root/radiance/ray/doc/man/man1/rcalc.1
Revision: 1.4
Committed: Tue Dec 9 15:59:06 2003 UTC (21 years, 6 months ago) by greg
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH RCALC 1 4/6/99 RADIANCE
3 .SH NAME
4 rcalc - record calculator
5 .SH SYNOPSIS
6 .B rcalc
7 [
8 .B \-b
9 ][
10 .B \-l
11 ][
12 .B \-n
13 ][
14 .B \-w
15 ][
16 .B \-u
17 ][
18 .B \-tS
19 ][
20 .B "\-i format"
21 ][
22 .B "\-o format"
23 ][
24 .B "\-f source"
25 ][
26 .B "\-e expr"
27 ][
28 .B "\-s svar=sval"
29 ]
30 file ..
31 .SH DESCRIPTION
32 .I Rcalc
33 transforms ``records'' from each
34 .I file
35 according to the given set of literal and relational information.
36 By default, records are separated by newlines, and contain
37 numeric fields separated by tabs.
38 The
39 .I \-tS
40 option is used to specify an alternate tab character.
41 .PP
42 A
43 .I \-i format
44 option specifies a template for an alternate
45 input record format.
46 .I Format
47 is interpreted as a specification string if it contains a dollar sign '$'.
48 Otherwise, it is interpreted as the name of the file containing
49 the format specification.
50 In either case, if the format does not end with a newline, one will be added
51 automatically.
52 A special form of the
53 .I \-i
54 option may be followed immediately by a 'd' or an 'f' and an optional
55 count, which defaults to 1, indicating the number of double or float
56 binary values to read per record on the input file.
57 If binary input is specified, no format string or file is needed.
58 .PP
59 A
60 .I \-o format
61 option specifies an alternate output record format.
62 It is interpreted the same as an input specification, except that
63 the special
64 .I \-od
65 or
66 .I \-of
67 options do not require a count, as this will be determined by the
68 number of output channels in the given expressions.
69 .PP
70 The variable and function definitions in each
71 .I \-f source
72 file are read and compiled.
73 The
74 .I \-e expr
75 option can be used to define variables on the command line.
76 Since many of the characters in an expression have special meaning
77 to the shell, it should usually be enclosed in single quotes.
78 The
79 .I \-s svar=sval
80 option can be used to assign a string variable a string value.
81 If this string variable appears in an input format, only records
82 with the specified value will be processed.
83 .PP
84 The
85 .I \-b
86 option instructs the program to accept only exact matches.
87 By default, tabs and spaces are ignored except
88 as field separators.
89 The
90 .I \-l
91 option instructs the program to ignore newlines in the input,
92 basically treating them the same as tabs and spaces.
93 Normally, the beginning of the input format matches the beginning of
94 a line, and the end of the format matches the end of a line.
95 With the
96 .I \-l
97 option, the input format can match anywhere on a line.
98 .PP
99 The
100 .I \-w
101 option causes non-fatal error messages (such as division by zero) to
102 be supressed.
103 The
104 .I \-u
105 option causes output to be flushed after each record.
106 The
107 .I \-n
108 option tells the program not to get any input, but to produce a
109 single output record.
110 Otherwise, if no files are given, the standard input is read.
111 .PP
112 Format files associate names with string and numeric fields
113 separated by literal information in a record.
114 A numeric field is given in a format file as a dollar sign, followed
115 by curly braces enclosing a variable name:
116 .PP
117 This is a numeric field: ${vname}
118 .PP
119 A string variable is enclosed in parentheses:
120 .PP
121 This is a string field: $(sname)
122 .PP
123 The program attempts to match literal information in
124 the input format to its input and assign string and numeric
125 fields accordingly.
126 If a string or numeric field variable appears more than once in
127 the input format, input values for the corresponding fields must
128 match (ie. have the same value) for the whole record to match.
129 Numeric values are allowed some deviation, on the order of 0.1%, but
130 string variables must match exactly.
131 Thus, dummy variables for "don't care" fields should be given unique
132 names so that they are not all required to take on the same value.
133 .PP
134 For each valid input record, an output record is produced
135 in its corresponding format.
136 Output field widths are given implicitly by the space occupied
137 in the format file, including the dollar sign and braces.
138 This makes it impossible to produce fields with fewer than four
139 characters.
140 If the
141 .I \-b
142 option is specified, input records must exactly match the
143 template.
144 By default, the character following each input field is used as
145 a delimiter.
