root/Development/ray/doc/man/man1/ranimove.1
Revision: 1.9
Committed: Fri Oct 5 00:59:38 2012 UTC (13 years ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R2P1, rad4R2P2, HEAD
Changes since 1.8: +24 -10 lines
# User Rev Content
1 greg 1.9 .\" RCSid "$Id: ranimove.1,v 1.8 2012/09/28 22:20:49 greg Exp $"
2 greg 1.2 .TH RANIMOVE 1 1/30/03 RADIANCE
3 greg 1.1 .SH NAME
4     ranimove - render a RADIANCE animation with motion
5     .SH SYNOPSIS
6     .B ranimove
7     [
8     .B \-s
9     ][
10     .B \-e
11     ][
12     .B \-w
13     ][
14     .B "\-f beg,end"
15     ][
16     .B "\-n nprocs"
17     ][
18     .B "\-t sec"
19     ][
20     .B "\-d jnd"
21     ]
22     .B rnmfile
23     .SH DESCRIPTION
24     .I Ranimove
25     is a program for progressive animation rendering.
26     Variables in the given
27     .I rnmfile
28     indicate input files, output file names,
29     and various other controls and options.
30     .PP
31     Normally, progress reports are written to the standard output, but the
32     .I \-s
33     option tells
34     .I ranimove
35     to do its work silently.
36     The
37     .I \-e
38     option tells
39     .I ranimove
40     to explicate all variables used for the animation, including
41     default values not specified in the input file, and print them on
42     the standard output.
43     The
44     .I \-w
45     option turns off warnings about multiply and misassigned variables and
46     non-fatal rendering problems.
47     .PP
48     Normally,
49     .I ranimove
50     will produce one animation frame for each view given in the specified
51     view file.
52     If the
53     .I \-f
54     option is specified, the animation will resume at the given frame, and
55     continue to the end of the sequence, or to the second frame if one is given
56     (separated from the first by a comma but no space).
57     .PP
58     The
59     .I \-n
60     option specifies the number of processes to use for rendering.
61     The default value is 1, which is appropriate for most machines
62     that have a single central processing unit (CPU).
63     If you are running on a machine with multiple CPUs, a larger
64     value up to the number of processors may be used
65     to improve rendering speed, depending on the system load.
66     .PP
67     Because
68     .I ranimove
69     renders each frame progressively, it needs some criteria for when
70     to proceed to the next frame in the animation.
71     The
72     .I \-t
73     option is used to specify the maximum number of seconds to spend
74     on any one frame.
75     The default value for this option is 60 seconds.
76     Additionally, the
77     .I \-d
78     option may be used to specify a termination
79     threshold in just-noticeable-differences.
80     If the error can be reduced below this number of JNDs
81     over the whole frame before the time allocation is spent,
82     .I ranimove
83     will then proceed to the next frame.
84     A value of 2.0 JNDs is the point at which 75% of the people will notice
85     a difference, and this is the level usually selected for such a
86     termination test.
87     There is no default value for this option, which means that rendering
88     will proceed until the time allocation is spent for each frame, regardless.
89     If
90     .I \-t
91     is set to 0,
92     .I ranimove
93     will spend as much time as it takes to reduce the
94     visible error below the value set by the
95     .I \-d
96     option.
97     .PP
98     .I Ranimove
99     renders each frame in three stages.
100     In the first stage, a low-quality image
101     is rendered using one ray sample per 16 pixels.
102     In the second stage, pixels from the previous frame are extrapolated to
103     their corresponding positions in
104     this one, based on the given camera and object movements.
105     A set of heuristics is applied
106     to prevent errors in specular highlights and shadows, avoiding
107     some of the errors typical with the
108     .I pinterp(1)
109     program.
110     In the third stage, additional high-quality samples are used to refine
111     important regions of the image that are judged to have visible errors.
112     This proceeds until the stopping criteria specified by the
113     .I \-t
114     and
115     .I -d
116     options are met,
117     when the frame is filtered and written to the designated picture file.
118     .PP
119     The chief differences between this program and
120     .I ranimate(1)
121     are that motion blur is computed for objects as well as camera movement,
122     and its progressive rendering allows better control over the tradeoff
123     between frame accuracy and rendering time.
124     Fewer controls are provided for managing the picture files produced by
125     .I ranimove,
126     and no facilities for distributed rendering are available other
127     than executing
128     .I ranimove
129     on different machines using the
130     .I \-f
131     option to manually partition the work.
132     .PP
133     Animation variable assignments appear one per line in
134     .I rnmfile.
135     The name of the variable is followed by an equals sign
136     ('=') and its value(s).
137     The end of line may be escaped with a backslash ('\\'), though it is
138     not usually necessary since additional variable values may be given
139     in multiple assignments.
140     Variables that should have only one value are given in upper case.
141     Variables that may have multiple values are given in lower case.
142     Variables may be abbreviated by their first three letters.
143     Comments in
144     .I rnmfile
145     start with a pound sign ('#') and proceed to the end of line.
