root/radiance/ray/doc/man/man1/rcalc.1
Revision: 1.12
Committed: Thu Mar 24 18:48:28 2016 UTC (9 years, 4 months ago) by greg
Changes since 1.11: +21 -1 lines
Added -in options to commands for manual EOF specification
1 .\" RCSid "$Id: rcalc.1,v 1.11 2013/12/19 16:38:12 greg Exp $"
2 .TH RCALC 1 4/6/99 RADIANCE
3 .SH NAME
4 rcalc - record calculator
5 .SH SYNOPSIS
6 .B rcalc
7 [
8 .B \-b
9 ][
10 .B \-l
11 ][
12 .B \-p
13 ][
14 .B \-n
15 ][
16 .B \-w
17 ][
18 .B \-u
19 ][
20 .B \-tS
21 ][
22 .B "\-i format"
23 ][
24 .B "\-o format"
25 ][
26 .B "\-in M"
27 ][
28 .B "\-on M"
29 ][
30 .B "\-f source"
31 ][
32 .B "\-e expr"
33 ][
34 .B "\-s svar=sval"
35 ]
36 file ..
37 .SH DESCRIPTION
38 .I Rcalc
39 transforms ``records'' from each
40 .I file
41 according to the given set of literal and relational information.
42 By default, records are separated by newlines, and contain
43 numeric fields separated by tabs.
44 The
45 .I \-tS
46 option is used to specify an alternate tab character.
47 .PP
48 A
49 .I \-i format
50 option specifies a template for an alternate
51 input record format.
52 .I Format
53 is interpreted as a specification string if it contains a dollar sign '$'.
54 Otherwise, it is interpreted as the name of the file containing
55 the format specification.
56 In either case, if the format does not end with a newline, one will be added
57 automatically.
58 A special form of the
59 .I \-i
60 option may be followed immediately by a 'd' or an 'f' and an optional
61 count, which defaults to 1, indicating the number of double or float
62 binary values to read per record on the input file.
63 If the input is byte-swapped, the
64 .I \-iD
65 or
66 .I \-iF
67 options may be substituted.
68 If binary input is specified, no format string or file is needed.
69 .PP
70 A
71 .I \-o format
72 option specifies an alternate output record format.
73 It is interpreted the same as an input specification, except that
74 the special
75 .I \-od
76 or
77 .I \-of
78 options do not require a count, as this will be determined by the
79 number of output channels in the given expressions.
80 If byte-swapped output is desired, the
81 .I \-oD
82 or
83 .I \-oF
84 options may be substituted.
85 .PP
86 The
87 .I \-p
88 option specifies "passive mode," where characters that do not
89 match the input format are passed unaltered to the output.
90 This option has no effect unless
91 .I \-i
92 is also specified, and does not make much sense unless
93 .I \-o
94 is also given.
95 With both input and output formats, the passive mode can
96 effectively substitute information in the middle of a file
97 or stream without affecting the rest of the data.
98 .PP
99 If a
100 .I \-in
101 option is given with a positive integer argument,
102 .I rcalc
103 will stop processing input once it has loaded this number of records.
104 Similarly, if a
105 .I \-on
106 option is present,
107 .I rcalc
108 will stop after producing this many records, which may be a smaller
109 number if the
110 .I cond
111 variable is used.
112 If multiple input files are given, these counts are continuous over
113 the input and do not reset on each file.
114 .PP
115 The variable and function definitions in each
116 .I \-f source
117 file are read and compiled from the RADIANCE library where it is found.
118 The
119 .I \-e expr
120 option can be used to define variables on the command line.
121 Since many of the characters in an expression have special meaning
122 to the shell, it should usually be enclosed in single quotes.
123 The
124 .I \-s svar=sval
125 option can be used to assign a string variable a string value.
126 If this string variable appears in an input format, only records
127 with the specified value will be processed.
128 .PP
129 The
130 .I \-b
131 option instructs the program to accept only exact matches.
132 By default, tabs and spaces are ignored except
133 as field separators.
134 The
135 .I \-l
136 option instructs the program to ignore newlines in the input,
137 basically treating them the same as tabs and spaces.
138 Normally, the beginning of the input format matches the beginning of
139 a line, and the end of the format matches the end of a line.
140 With the
141 .I \-l
142 option, the input format can match anywhere on a line.
143 .PP
144 The
145 .I \-w
146 option causes non-fatal error messages (such as division by zero) to
147 be supressed.
148 The
149 .I \-u
150 option causes output to be flushed after each record.
151 The
152 .I \-n
153 option tells the program not to get any input, but to produce a
154 single output record.
155 Otherwise, if no files are given, the standard input is read.
156 .PP
157 Format files associate names with string and numeric fields
158 separated by literal information in a record.
159 A numeric field is given in a format file as a dollar sign, followed
160 by curly braces enclosing a variable name:
161 .PP
162 This is a numeric field: ${vname}
163 .PP
164 A string variable is enclosed in parentheses:
165 .PP
166 This is a string field: $(sname)
167 .PP
168 The program attempts to match literal information in
169 the input format to its input and assign string and numeric
170 fields accordingly.
171 If a string or numeric field variable appears more than once in
172 the input format, input values for the corresponding fields must
173 match (ie. have the same value) for the whole record to match.
