--- ray/doc/man/man1/rcalc.1 2022/03/11 22:50:13 1.16 +++ ray/doc/man/man1/rcalc.1 2022/03/13 16:11:48 1.17 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcalc.1,v 1.16 2022/03/11 22:50:13 greg Exp $" +.\" RCSid "$Id: rcalc.1,v 1.17 2022/03/13 16:11:48 greg Exp $" .TH RCALC 1 4/6/99 RADIANCE .SH NAME rcalc - record calculator @@ -351,6 +351,17 @@ String variables can only be used in input and output options, not in definitions. .PP Tabs count as single spaces inside fields. +.PP +The +.I \-P +option buffers up to 16 Kbytes of data per record. +Longer records passed because the "cond" variable +evaluates to <= 0 will be partial; a warning will +be generated and the string "*** MISSING DATA ***" +will appear at the break. +The only workaround is to use the +.I \-p +option instead, which does not pass rejected records. .SH "SEE ALSO" cnt(1), ev(1), getinfo(1), icalc(1), rcollate(1), rlam(1), rsplit(1), tabfunc(1), total(1)
