--- ray/doc/man/man1/ranimate.1 2003/12/09 15:59:06 1.2 +++ ray/doc/man/man1/ranimate.1 2008/11/10 19:08:17 1.10 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: ranimate.1,v 1.2 2003/12/09 15:59:06 greg Exp $" +.\" RCSid "$Id: ranimate.1,v 1.10 2008/11/10 19:08:17 greg Exp $" .TH RANIMATE 1 6/24/98 RADIANCE .SH NAME ranimate - compute a RADIANCE animation @@ -157,7 +157,7 @@ how to adjust the exposure for each frame. As in .I pfilt, the exposure setting may be given either as a multiplier or as a -number of f-stop adjustments (eg. +2 or -1.5). +number of f\-stop adjustments (eg. +2 or \-1.5). Alternatively, a file name may be given, which .I ranimate will interpret as having one exposure value per line per frame, @@ -180,7 +180,7 @@ options of rpict, along with appropriate suffixes, and thus should contain a .I printf(3) style integer field to distinguish one frame number from another. -The final frames will use this name with a ".pic" suffix. +The final frames will use this name with a ".hdr" suffix. The default value is the assigned .I DIRECTORY followed by "/frame%03d". @@ -271,6 +271,10 @@ before it is executed. Normally, the transfer command does something such as convert the frames to another format and/or copy them to tape or some other destination device before removing them. +The +.I fieldcomb(1) +script may be used to conveniently combine fields into frames for +field-based animations. If this variable is not given, the final frames are left where they are. (See @@ -279,22 +283,22 @@ above.)\0 .TP .BR RSH The command to use instead of -.I rsh(1) +.I ssh(1) to execute commands remotely on another machine. The arguments and behavior of this program must be identical to the UNIX -.I rsh +.I ssh command, except that the .I -l option will always be used to specify an alternate user name rather than the .I "user@host" convention. -Th +The .I -l option may or may not appear, but the .I -n option will always be used, and the expected starting directory will be that of the remote user, just as with -.I rsh. +.I ssh. .TP .BR NEXTANIM This variable specifies the next @@ -352,14 +356,35 @@ If this number is less than 2, then bluring is perform only, resulting in greater noise than the combination of .I rpict and -.I pinterp used otherwise. +.I pinterp +used otherwise. (The default value for number of samples is 5.)\0 -The -.I pmblur(1) -command is used to generate the given number of additional views for +The default fraction is 0, meaning no motion blurring. +This option does not currently work with the +.I ANIMATE +variable, since pinterp only works for static environments. +.TP +.BR DBLUR +This variable specifies the aperture diameter for depth-of-field blurring, +in world units. +A number of samples may be given as a second argument, which controls the +number of additional frames computed and averaged together by +.I pinterp. +If this number is less than 2, then blurring is performed by +.I rpict +only, resulting in greater noise than the combination of +.I rpict +and .I pinterp -to average together. -The default value is 0, meaning no motion blurring. +used otherwise. +(The default value for number of samples is 5.)\0 +To simulate a particular camera's aperture, divide the focal length of +the lens by the f-number, then convert to the corresponding +world coordinate units. +For example, if you wish to simulate a 50mm lens at f/2.0 in +a scene modeled in meters, then you divide 50mm by 2.0 to get 25mm, +which corresponds to an effective aperture of 0.025 meters. +The default aperture is 0, meaning no depth-of-field blurring. This option does not currently work with the .I ANIMATE variable, since pinterp only works for static environments. @@ -464,7 +489,7 @@ If we only want to see what default values would use without actually executing anything, we can invoke it thus: .IP "" .2i -ranimate -n -e sample.ran +ranimate \-n \-e sample.ran .PP This will print the variables we have given as well as default values @@ -495,7 +520,7 @@ INTERP= 3 # render every fourth frame RES= 1024 # shoot for 1024x resolution MBLUR= .25 # apply camera motion blur EXP= anim1.exp # adjust exposure according to file -pfilt= -r .9 # use Gaussian filtering +pfilt= \-r .9 # use Gaussian filtering ARCHIVE= tar cf /dev/nrtape # save original renderings to tape .fi .PP @@ -503,7 +528,7 @@ Note the use of abbreviation for variable names. .SH FILES $(DIRECTORY)/STATUS animation status file $(DIRECTORY)/* other temporary files -$(BASENAME).pic final animation frames +$(BASENAME).hdr final animation frames .SH AUTHOR Greg Ward .SH BUGS @@ -560,7 +585,7 @@ to set whatever variables are important in the remote This requirement may be circumvented by substituting the .I on(1) command for -.I rsh(1) +.I ssh(1) using the .I RSH control variable, or by writing a custom remote execution script. @@ -584,5 +609,5 @@ is called if INTERPOLATE > 0 and/or MBLUR is assigned. Since most modern machines use IEEE floating point, this is not usually a problem, but it is something to keep in mind. .SH "SEE ALSO" -pfilt(1), pinterp(1), pmblur(1), rad(1), -ranimove(1), rpict(1), rsh(1), rtrace(1) +fieldcomb(1), pfilt(1), pinterp(1), pmblur(1), rad(1), +ran2tiff(1), ranimove(1), rpict(1), ssh(1), rtrace(1)
