--- ray/doc/man/man1/rcalc.1 2006/12/23 17:27:45 1.7 +++ ray/doc/man/man1/rcalc.1 2012/02/03 17:55:16 1.9 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcalc.1,v 1.7 2006/12/23 17:27:45 greg Exp $" +.\" RCSid "$Id: rcalc.1,v 1.9 2012/02/03 17:55:16 greg Exp $" .TH RCALC 1 4/6/99 RADIANCE .SH NAME rcalc - record calculator @@ -202,7 +202,8 @@ and the following operators: .PP + - * / ^ .PP -Operators are evaluated left to right. +Operators are evaluated left to right, except '^', +which is right associative. Powers have the highest precedence; multiplication and division are evaluated before addition and subtraction. Expressions can be grouped with parentheses. @@ -234,6 +235,11 @@ are evaluated. This provides a convenient method for avoiding inappropriate calculations. The following library of pre-defined functions and variables is provided: .TP 10n +.BR \$N +Return the value for input column +.I N. +If an input format is given, using a channel number generates an error. +.TP .BR "in(n)" Return the value for input column .I n, @@ -293,12 +299,12 @@ trigonometric functions. inverse trigonometric functions. .TP .BR "atan2(y, x)" -inverse tangent of y/x (range -pi to pi). +inverse tangent of y/x (range \-pi to pi). .SH EXAMPLE To print the square root of column two in column one, and column one times column three in column two: .IP "" .2i -rcalc -e '$1=sqrt($2);$2=$1*$3' inputfile > outputfile +rcalc \-e '$1=sqrt($2);$2=$1*$3' inputfile > outputfile .SH AUTHOR Greg Ward .SH BUGS
