--- ray/doc/man/man1/ranimate.1 2005/02/07 17:08:16 1.5 +++ ray/doc/man/man1/ranimate.1 2022/06/01 16:59:34 1.11 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: ranimate.1,v 1.5 2005/02/07 17:08:16 greg Exp $" +.\" RCSid "$Id: ranimate.1,v 1.11 2022/06/01 16:59:34 greg Exp $" .TH RANIMATE 1 6/24/98 RADIANCE .SH NAME ranimate - compute a RADIANCE animation @@ -157,7 +157,7 @@ how to adjust the exposure for each frame. As in .I pfilt, the exposure setting may be given either as a multiplier or as a -number of f-stop adjustments (eg. +2 or -1.5). +number of f\-stop adjustments (eg. +2 or \-1.5). Alternatively, a file name may be given, which .I ranimate will interpret as having one exposure value per line per frame, @@ -180,7 +180,7 @@ options of rpict, along with appropriate suffixes, and thus should contain a .I printf(3) style integer field to distinguish one frame number from another. -The final frames will use this name with a ".pic" suffix. +The final frames will use this name with a ".hdr" suffix. The default value is the assigned .I DIRECTORY followed by "/frame%03d". @@ -271,6 +271,10 @@ before it is executed. Normally, the transfer command does something such as convert the frames to another format and/or copy them to tape or some other destination device before removing them. +The +.I fieldcomb(1) +script may be used to conveniently combine fields into frames for +field-based animations. If this variable is not given, the final frames are left where they are. (See @@ -288,7 +292,7 @@ command, except that the option will always be used to specify an alternate user name rather than the .I "user@host" convention. -Th +The .I -l option may or may not appear, but the .I -n @@ -358,7 +362,7 @@ used otherwise. The default fraction is 0, meaning no motion blurring. This option does not currently work with the .I ANIMATE -variable, since pinterp only works for static environments. +variable. .TP .BR DBLUR This variable specifies the aperture diameter for depth-of-field blurring, @@ -380,10 +384,8 @@ world coordinate units. For example, if you wish to simulate a 50mm lens at f/2.0 in a scene modeled in meters, then you divide 50mm by 2.0 to get 25mm, which corresponds to an effective aperture of 0.025 meters. +The focus distance is determined by the length of the view directon vector. The default aperture is 0, meaning no depth-of-field blurring. -This option does not currently work with the -.I ANIMATE -variable, since pinterp only works for static environments. .TP .BR RTRACE This boolean variable tells @@ -485,7 +487,7 @@ If we only want to see what default values would use without actually executing anything, we can invoke it thus: .IP "" .2i -ranimate -n -e sample.ran +ranimate \-n \-e sample.ran .PP This will print the variables we have given as well as default values @@ -516,7 +518,7 @@ INTERP= 3 # render every fourth frame RES= 1024 # shoot for 1024x resolution MBLUR= .25 # apply camera motion blur EXP= anim1.exp # adjust exposure according to file -pfilt= -r .9 # use Gaussian filtering +pfilt= \-r .9 # use Gaussian filtering ARCHIVE= tar cf /dev/nrtape # save original renderings to tape .fi .PP @@ -524,7 +526,7 @@ Note the use of abbreviation for variable names. .SH FILES $(DIRECTORY)/STATUS animation status file $(DIRECTORY)/* other temporary files -$(BASENAME).pic final animation frames +$(BASENAME).hdr final animation frames .SH AUTHOR Greg Ward .SH BUGS @@ -605,5 +607,5 @@ is called if INTERPOLATE > 0 and/or MBLUR is assigned. Since most modern machines use IEEE floating point, this is not usually a problem, but it is something to keep in mind. .SH "SEE ALSO" -pfilt(1), pinterp(1), pmblur(1), rad(1), -ranimove(1), rpict(1), ssh(1), rtrace(1) +fieldcomb(1), pfilt(1), pinterp(1), pmblur(1), rad(1), +ran2tiff(1), ranimove(1), rpict(1), ssh(1), rtrace(1)
