--- ray/doc/man/man1/rcalc.1 2019/07/20 00:57:43 1.15 +++ ray/doc/man/man1/rcalc.1 2022/03/11 22:50:13 1.16 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcalc.1,v 1.15 2019/07/20 00:57:43 greg Exp $" +.\" RCSid "$Id: rcalc.1,v 1.16 2022/03/11 22:50:13 greg Exp $" .TH RCALC 1 4/6/99 RADIANCE .SH NAME rcalc - record calculator @@ -9,7 +9,7 @@ rcalc - record calculator ][ .B \-l ][ -.B \-p +.B "\-p | \-P" ][ .B \-n ][ @@ -87,11 +87,18 @@ The .I \-p option specifies "passive mode," where characters that do not match the input format are passed unaltered to the output. -This option has no effect unless +If the +.I \-P +option is given instead, then valid input records that do not +yield a positive +.I cond +value are similarly passed to the output. +(See paragraph below.)\0 +These options options require that the .I \-i -is also specified, and does not make much sense unless +input format and .I \-o -is also given. +output format also be present. With both input and output formats, the passive mode can effectively substitute information in the middle of a file or stream without affecting the rest of the data. @@ -250,7 +257,10 @@ If is positive, output is produced. If .I cond -is less than or equal to zero, the record is skipped and no other expressions +is less than or equal to zero, the record is skipped (or passed to the +output if +.I \-P +is specified) and no other expressions are evaluated. This provides a convenient method for avoiding inappropriate calculations. The following library of pre-defined functions and variables is provided: @@ -270,8 +280,8 @@ This is an alternate way to get a column value instead the $N notation, and is more flexible since it is programmable. This function is disabled if an input format is used. .TP -.BR "if(cond, then, else)" -if cond is greater than zero, +.BR "if(test, then, else)" +if test is greater than zero, then is evaluated, otherwise else is evaluated. This function is necessary for recursive definitions. .TP