146 This implies that string fields that are followed by white space
147 cannot contain strings with white space.
148 Also, numeric fields followed but not preceded by white space
149 will not accept numbers preceded by white space.
150 Adjacent input fields are advisable only with the
151 .I \-b
152 option.
153 Numeric output fields may contain expressions as well as variables.
154 A dollar sign may appear in a literal as two dollar signs ($$).
155 .PP
156 The definitions specified in
157 .I \-e
158 and
159 .I \-f
160 options relate numeric output fields to numeric input fields.
161 For the default record format, a field is a variable of the form
162 $N, where N is the column number, beginning with 1.
163 Output columns appear on the left-hand side of assignments, input
164 columns appear on the right-hand side.
165 .PP
166 A variable definition has the form:
167 .PP
168
169 var = expression ;
170
171 .PP
172 Any instance of the variable in an expression will be replaced
173 with its definition.
174 .PP
175 An expression contains real numbers, variable names, function calls,
176 and the following operators:
177 .PP
178 + - * / ^
179 .PP
180 Operators are evaluated left to right.
181 Powers have the highest precedence; multiplication and
182 division are evaluated before addition and subtraction.
183 Expressions can be grouped with parentheses.
184 All values are double precision real.
185 .PP
186 A function definition has the form:
187 .PP
188
189 func(a1, a2, ..) = expression ;
190
191 .PP
192 The expression can contain instances of the function arguments
193 as well as other variables and functions.
194 Function names can be passed as arguments.
195 Recursive functions can be defined using calls to the defined
196 function or other functions calling the defined function.
197 .PP
198 The variable
199 .I cond,
200 if defined, will determine whether the current input record produces
201 an output record.
202 If
203 .I cond
204 is positive, output is produced.
205 If
206 .I cond
207 is less than or equal to zero, the record is skipped and no other expressions
208 are evaluated.
209 This provides a convenient method for avoiding inappropriate calculations.
210 The following library of pre-defined functions and variables is provided:
211 .TP 10n
212 .BR "in(n)"
213 Return the value for input column
214 .I n,
215 or the number of columns available in this record if
216 .I n
217 is 0.
218 This is an alternate way to get a column value instead of using
219 the $N notation, and is more flexible since it is programmable.
220 This function is disabled if an input format is used.
221 .TP
222 .BR "if(cond, then, else)"
223 if cond is greater than zero,
224 then is evaluated, otherwise else is evaluated.
225 This function is necessary for recursive definitions.
226 .TP
227 .BR "select(N, a1, a2, ..)"
228 return aN (N is rounded to the nearest integer).
229 This function provides array capabilities.
230 If
231 .I N
232 is zero, the number of available arguments is returned.
233 .TP
234 .BR "rand(x)"
235 compute a random number between 0 and 1 based on x.
236 .TP
237 .BR "floor(x)"
238 return largest integer not greater than x.
239 .TP
240 .BR "ceil(x)"
241 return smallest integer not less than x.
242 .TP
243 .BR "sqrt(x)"
244 return square root of x.
245 .TP
246 .BR "exp(x)"
247 compute e to the power of x (e approx = 2.718281828).
248 .TP
249 .BR "log(x)"
250 compute the logarithm of x to the base e.
251 .TP
252 .BR "log10(x)"
253 compute the logarithm of x to the base 10.
254 .TP
255 .BR PI
256 the ratio of a circle's circumference to its diameter.
257 .TP
258 .BR recno
259 the number of records recognized thus far.
260 .TP
261 .BR outno
262 the number or records output thus far (including this one).
263 .TP
264 .BR "sin(x), cos(x), tan(x)"
265 trigonometric functions.
266 .TP
267 .BR "asin(x), acos(x), atan(x)"
268 inverse trigonometric functions.
269 .TP
270 .BR "atan2(y, x)"
271 inverse tangent of y/x (range -pi to pi).
272 .SH EXAMPLE
273 To print the square root of column two in column one,
274 and column one times column three in column two:
275 .IP "" .2i
276 rcalc -e '$1=sqrt($2);$2=$1*$3' inputfile > outputfile
277 .SH AUTHOR
278 Greg Ward
279 .SH BUGS
280 String variables can only be used in input and output formats and
281 .I \-s
282 options, not in definitions.
283 .PP
284 Tabs count as single spaces inside fields.
285 .SH "SEE ALSO"
286 calc(1), cnt(1), ev(1), getinfo(1), lam(1), tabfunc(1), total(1)
