root/Development/ray/doc/man/man1/rcalc.1
Revision: 1.17
Committed: Sun Mar 13 16:11:48 2022 UTC (3 years, 9 months ago) by greg
CVS Tags: rad6R0, rad5R4, HEAD
Changes since 1.16: +12 -1 lines
feat(rcalc): Added warning and embedded message when buffer overflows with -P
1 .\" RCSid "$Id: rcalc.1,v 1.16 2022/03/11 22:50:13 greg Exp $"
2 .TH RCALC 1 4/6/99 RADIANCE
3 .SH NAME
4 rcalc - record calculator
5 .SH SYNOPSIS
6 .B rcalc
7 [
8 .B \-b
9 ][
10 .B \-l
11 ][
12 .B "\-p | \-P"
13 ][
14 .B \-n
15 ][
16 .B \-w
17 ][
18 .B \-u
19 ][
20 .B \-tS
21 ][
22 .B "\-i format"
23 ][
24 .B "\-o format"
25 ][
26 .B "\-in M"
27 ][
28 .B "\-on M"
29 ][
30 .B "\-f source"
31 ][
32 .B "\-e expr"
33 ][
34 .B "\-s svar=sval"
35 ]
36 file ..
37 .SH DESCRIPTION
38 .I Rcalc
39 transforms ``records'' from each
40 .I file
41 according to the given set of literal and relational information.
42 By default, records are separated by newlines, and contain
43 numeric fields separated by tabs.
44 The
45 .I \-tS
46 option is used to specify an alternate tab character.
47 .PP
48 A
49 .I \-i format
50 option specifies a template for an alternate
51 input record format.
52 .I Format
53 is interpreted as a specification string if it contains a dollar sign '$'.
54 Otherwise, it is interpreted as the name of the file containing
55 the format specification.
56 In either case, if the format does not end with a newline, one will be added
57 automatically.
58 A special form of the
59 .I \-i
60 option may be followed immediately by a 'd' or an 'f' and an optional
61 count, which defaults to 1, indicating the number of double or float
62 binary values to read per record on the input file.
63 If the input is byte-swapped, the
64 .I \-iD
65 or
66 .I \-iF
67 options may be substituted.
68 If binary input is specified, no format string or file is needed.
69 .PP
70 A
71 .I \-o format
72 option specifies an alternate output record format.
73 It is interpreted the same as an input specification, except that
74 the special
75 .I \-od
76 or
77 .I \-of
78 options do not require a count, as this will be determined by the
79 number of output channels in the given expressions.
80 If byte-swapped output is desired, the
81 .I \-oD
82 or
83 .I \-oF
84 options may be substituted.
85 .PP
86 The
87 .I \-p
88 option specifies "passive mode," where characters that do not
89 match the input format are passed unaltered to the output.
90 If the
91 .I \-P
92 option is given instead, then valid input records that do not
93 yield a positive
94 .I cond
95 value are similarly passed to the output.
96 (See paragraph below.)\0
97 These options options require that the
98 .I \-i
99 input format and
100 .I \-o
101 output format also be present.
102 With both input and output formats, the passive mode can
103 effectively substitute information in the middle of a file
104 or stream without affecting the rest of the data.
105 .PP
106 If a
107 .I \-in
108 option is given with a positive integer argument,
109 .I rcalc
110 will stop processing input once it has loaded this number of records.
111 Similarly, if a
112 .I \-on
113 option is present,
114 .I rcalc
115 will stop after producing this many records, which may be a smaller
116 number if the
117 .I cond
118 variable is used.
119 If multiple input files are given, these counts are continuous over
120 the input and do not reset on each file.
121 .PP
122 The variable and function definitions in each
123 .I \-f source
124 file are read and compiled from the RADIANCE library where it is found.
125 The
126 .I \-e expr
127 option can be used to define variables on the command line.
128 Since many of the characters in an expression have special meaning
129 to the shell, it should usually be enclosed in single quotes.
130 The
131 .I \-s svar=sval
132 option can be used to assign a string variable a string value.
133 If this string variable appears in an input format, only records
134 with the specified value will be processed.
135 .PP
136 The
137 .I \-b
138 option instructs the program to accept only exact matches.
139 By default, tabs and spaces are ignored except
140 as field separators.
141 The
142 .I \-l
143 option instructs the program to ignore newlines in the input,
144 basically treating them the same as tabs and spaces.
145 Normally, the beginning of the input format matches the beginning of
146 a line, and the end of the format matches the end of a line.
147 With the
148 .I \-l
149 option, the input format can match anywhere on a line.
150 .PP
151 The
152 .I \-w
153 option causes non-fatal error messages (such as division by zero) to
154 be supressed.
155 The
156 .I \-u
157 option causes output to be flushed after each record.
158 The
159 .I \-n
160 option tells the program not to get any input, but to produce a
161 single output record.
162 Otherwise, if no files are given, the standard input is read.
163 .PP
164 Format files associate names with string and numeric fields
165 separated by literal information in a record.
166 A numeric field is given in a format file as a dollar sign, followed
167 by curly braces enclosing a variable name:
168 .PP
169 This is a numeric field: ${vname}
170 .PP
171 A string variable is enclosed in parentheses:
172 .PP
173 This is a string field: $(sname)
174 .PP
175 The program attempts to match literal information in
176 the input format to its input and assign string and numeric
177 fields accordingly.
178 If a string or numeric field variable appears more than once in
179 the input format, input values for the corresponding fields must
180 match (ie. have the same value) for the whole record to match.
181 Numeric values are allowed some deviation, on the order of 0.1%, but
182 string variables must match exactly.
183 Thus, dummy variables for "don't care" fields should be given unique
184 names so that they are not all required to take on the same value.