146     .PP
147     The animation variables, their interpretations and default values
148     are given below.
149     .TP 10n
150     .BR OCTREE
151     The name of the base octree file, which should be generated by the
152     .I oconv(1)
153     command using the
154     .I \-f
155     option.
156     There is no default value for this variable.
157     If no
158     .I RIF
159     variable is given, the octree must be specified.
160     .TP
161     .BR RIF
162     This variable specifies a
163     .I rad(1)
164     input file to use as a source of rendering options and other
165     variable settings.
166     If given,
167     .I ranimate
168     will execute
169     .I rad
170     and create an options file to control rendering parameters.
171     .I Ranimate
172     will also extract default settings for the common variables:
173     .I OCTREE,
174     .I RESOLUTION,
175     and
176     .I EXPOSURE.
177     Following the file name, overriding variable settings may be given,
178     which will be passed to
179     .I rad
180     on the command line.
181     Settings with spaces in them should be enclosed in quotes.
182     The execution of
183     .I rad
184     will also update the contents of the octree, if necessary.
185     There is no default value for this variable.
186     .TP
187     .BR move
188     This variable specifies an object (or objects) with a specific
189     motion and/or rendering priority.
190     Four value arguments are expected for each appearance of this variable.
191     The first is the name of a parent move object, or "void" if none.
192     If given, the object's transformation will be prepended to that
193     of its parent.
194     The second argument is the name of this object, which will be used
195 greg 1.7 to name surfaces it contains, and as a parent identifier for any child
196     objects that reference it.
197 greg 1.1 The third argument is the transformation string or file for this object.
198     If this argument is enclosed in quotes and begins with a hyphen
199     ('-'), then it will be interpreted as a
200     static transform specification a la
201     .I xform(1).
202     Otherwise, the argument will be taken as the name of a file that contains
203     one such transform specification per line, corresponding to frames in the
204     animation.
205     A period ('.') may be given if no object transformation is desired.
206     The fourth argument is the name of a
207     .I RADIANCE
208     scene file (or files) to be given to
209     .I xform
210     for transformation.
211     If this argument begins with an exclamation point ('!'), then
212     it will be interpreted as a command rather than a file.
213     A final word corresponding to the frame number will be
214     appended to the command, and its output will be passed to
215     the input of
216     .I xform
217     for each frame.
218 greg 1.7 An optional fifth argument
219 greg 1.1 specifies the rendering priority for this object.
220 greg 1.7 Values greater than 1.0 will result in preferential rendering of
221 greg 1.1 this object over other portions of the image when it appears in a frame.
222 greg 1.7 Values less than 1.0 will cause the rendering to neglect this object in
223 greg 1.1 favor of other parts of the image.
224     A value of 3.0 can be interpreted as saying the viewer is three times more
225     likely to look at this object than the background.
226     A file may be given rather than a floating point value, and this file must
227 greg 1.7 contain one floating point number per line, corresponding to priorities
228     for frames in the animation.
229 greg 1.1 .TP
230     .BR VIEWFILE
231     This variable names a file from which
232     .I ranimove
233     may extract the view for each frame in the animation.
234     This file should contain one valid view per frame, starting with
235     frame 1 on line 1.
236     An exception is made for a view file with only a single view, which
237     is used for every frame of the animation.
238     In this case, the
239     .I END
240     variable must also be specified.
241     This variable is required, and there is no default value.
242     .TP
243     .BR END
244     The final frame number in the animation.
245     The default value is computed from the number of views in the given
246     .I VIEWFILE.
247     Normally, this variable will only be given if the view is static.
248     .TP
249     .BR EXPOSURE
250     This variable tells
251     .I ranimate
252     how to adjust the exposure for each frame.
253     As in
254     .I pfilt,
255     the exposure setting may be given either as a multiplier or as a
256 greg 1.5 number of f\-stop adjustments (eg. +2 or \-1.5).
257 greg 1.1 Alternatively, a file name may be given, which
258     .I ranimate
259     will interpret as having one exposure value per line per frame,
260     beginning with frame 1 at line 1.
261     (See also the
262     .I VIEWFILE
263     variable, above.)\0
264     There is no default value for this variable.
265     If it is not given, no exposure adjustments will be made.
266     .TP
267     .BR BASENAME
268     The base output file name for the final frames.
269     This string should contain a
270     .I printf(3)
271     style integer field to distinguish one frame number from another.
272 greg 1.6 The final frames will use this name with a ".hdr" suffix.
273 greg 1.1 The default value is "frame%03d".
274     .TP
275     .BR MBLUR
276     This variable specifies the fraction of a frame time that the shutter
277     is simulated as being open for motion blur.
278     Motion blur is computed by
279     .I ranimove
280 greg 1.9 using image-based rendering methods in a rather crude fashion.
281     A much better result is achieved by setting
282     .I MBLUR=0
283     and using the
284     .I pmblur2(1)
285     command as a post-process, assigning the
286     .I ZNAME
287     and
288     .I MNAME
289     variables described below.
