root/radiance/ray/doc/man/man1/rcalc.1
Revision: 1.6
Committed: Wed Jun 9 16:00:12 2004 UTC (19 years, 10 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
Changes since 1.5: +16 -1 lines
1 .\" RCSid "$Id: rcalc.1,v 1.5 2004/01/01 19:31:45 greg Exp $"
2 .TH RCALC 1 4/6/99 RADIANCE
3 .SH NAME
4 rcalc - record calculator
5 .SH SYNOPSIS
6 .B rcalc
7 [
8 .B \-b
9 ][
10 .B \-l
11 ][
12 .B \-p
13 ][
14 .B \-n
15 ][
16 .B \-w
17 ][
18 .B \-u
19 ][
20 .B \-tS
21 ][
22 .B "\-i format"
23 ][
24 .B "\-o format"
25 ][
26 .B "\-f source"
27 ][
28 .B "\-e expr"
29 ][
30 .B "\-s svar=sval"
31 ]
32 file ..
33 .SH DESCRIPTION
34 .I Rcalc
35 transforms ``records'' from each
36 .I file
37 according to the given set of literal and relational information.
38 By default, records are separated by newlines, and contain
39 numeric fields separated by tabs.
40 The
41 .I \-tS
42 option is used to specify an alternate tab character.
43 .PP
44 A
45 .I \-i format
46 option specifies a template for an alternate
47 input record format.
48 .I Format
49 is interpreted as a specification string if it contains a dollar sign '$'.
50 Otherwise, it is interpreted as the name of the file containing
51 the format specification.
52 In either case, if the format does not end with a newline, one will be added
53 automatically.
54 A special form of the
55 .I \-i
56 option may be followed immediately by a 'd' or an 'f' and an optional
57 count, which defaults to 1, indicating the number of double or float
58 binary values to read per record on the input file.
59 If binary input is specified, no format string or file is needed.
60 .PP
61 A
62 .I \-o format
63 option specifies an alternate output record format.
64 It is interpreted the same as an input specification, except that
65 the special
66 .I \-od
67 or
68 .I \-of
69 options do not require a count, as this will be determined by the
70 number of output channels in the given expressions.
71 .PP
72 The
73 .I \-p
74 option specifies "passive mode," where characters that do not
75 match the input format are passed unaltered to the output.
76 This option has no effect unless
77 .I \-i
78 is also specified, and does not make much sense unless
79 .I \-o
80 is also given.
81 With both input and output formats, the passive mode can
82 effectively substitute information in the middle of a file
83 or stream without affecting the rest of the data.
84 .PP
85 The variable and function definitions in each
86 .I \-f source
87 file are read and compiled.
88 The
89 .I \-e expr
90 option can be used to define variables on the command line.
91 Since many of the characters in an expression have special meaning
92 to the shell, it should usually be enclosed in single quotes.
93 The
94 .I \-s svar=sval
95 option can be used to assign a string variable a string value.
96 If this string variable appears in an input format, only records
97 with the specified value will be processed.
98 .PP
99 The
100 .I \-b
101 option instructs the program to accept only exact matches.
102 By default, tabs and spaces are ignored except
103 as field separators.
104 The
105 .I \-l
106 option instructs the program to ignore newlines in the input,
107 basically treating them the same as tabs and spaces.
108 Normally, the beginning of the input format matches the beginning of
109 a line, and the end of the format matches the end of a line.
110 With the
111 .I \-l
112 option, the input format can match anywhere on a line.
113 .PP
114 The
115 .I \-w
116 option causes non-fatal error messages (such as division by zero) to
117 be supressed.
118 The
119 .I \-u
120 option causes output to be flushed after each record.
121 The
122 .I \-n
123 option tells the program not to get any input, but to produce a
124 single output record.
125 Otherwise, if no files are given, the standard input is read.
126 .PP
127 Format files associate names with string and numeric fields
128 separated by literal information in a record.
129 A numeric field is given in a format file as a dollar sign, followed
130 by curly braces enclosing a variable name:
131 .PP
132 This is a numeric field: ${vname}
133 .PP
134 A string variable is enclosed in parentheses:
135 .PP
136 This is a string field: $(sname)
137 .PP
138 The program attempts to match literal information in
139 the input format to its input and assign string and numeric
140 fields accordingly.
141 If a string or numeric field variable appears more than once in
142 the input format, input values for the corresponding fields must
143 match (ie. have the same value) for the whole record to match.
144 Numeric values are allowed some deviation, on the order of 0.1%, but
145 string variables must match exactly.
146 Thus, dummy variables for "don't care" fields should be given unique
147 names so that they are not all required to take on the same value.
148 .PP
149 For each valid input record, an output record is produced
150 in its corresponding format.
