root/radiance/ray/doc/man/man1/ranimate.1
Revision: 1.9
Committed: Tue Sep 4 17:36:41 2007 UTC (16 years, 9 months ago) by greg
Changes since 1.8: +4 -4 lines
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: ranimate.1,v 1.8 2006/04/18 04:50:43 greg Exp $"
2 .TH RANIMATE 1 6/24/98 RADIANCE
3 .SH NAME
4 ranimate - compute a RADIANCE animation
5 .SH SYNOPSIS
6 .B ranimate
7 [
8 .B \-s
9 ][
10 .B \-n
11 ][
12 .B \-e
13 ][
14 .B \-w
15 ]
16 .B ranfile
17 .SH DESCRIPTION
18 .I Ranimate
19 is an executive program that reads the given
20 .I ranfile
21 and makes appropriate calls to
22 .I rad(1),
23 .I rpict(1),
24 .I pinterp(1),
25 and/or
26 .I pfilt(1)
27 to render an animation.
28 Variables in
29 .I ranfile
30 indicate input files, process servers (execution hosts), output
31 directories and file names, and various other controls and options.
32 .PP
33 Normally, commands are echoed to the standard output as they are
34 executed.
35 The
36 .I \-s
37 option tells
38 .I ranimate
39 to do its work silently.
40 The
41 .I \-n
42 option tells
43 .I ranimate
44 not to take any action (ie. not to actually execute any commands).
45 The
46 .I \-e
47 option tells
48 .I ranimate
49 to explicate all variables used for the animation, including
50 default values not specified in the input file, and print them on
51 the standard output.
52 .PP
53 The
54 .I \-w
55 option turns off warnings about multiply and misassigned variables.
56 .PP
57 Normally,
58 .I ranimate
59 will produce one animation frame for each view given in the specified
60 view file.
61 If an animation has ended or been killed in an incomplete state, however,
62 .I ranimate
63 will attempt to pick up where the earlier process left off.
64 If the process is still running, or was started on another machine,
65 .I ranimate
66 will report this information and exit.
67 .PP
68 Animation variable assignments appear one per line in
69 .I ranfile.
70 The name of the variable is followed by an equals sign
71 ('=') and its value(s).
72 The end of line may be escaped with a backslash ('\\'), though it is
73 not usually necessary since additional variable values may be given
74 in multiple assignments.
75 Variables that should have only one value are given in upper case.
76 Variables that may have multiple values are given in lower case.
77 Variables may be abbreviated by their first three letters, except
78 for "host", which must have all four.
79 Comments in
80 .I ranfile
81 start with a pound sign ('#') and proceed to the end of line.
82 .PP
83 The animation variables, their interpretations and default values
84 are given below.
85 .TP 10n
86 .BR DIRECTORY
87 The name of the animation directory.
88 All temporary files generated during the animation will be placed in
89 this directory, which will be created by
90 .I ranimate
91 if it does not exist.
92 A file named "STATUS" will also be created there, and will contain current
93 information about the animation process.
94 This variable has no default value, and its setting is required.
95 .TP
96 .BR OCTREE
97 The name of the octree file for a static scene walk-through
98 animation.
99 There is no default value for this variable, and any
100 setting will be ignored if the
101 .I ANIMATE
102 variable is also set (see below).
103 .TP
104 .BR ANIMATE
105 The scene generation command for a dynamic animation.
106 This command, if given, will be executed with the frame number as the
107 final argument, and on its standard output it must produce
108 the complete octree for that frame.
109 Care must be taken that this command does not create any temporary files
110 that might collide with same-named files created by other
111 animation commands running in parallel.
112 Also, the command should produce no output to the standard error, unless
113 there is a fatal condition.
114 (I.e., switch all warnings off;
115 see the BUGS section, below.)\0
116 There is no default animation command, and either this variable or the
117 .I OCTREE
118 variable must be set.
119 .TP
120 .BR VIEWFILE
121 This variable names a file from which
122 .I ranimate
123 may extract the view for each frame in the animation.
124 This file should contain one valid view per frame, starting with
125 frame 1 on line 1, regardless of the setting of the
126 .I START
127 variable.
128 An exception is made for a view file with only a single view, which
129 is used for every frame of a dynamic scene animation.
130 This variable is required, and there is no default value.
131 .TP
132 .BR START
133 The initial frame number in this animation sequence.
134 The minimum value is 1, and if a later starting frame is given,
135 .I ranimate
136 assumes that the earlier frames are included in some other
137 .I ranfile,
138 which has been previously executed.