290     The default motion blur is 0.
291 greg 1.1 .TP
292     .BR RATE
293     This variable specifies the animation frame rate, in frames per second.
294     This is needed to compute the animation error visibility.
295     The default value is 8.
296     .TP
297     .BR RESOLUTION
298     This variable specifies the desired final picture resolution.
299     If only a single number is given, this value will be used for both
300     the horizontal and vertical picture dimensions.
301     If two numbers are given, the first is the horizontal resolution and
302     the second is the vertical resolution.
303     If three numbers are given, the third is taken as the pixel aspect
304     ratio for the final picture (a real value).
305     If the pixel aspect ratio is zero, the exact dimensions given will
306     be those produced.
307     Otherwise, they will be used as a frame in which the final image
308     must fit.
309     The default value for this variable is 640.
310     .TP
311     .BR lowq
312     This variable may be used to specify rendering options
313     for the initial, low-quality ray samples.
314     It may be given either as a list of rendering parameter settings,
315     or as variable settings for the
316     .I rad
317     command, in which case the
318     .I RIF
319     variable must also be specified.
320     .TP
321     .BR highq
322     This variable may be used to specify rendering options
323     for the final, high-quality ray samples.
324     It may be given either as a list of rendering parameter settings,
325     or as variable settings for the
326     .I rad
327     command, in which case the
328     .I RIF
329     variable must also be specified.
330     .TP
331     .BR oconv
332     This variable may be used to specify special options for
333     .I oconv.
334     See the
335     .I oconv(1)
336     manual page for a list of valid options.
337     (The
338     .I \-f
339     option is specified by default.)\0
340 greg 1.8 .TP
341     .BR ZNAME
342     The base file name for the depth buffer output frames.
343     This string should contain a
344     .I printf(3)
345     style integer field to distinguish one frame number from another.
346     The final frames will use this name with a ".zbf" suffix.
347 greg 1.9 This is needed by the
348     .I pmblur2
349     command to compute a better motion blur.
350 greg 1.8 There is no default setting for this variable.
351     .TP
352     .BR MNAME
353     The base file name for the motion vector output frames.
354     This string should contain a
355     .I printf(3)
356     style integer field to distinguish one frame number from another.
357     The final frames will use this name with a ".mvo" suffix.
358 greg 1.9 This file is used together with the image and depth buffer by
359     .I pmblur2
360     to compute a better motion blur.
361     In this case, the
362     .I MBLUR
363     variable should be unset or zero.
364 greg 1.8 The file will contain 3 16-bit unsigned values per pixel.
365 greg 1.9 The first two are the x and y offsets to each pixel in the previous frame,
366     with an offset of 32768 being no movement.
367 greg 1.8 The third value is 0 if the previous frame's pixel was on a
368     different object, and 32768 if it was on the same object.
369     There is no default setting for this variable.
370 greg 1.1 .SH EXAMPLES
371     A minimal input file for
372     .I ranimove
373     might look like this:
374     .IP "" .3i
375     .nf
376     ::::::::::
377     sample.rnm
378     ::::::::::
379     # The rad input file for our static scene:
380     RIF= tutor.rif
381     # The view file containing one view per frame:
382     VIEWFILE= anim1.vf
383     # Our central character and its motion:
384     move= void myguy myguy.xf myguy.rad 2.0
385     .fi
386     .PP
387     Note that most of the variables are not set in this file.
388     If we only want to see what default values
389     .I ranimove
390     would use without actually executing anything, we can invoke it
391     thus:
392     .IP "" .2i
393 greg 1.5 ranimove \-n 0 \-e sample.rnm
394 greg 1.1 .PP
395     This will print the variables we have given as well as default
396     values
397     .I ranimove
398     has assigned for us.
399     .PP
400     Usually, we execute
401     .I ranimove
402     in the background, redirecting the standard output and standard
403     error to a file:
404     .IP "" .2i
405     ranimove sample.rnm >& sample.err &
406     .PP
407     If we decide that the default values
408     .I ranimove
409     has chosen for our variables are not all appropriate, we can add
410     some more assignments to the file:
411     .IP "" .3i
412     .nf
413     RES= 1024 # shoot for 1024x resolution
414     MBLUR= .25 # apply camera motion blur
415     RATE= 15 # 15 frames/second
416     EXP= anim1.exp # adjust exposure according to file
417     lowq= QUAL=Low # low quality ray sampling
418     highq= QUAL=Med # high quality ray sampling
419     .fi
420     .PP
421     Note the use of abbreviation for variable names.
422     .SH AUTHOR
423     Greg Ward
424     .SH "SEE ALSO"
425 greg 1.9 fieldcomb(1), oconv(1), pfilt(1), pinterp(1), pmblur2(1), pvalue(1), rad(1),
426 greg 1.4 ran2tiff(1), ranimate(1), rpict(1), xform(1)