185 .PP
186 For each valid input record, an output record is produced
187 in its corresponding format.
188 Output field widths are given implicitly by the space occupied
189 in the format file, including the dollar sign and braces.
190 This makes it impossible to produce fields with fewer than four
191 characters.
192 If the
193 .I \-b
194 option is specified, input records must exactly match the
195 template.
196 By default, the character following each input field is used as
197 a delimiter.
198 This implies that string fields that are followed by white space
199 cannot contain strings with white space.
200 Also, numeric fields followed but not preceded by white space
201 will not accept numbers preceded by white space.
202 Adjacent input fields are advisable only with the
203 .I \-b
204 option.
205 Numeric output fields may contain expressions as well as variables.
206 A dollar sign may appear in a literal as two dollar signs ($$).
207 .PP
208 The definitions specified in
209 .I \-e
210 and
211 .I \-f
212 options relate numeric output fields to numeric input fields.
213 For the default record format, a field is a variable of the form
214 $N, where N is the column number, beginning with 1.
215 Output columns appear on the left-hand side of assignments, input
216 columns appear on the right-hand side.
217 .PP
218 A variable definition has the form:
219 .PP
220
221 var = expression ;
222
223 .PP
224 Any instance of the variable in an expression will be replaced
225 with its definition.
226 .PP
227 An expression contains real numbers, variable names, function calls,
228 and the following operators:
229 .PP
230 + - * / ^
231 .PP
232 Operators are evaluated left to right, except '^',
233 which is right associative.
234 Powers have the highest precedence; multiplication and
235 division are evaluated before addition and subtraction.
236 Expressions can be grouped with parentheses.
237 All values are double precision real.
238 .PP
239 A function definition has the form:
240 .PP
241
242 func(a1, a2, ..) = expression ;
243
244 .PP
245 The expression can contain instances of the function arguments
246 as well as other variables and functions.
247 Function names can be passed as arguments.
248 Recursive functions can be defined using calls to the defined
249 function or other functions calling the defined function.
250 .PP
251 The variable
252 .I cond,
253 if defined, will determine whether the current input record produces
254 an output record.
255 If
256 .I cond
257 is positive, output is produced.
258 If
259 .I cond
260 is less than or equal to zero, the record is skipped (or passed to the
261 output if
262 .I \-P
263 is specified) and no other expressions
264 are evaluated.
265 This provides a convenient method for avoiding inappropriate calculations.
266 The following library of pre-defined functions and variables is provided:
267 .TP 10n
268 .BR $N
269 Return the value for input column
270 .I N.
271 If an input format is given, using a channel number generates an error.
272 .TP
273 .BR "in(n)"
274 Return the value for input column
275 .I n,
276 or the number of columns available in this record if
277 .I n
278 is 0.
279 This is an alternate way to get a column value instead of using
280 the $N notation, and is more flexible since it is programmable.
281 This function is disabled if an input format is used.
282 .TP
283 .BR "if(test, then, else)"
284 if test is greater than zero,
285 then is evaluated, otherwise else is evaluated.
286 This function is necessary for recursive definitions.
287 .TP
288 .BR "select(N, a1, a2, ..)"
289 return aN (N is rounded to the nearest integer).
290 This function provides array capabilities.
291 If
292 .I N
293 is zero, the number of available arguments is returned.
294 .TP
295 .BR "rand(x)"
296 compute a random number between 0 and 1 based on x.
297 .TP
298 .BR "min(a1, a2, ..)"
299 return the minimum value from a list of arguments.
300 .TP
301 .BR "max(a1, a2, ..)"
302 return the maximum value from a list of arguments.
303 .TP
304 .BR "floor(x)"
305 return largest integer not greater than x.
306 .TP
307 .BR "ceil(x)"
308 return smallest integer not less than x.
309 .TP
310 .BR "sqrt(x)"
311 return square root of x.
312 .TP
313 .BR "exp(x)"
314 compute e to the power of x (e approx = 2.718281828).
315 .TP
316 .BR "log(x)"
317 compute the logarithm of x to the base e.
318 .TP
319 .BR "log10(x)"
320 compute the logarithm of x to the base 10.
321 .TP
322 .BR PI
323 the ratio of a circle's circumference to its diameter.
324 .TP
325 .BR recno
326 the number of records recognized thus far.
327 .TP
328 .BR outno
329 the number or records output thus far (including this one).
330 .TP
331 .BR "sin(x), cos(x), tan(x)"
332 trigonometric functions.
333 .TP
334 .BR "asin(x), acos(x), atan(x)"
335 inverse trigonometric functions.
336 .TP
337 .BR "atan2(y, x)"
338 inverse tangent of y/x (range \-pi to pi).
339 .SH EXAMPLE
340 To print the square root of column two in column one,
341 and column one times column three in column two:
342 .IP "" .2i
343 rcalc -e '$1=sqrt($2);$2=$1*$3' inputfile > outputfile
344 .SH ENVIRONMENT
345 RAYPATH the directories to check for auxiliary files.
346 .SH AUTHOR
347 Greg Ward
348 .SH BUGS
349 String variables can only be used in input and output formats and
350 .I \-s
351 options, not in definitions.
352 .PP
353 Tabs count as single spaces inside fields.
354 .PP
355 The
356 .I \-P
357 option buffers up to 16 Kbytes of data per record.
358 Longer records passed because the "cond" variable
359 evaluates to <= 0 will be partial; a warning will
360 be generated and the string "*** MISSING DATA ***"
361 will appear at the break.
362 The only workaround is to use the
363 .I \-p
364 option instead, which does not pass rejected records.
365 .SH "SEE ALSO"
366 cnt(1), ev(1), getinfo(1), icalc(1), rcollate(1), rlam(1),
367 rsplit(1), tabfunc(1), total(1)