139 (See the
140 .I NEXTANIM
141 variable, below.)\0
142 The default value is 1.
143 .TP
144 .BR END
145 The final frame number in this sequence.
146 The minimum value is equal to the
147 .I START
148 frame,
149 and the default value is computed from the number of views in the
150 given
151 .I VIEWFILE.
152 .TP
153 .BR EXPOSURE
154 This variable tells
155 .I ranimate
156 how to adjust the exposure for each frame.
157 As in
158 .I pfilt,
159 the exposure setting may be given either as a multiplier or as a
160 number of f\-stop adjustments (eg. +2 or \-1.5).
161 Alternatively, a file name may be given, which
162 .I ranimate
163 will interpret as having one exposure value per line per frame,
164 beginning with frame 1 at line 1.
165 (See also the
166 .I VIEWFILE
167 variable, above.)\0
168 There is no default value for this variable.
169 If it is not given, an average level will be computed by
170 .I pfilt
171 for each frame.
172 .TP
173 .BR BASENAME
174 The base output file name for the final frames.
175 This string will be passed to the
176 .I \-o
177 and
178 .I \-z
179 options of rpict, along with appropriate suffixes,
180 and thus should contain a
181 .I printf(3)
182 style integer field to distinguish one frame number from another.
183 The final frames will use this name with a ".pic" suffix.
184 The default value is the assigned
185 .I DIRECTORY
186 followed by "/frame%03d".
187 .TP
188 .BR host
189 A host to use for command execution.
190 This variable may be assigned a host name, followed by an optional
191 number of parallel processes, followed by an optional
192 directory (relative to the user's home directory on that machine),
193 followed by an alternate user name.
194 Multiple
195 .I host
196 assignments may appear.
197 It is not advisable to specify more than one process on a single-CPU
198 host, as this just tends to slow things down.
199 The default value is "localhost", which starts a single process in
200 the current directory of the local machine.
201 .TP
202 .BR RIF
203 This variable specifies a
204 .I rad
205 input file to use as a source of rendering options and other
206 variable settings.
207 If given,
208 .I ranimate
209 will execute
210 .I rad
211 and create an options file to later pass to
212 .I rpict
213 or
214 .I rtrace.
215 Besides prepending the
216 .I render
217 variable,
218 .I ranimate
219 will also extract default settings for the common variables:
220 .I OCTREE,
221 .I RESOLUTION,
222 .I EXPOSURE
223 and
224 .I pfilt.
225 Following the file name, overriding variable settings may be given,
226 which will be passed to
227 .I rad
228 on the command line.
229 Settings with spaces in them should be enclosed in quotes.
230 The execution of
231 .I rad
232 will also update the contents of the octree, if necessary.
233 There is no default value for this variable.
234 .TP
235 .BR DISKSPACE
236 Specify the amount of disk space (in megabytes) available on the
237 destination file system for temporary file storage.
238 .I Ranimate
239 will coordinate its batch operations based on this amount of storage,
240 assuming that there is either enough additional space for all the
241 final frames, or that the given
242 .I TRANSFER
243 command will move the finished frames to some other location (see
244 below).
245 The default value is 100 megabytes.
246 .TP
247 .BR ARCHIVE
248 After each batch rendering is finished and checked for completeness,
249 .I ranimate
250 will execute the given command, passing the names of all the
251 original pictures and z-buffer files generated by
252 .I rpict.
253 (The command is executed in the destination directory, and file names
254 will be simple.)\0
255 Normally, the archive command copies the original files to a tape device
256 or somewhere that they can be retrieved in the event of failure in
257 the frame interpolation stages.
258 After the archive command has successfully completed, the original
259 renderings are removed.
260 There is no default value for this variable, meaning that the
261 original unfiltered frames will simply be removed.
262 Note that the last one or two rendered frames may not be copied, archived
263 or removed in case there is a another sequence picking up where this
264 one left off.
265 .TP
266 .BR TRANSFER
267 The command to transfer the completed animation frames.
268 The shell changes to the destination directory and appends
269 the names of all the finished frames to this command
270 before it is executed.
271 Normally, the transfer command does something such as convert the
272 frames to another format and/or copy them to tape or some other
273 destination device before removing them.
274 The
275 .I fieldcomb(1)
276 script may be used to conveniently combine fields into frames for
277 field-based animations.
278 If this variable is not given, the final frames are left where they
279 are.
280 (See
281 .I BASENAME,
282 above.)\0
283 .TP
284 .BR RSH
285 The command to use instead of
286 .I ssh(1)
287 to execute commands remotely on another machine.