174 Numeric values are allowed some deviation, on the order of 0.1%, but
175 string variables must match exactly.
176 Thus, dummy variables for "don't care" fields should be given unique
177 names so that they are not all required to take on the same value.
178 .PP
179 For each valid input record, an output record is produced
180 in its corresponding format.
181 Output field widths are given implicitly by the space occupied
182 in the format file, including the dollar sign and braces.
183 This makes it impossible to produce fields with fewer than four
184 characters.
185 If the
186 .I \-b
187 option is specified, input records must exactly match the
188 template.
189 By default, the character following each input field is used as
190 a delimiter.
191 This implies that string fields that are followed by white space
192 cannot contain strings with white space.
193 Also, numeric fields followed but not preceded by white space
194 will not accept numbers preceded by white space.
195 Adjacent input fields are advisable only with the
196 .I \-b
197 option.
198 Numeric output fields may contain expressions as well as variables.
199 A dollar sign may appear in a literal as two dollar signs ($$).
200 .PP
201 The definitions specified in
202 .I \-e
203 and
204 .I \-f
205 options relate numeric output fields to numeric input fields.
206 For the default record format, a field is a variable of the form
207 $N, where N is the column number, beginning with 1.
208 Output columns appear on the left-hand side of assignments, input
209 columns appear on the right-hand side.
210 .PP
211 A variable definition has the form:
212 .PP
213
214 var = expression ;
215
216 .PP
217 Any instance of the variable in an expression will be replaced
218 with its definition.
219 .PP
220 An expression contains real numbers, variable names, function calls,
221 and the following operators:
222 .PP
223 + - * / ^
224 .PP
225 Operators are evaluated left to right, except '^',
226 which is right associative.
227 Powers have the highest precedence; multiplication and
228 division are evaluated before addition and subtraction.
229 Expressions can be grouped with parentheses.
230 All values are double precision real.
231 .PP
232 A function definition has the form:
233 .PP
234
235 func(a1, a2, ..) = expression ;
236
237 .PP
238 The expression can contain instances of the function arguments
239 as well as other variables and functions.
240 Function names can be passed as arguments.
241 Recursive functions can be defined using calls to the defined
242 function or other functions calling the defined function.
243 .PP
244 The variable
245 .I cond,
246 if defined, will determine whether the current input record produces
247 an output record.
248 If
249 .I cond
250 is positive, output is produced.
251 If
252 .I cond
253 is less than or equal to zero, the record is skipped and no other expressions
254 are evaluated.
255 This provides a convenient method for avoiding inappropriate calculations.
256 The following library of pre-defined functions and variables is provided:
257 .TP 10n
258 .BR \$N
259 Return the value for input column
260 .I N.
261 If an input format is given, using a channel number generates an error.
262 .TP
263 .BR "in(n)"
264 Return the value for input column
265 .I n,
266 or the number of columns available in this record if
267 .I n
268 is 0.
269 This is an alternate way to get a column value instead of using
270 the $N notation, and is more flexible since it is programmable.
271 This function is disabled if an input format is used.
272 .TP
273 .BR "if(cond, then, else)"
274 if cond is greater than zero,
275 then is evaluated, otherwise else is evaluated.
276 This function is necessary for recursive definitions.
277 .TP
278 .BR "select(N, a1, a2, ..)"
279 return aN (N is rounded to the nearest integer).
280 This function provides array capabilities.
281 If
282 .I N
283 is zero, the number of available arguments is returned.
284 .TP
285 .BR "rand(x)"
286 compute a random number between 0 and 1 based on x.
287 .TP
288 .BR "floor(x)"
289 return largest integer not greater than x.
290 .TP
291 .BR "ceil(x)"
292 return smallest integer not less than x.
293 .TP
294 .BR "sqrt(x)"
295 return square root of x.
296 .TP
297 .BR "exp(x)"
298 compute e to the power of x (e approx = 2.718281828).
299 .TP
300 .BR "log(x)"
301 compute the logarithm of x to the base e.
302 .TP
303 .BR "log10(x)"
304 compute the logarithm of x to the base 10.
305 .TP
306 .BR PI
307 the ratio of a circle's circumference to its diameter.
308 .TP
309 .BR recno
310 the number of records recognized thus far.
311 .TP
312 .BR outno
313 the number or records output thus far (including this one).
314 .TP
315 .BR "sin(x), cos(x), tan(x)"
316 trigonometric functions.
317 .TP
318 .BR "asin(x), acos(x), atan(x)"
319 inverse trigonometric functions.
320 .TP
321 .BR "atan2(y, x)"
322 inverse tangent of y/x (range \-pi to pi).
323 .SH EXAMPLE
324 To print the square root of column two in column one,
325 and column one times column three in column two:
326 .IP "" .2i
327 rcalc \-e '$1=sqrt($2);$2=$1*$3' inputfile > outputfile
328 .SH ENVIRONMENT
329 RAYPATH the directories to check for auxiliary files.
330 .SH AUTHOR
331 Greg Ward
332 .SH BUGS
333 String variables can only be used in input and output formats and
334 .I \-s
335 options, not in definitions.
336 .PP
337 Tabs count as single spaces inside fields.
338 .SH "SEE ALSO"
339 cnt(1), ev(1), getinfo(1), icalc(1), rcollate(1), rlam(1), tabfunc(1), total(1)
