIPTION
43 .I Rcode_depth
44 reads a map of depth values from 0 to infinity
45 and encodes them in an efficient 16-bit/pixel format for storage.
46 Input is taken from the first named file, or standard input if no
47 files are given.
48 Output is sent to the second named file, or standard output if none.
49 .PP
50 The
51 .I \-d
52 option specifies a reference distance with an optional unit
53 after a slash separator ('/').
54 (E.g., "1/meter" for diopters.)\0
55 This distance should roughly correspond to the average
56 depths on the input, as it sets the threshold between a linear
57 near-field and a reciprocal far-field range.
58 The default value is 1.0, with no specified units.
59 .PP
60 The
61 .I \-hi
62 option tells
63 .I rcode_depth
64 not to expect an information header on its input.
65 The
66 .I \-ho
67 option tells
68 .I rcode_depth
69 not to produce an information header on its output.
70 Specifying
71 .I \-h
72 turns both input and output headers off.
73 Similarly, the
74 .I \-Hi
75 option says not to expect an image resolution string on input, the
76 .I \-Ho
77 option says not to produce one on output, and
78 .I \-H
79 applies both.
80 .PP
81 The default input format is ASCII (user-readable) real values,
82 corresponding to the
83 .I \-fa
84 option.
85 The
86 .I \-ff
87 option tells
88 .I rcode_depth
89 to expect binary, 32-bit floating-point values per
90 depth on its input, instead.
91 The
92 .I \-fd
93 option tells it to expect 64-bit/pixel binary input.
94 .PP
95 The second form applies either the
96 .I \-r
97 option to decode from 16-bit depths to the desired format, or the
98 .I \-p
99 option to compute world intersection points from
100 view parameters in the encoded depth file header.
101 The output format is specified with the
102 .I \-f
103 option as described above.
104 The
105 .I \-h
106 and
107 .I \-H
108 options have the same behavior as before.
109 .PP
110 When decoding, the
111 .I \-i
112 option further tells
113 .I rcode_depth
114 to produce one depth or world point
115 for each integer input pair specifying
116 the horizontal and vertical coordinates of a particular pixel,
117 where x is measured from 0 on the left and y from 0 at the bottom
118 in the standard orientation.
119 Note that
120 .I \-i
121 implies that an encoded normal file is explicitly given on the command
122 line, since the pixel coordinates are read from the standard input.
123 Also, the
124 .I \-H
125 option is not supported with
126 .I \-i,
127 since the map dimensions are required on the
128 input and not copied to the output.
129 If the
130 .I \-u
131 option is also given, output will be flushed after each coordinate pair.
132 .SH EXAMPLES
133 To store first surface intersection distances out of rtrace:
134 .IP "" .2i
135 rtrace -ff < rays.flt -x 512 -y 400 -oL octree | rcode_depth -ff > first.dpt
136 .PP
137 To query world intersection points using ximage with the 't' command:
138 .IP "" .2i
139 ximage -op render.hdr | rcode_depth -i -p first.dpt
140 .SH AUTHOR
141 Greg Ward
142 .SH "SEE ALSO"
143 rcalc(1), rcode_ident(1), rcode_norm(1), rlam(1), rsplit(1), rtpict(1)
