--- ray/doc/man/man1/rcalc.1 2013/09/05 17:53:22 1.10 +++ ray/doc/man/man1/rcalc.1 2013/12/19 16:38:12 1.11 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rcalc.1,v 1.10 2013/09/05 17:53:22 greg Exp $" +.\" RCSid "$Id: rcalc.1,v 1.11 2013/12/19 16:38:12 greg Exp $" .TH RCALC 1 4/6/99 RADIANCE .SH NAME rcalc - record calculator @@ -94,7 +94,7 @@ or stream without affecting the rest of the data. .PP The variable and function definitions in each .I \-f source -file are read and compiled. +file are read and compiled from the RADIANCE library where it is found. The .I \-e expr option can be used to define variables on the command line. @@ -305,6 +305,8 @@ To print the square root of column two in column one, and column one times column three in column two: .IP "" .2i rcalc \-e '$1=sqrt($2);$2=$1*$3' inputfile > outputfile +.SH ENVIRONMENT +RAYPATH the directories to check for auxiliary files. .SH AUTHOR Greg Ward .SH BUGS
