root/radiance/ray/doc/man/man1/rcalc.1
Sun Mar 13 16:11:48 2022 UTC (3 years, 3 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 1.16: +12 -1 lines
Diff to previous 1.16
feat(rcalc): Added warning and embedded message when buffer overflows with -P
Fri Mar 11 22:50:13 2022 UTC (3 years, 3 months ago) by greg
Changes since 1.15: +18 -8 lines
Diff to previous 1.15
feat(rcalc): Added -P option to pass records where cond evaluates <= 0
Sat Jul 20 00:57:43 2019 UTC (5 years, 10 months ago) by greg
Changes since 1.14: +4 -3 lines
Diff to previous 1.14
Added mention of rsplit(1)
Mon Jun 10 13:56:52 2019 UTC (6 years ago) by greg
Changes since 1.13: +7 -1 lines
Diff to previous 1.13
Tue Oct 10 16:10:14 2017 UTC (7 years, 8 months ago) by greg
Diff to previous 1.12
Minor formatting fixes
Thu Mar 24 18:48:28 2016 UTC (9 years, 2 months ago) by greg
Changes since 1.11: +21 -1 lines
Diff to previous 1.11
Added -in options to commands for manual EOF specification
Thu Dec 19 16:38:12 2013 UTC (11 years, 5 months ago) by greg
Diff to previous 1.10
Thu Sep 5 17:53:22 2013 UTC (11 years, 9 months ago) by greg
Diff to previous 1.9
Fri Feb 3 17:55:16 2012 UTC (13 years, 4 months ago) by greg
Changes since 1.8: +8 -2 lines
Diff to previous 1.8
Minor corrections and additions
Tue Sep 4 17:36:41 2007 UTC (17 years, 9 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Diff to previous 1.7
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Sat Dec 23 17:27:45 2006 UTC (18 years, 5 months ago) by greg
Changes since 1.6: +11 -1 lines
Diff to previous 1.6
Wed Jun 9 16:00:12 2004 UTC (21 years ago) by greg
Changes since 1.5: +16 -1 lines
Diff to previous 1.5
Thu Jan 1 19:31:45 2004 UTC (21 years, 5 months ago) by greg
Diff to previous 1.4
Tue Dec 9 15:59:06 2003 UTC (21 years, 6 months ago) by greg
Diff to previous 1.3
Fixed RCSid specification
Thu Nov 6 05:39:32 2003 UTC (21 years, 7 months ago) by greg
Changes since 1.2: +10 -0 lines
Diff to previous 1.2
Sun Apr 27 06:08:03 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.1: +19 -2 lines
Tue Mar 11 19:20:21 2003 UTC (22 years, 3 months ago) by greg
Added documentation to repository
