--- ray/doc/man/man1/ranimate.1 2005/01/18 03:59:40 1.3 +++ ray/doc/man/man1/ranimate.1 2005/09/17 05:14:14 1.7 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: ranimate.1,v 1.3 2005/01/18 03:59:40 greg Exp $" +.\" RCSid "$Id: ranimate.1,v 1.7 2005/09/17 05:14:14 greg Exp $" .TH RANIMATE 1 6/24/98 RADIANCE .SH NAME ranimate - compute a RADIANCE animation @@ -271,6 +271,10 @@ before it is executed. Normally, the transfer command does something such as convert the frames to another format and/or copy them to tape or some other destination device before removing them. +The +.I fieldcomb(1) +script may be used to conveniently combine fields into frames for +field-based animations. If this variable is not given, the final frames are left where they are. (See @@ -279,10 +283,10 @@ above.)\0 .TP .BR RSH The command to use instead of -.I rsh(1) +.I ssh(1) to execute commands remotely on another machine. The arguments and behavior of this program must be identical to the UNIX -.I rsh +.I ssh command, except that the .I -l option will always be used to specify an alternate user name rather than the @@ -294,7 +298,7 @@ option may or may not appear, but the .I -n option will always be used, and the expected starting directory will be that of the remote user, just as with -.I rsh. +.I ssh. .TP .BR NEXTANIM This variable specifies the next @@ -374,6 +378,12 @@ and .I pinterp used otherwise. (The default value for number of samples is 5.)\0 +To simulate a particular camera's aperture, divide the focal length of +the lens by the f-number, then convert to the corresponding +world coordinate units. +For example, if you wish to simulate a 50mm lens at f/2.0 in +a scene modeled in meters, then you divide 50mm by 2.0 to get 25mm, +which corresponds to an effective aperture of 0.025 meters. The default aperture is 0, meaning no depth-of-field blurring. This option does not currently work with the .I ANIMATE @@ -575,7 +585,7 @@ to set whatever variables are important in the remote This requirement may be circumvented by substituting the .I on(1) command for -.I rsh(1) +.I ssh(1) using the .I RSH control variable, or by writing a custom remote execution script. @@ -599,5 +609,5 @@ is called if INTERPOLATE > 0 and/or MBLUR is assigned. Since most modern machines use IEEE floating point, this is not usually a problem, but it is something to keep in mind. .SH "SEE ALSO" -pfilt(1), pinterp(1), pmblur(1), rad(1), -ranimove(1), rpict(1), rsh(1), rtrace(1) +fieldcomb(1), pfilt(1), pinterp(1), pmblur(1), rad(1), +ran2tiff(1), ranimove(1), rpict(1), ssh(1), rtrace(1)