151 Output field widths are given implicitly by the space occupied
152 in the format file, including the dollar sign and braces.
153 This makes it impossible to produce fields with fewer than four
154 characters.
155 If the
156 .I \-b
157 option is specified, input records must exactly match the
158 template.
159 By default, the character following each input field is used as
160 a delimiter.
161 This implies that string fields that are followed by white space
162 cannot contain strings with white space.
163 Also, numeric fields followed but not preceded by white space
164 will not accept numbers preceded by white space.
165 Adjacent input fields are advisable only with the
166 .I \-b
167 option.
168 Numeric output fields may contain expressions as well as variables.
169 A dollar sign may appear in a literal as two dollar signs ($$).
170 .PP
171 The definitions specified in
172 .I \-e
173 and
174 .I \-f
175 options relate numeric output fields to numeric input fields.
176 For the default record format, a field is a variable of the form
177 $N, where N is the column number, beginning with 1.
178 Output columns appear on the left-hand side of assignments, input
179 columns appear on the right-hand side.
180 .PP
181 A variable definition has the form:
182 .PP
183
184 var = expression ;
185
186 .PP
187 Any instance of the variable in an expression will be replaced
188 with its definition.
189 .PP
190 An expression contains real numbers, variable names, function calls,
191 and the following operators:
192 .PP
193 + - * / ^
194 .PP
195 Operators are evaluated left to right.
196 Powers have the highest precedence; multiplication and
197 division are evaluated before addition and subtraction.
198 Expressions can be grouped with parentheses.
199 All values are double precision real.
200 .PP
201 A function definition has the form:
202 .PP
203
204 func(a1, a2, ..) = expression ;
205
206 .PP
207 The expression can contain instances of the function arguments
208 as well as other variables and functions.
209 Function names can be passed as arguments.
210 Recursive functions can be defined using calls to the defined
211 function or other functions calling the defined function.
212 .PP
213 The variable
214 .I cond,
215 if defined, will determine whether the current input record produces
216 an output record.
217 If
218 .I cond
219 is positive, output is produced.
220 If
221 .I cond
222 is less than or equal to zero, the record is skipped and no other expressions
223 are evaluated.
224 This provides a convenient method for avoiding inappropriate calculations.
225 The following library of pre-defined functions and variables is provided:
226 .TP 10n
227 .BR "in(n)"
228 Return the value for input column
229 .I n,
230 or the number of columns available in this record if
231 .I n
232 is 0.
233 This is an alternate way to get a column value instead of using
234 the $N notation, and is more flexible since it is programmable.
235 This function is disabled if an input format is used.
236 .TP
237 .BR "if(cond, then, else)"
238 if cond is greater than zero,
239 then is evaluated, otherwise else is evaluated.
240 This function is necessary for recursive definitions.
241 .TP
242 .BR "select(N, a1, a2, ..)"
243 return aN (N is rounded to the nearest integer).
244 This function provides array capabilities.
245 If
246 .I N
247 is zero, the number of available arguments is returned.
248 .TP
249 .BR "rand(x)"
250 compute a random number between 0 and 1 based on x.
251 .TP
252 .BR "floor(x)"
253 return largest integer not greater than x.
254 .TP
255 .BR "ceil(x)"
256 return smallest integer not less than x.
257 .TP
258 .BR "sqrt(x)"
259 return square root of x.
260 .TP
261 .BR "exp(x)"
262 compute e to the power of x (e approx = 2.718281828).
263 .TP
264 .BR "log(x)"
265 compute the logarithm of x to the base e.
266 .TP
267 .BR "log10(x)"
268 compute the logarithm of x to the base 10.
269 .TP
270 .BR PI
271 the ratio of a circle's circumference to its diameter.
272 .TP
273 .BR recno
274 the number of records recognized thus far.
275 .TP
276 .BR outno
277 the number or records output thus far (including this one).
278 .TP
279 .BR "sin(x), cos(x), tan(x)"
280 trigonometric functions.
281 .TP
282 .BR "asin(x), acos(x), atan(x)"
283 inverse trigonometric functions.
284 .TP
285 .BR "atan2(y, x)"
286 inverse tangent of y/x (range -pi to pi).
287 .SH EXAMPLE
288 To print the square root of column two in column one,
289 and column one times column three in column two:
290 .IP "" .2i
291 rcalc -e '$1=sqrt($2);$2=$1*$3' inputfile > outputfile
292 .SH AUTHOR
293 Greg Ward
294 .SH BUGS
295 String variables can only be used in input and output formats and
296 .I \-s
297 options, not in definitions.
298 .PP
299 Tabs count as single spaces inside fields.
300 .SH "SEE ALSO"
301 cnt(1), ev(1), getinfo(1), icalc(1), rlam(1), tabfunc(1), total(1)