288 The arguments and behavior of this program must be identical to the UNIX
289 .I ssh
290 command, except that the
291 .I -l
292 option will always be used to specify an alternate user name rather than the
293 .I "user@host"
294 convention.
295 The
296 .I -l
297 option may or may not appear, but the
298 .I -n
299 option will always be used, and the expected starting directory will
300 be that of the remote user, just as with
301 .I ssh.
302 .TP
303 .BR NEXTANIM
304 This variable specifies the next
305 .I ranfile
306 to use after this sequence is completed.
307 This offers a convenient means to continue an animation that
308 requires different control options in different segments.
309 It is important in this case to correctly set the
310 .I START
311 and
312 .I END
313 variables in each
314 .I ranfile
315 so that the segments do not overlap frames.
316 .TP
317 .BR OVERSAMPLE
318 This variable sets the multiplier of the original image size
319 relative to the final size given by the
320 .I RESOLUTION
321 variable.
322 This determines the quality of anti-aliasing in the final frames.
323 A value of 1 means no anti-aliasing, and a value of 3 produces very
324 good anti-aliasing.
325 The default value is 2.
326 (A fractional value may be used for previews, causing low
327 resolution frames with large, blocky pixels to be produced.)\0
328 .TP
329 .BR INTERPOLATE
330 This variable sets the number of frames to interpolate between each
331 rendered frame in a static scene walk-through.
332 Z-buffers for each rendered frame will be generated by
333 .I rpict,
334 and
335 .I pinterp
336 will be called to perform the actual "tweening."
337 This results in a potentially large savings in rendering time, but
338 should be used with caution since certain information may be lost or
339 inaccurate, such as specular highlights and reflections, and objects
340 may even break apart if too few renderings are used to interpolate
341 too much motion.
342 The default value for this variable is 0, meaning no interpolation.
343 Interpolation is also switched off if the
344 .I ANIMATE
345 variable is specified.
346 .TP
347 .BR MBLUR
348 This variable specifies the fraction of a frame time that the shutter
349 is simulated as being open for motion blur.
350 A number of samples may be given as a second argument, which
351 controls the number of additional frames computed and averaged
352 together by
353 .I pinterp.
354 If this number is less than 2, then bluring is performed by
355 .I rpict
356 only, resulting in greater noise than the combination of
357 .I rpict
358 and
359 .I pinterp
360 used otherwise.
361 (The default value for number of samples is 5.)\0
362 The default fraction is 0, meaning no motion blurring.
363 This option does not currently work with the
364 .I ANIMATE
365 variable, since pinterp only works for static environments.
366 .TP
367 .BR DBLUR
368 This variable specifies the aperture diameter for depth-of-field blurring,
369 in world units.
370 A number of samples may be given as a second argument, which controls the
371 number of additional frames computed and averaged together by
372 .I pinterp.
373 If this number is less than 2, then blurring is performed by
374 .I rpict
375 only, resulting in greater noise than the combination of
376 .I rpict
377 and
378 .I pinterp
379 used otherwise.
380 (The default value for number of samples is 5.)\0
381 To simulate a particular camera's aperture, divide the focal length of
382 the lens by the f-number, then convert to the corresponding
383 world coordinate units.
384 For example, if you wish to simulate a 50mm lens at f/2.0 in
385 a scene modeled in meters, then you divide 50mm by 2.0 to get 25mm,
386 which corresponds to an effective aperture of 0.025 meters.
387 The default aperture is 0, meaning no depth-of-field blurring.
388 This option does not currently work with the
389 .I ANIMATE
390 variable, since pinterp only works for static environments.
391 .TP
392 .BR RTRACE
393 This boolean variable tells
394 .I ranimate
395 whether or not to employ
396 .I rtrace
397 during frame interpolation using the
398 .I \-fr
399 option to
400 .I pinterp.
401 If set to True, then the same rendering options and static octree
402 are passed to
403 .I rtrace
404 as are normally used by
405 .I rpict.
406 The default value is False.
407 Note that this variable only applies to static environment
408 walk-throughs (i.e., no
409 .I ANIMATE
410 command).
411 .TP
412 .BR RESOLUTION
413 This variable specifies the desired final picture resolution.
414 If only a single number is given, this value will be used for both
415 the horizontal and vertical picture dimensions.
416 If two numbers are given, the first is the horizontal resolution and
417 the second is the vertical resolution.
418 If three numbers are given, the third is taken as the pixel aspect
419 ratio for the final picture (a real value).
420 If the pixel aspect ratio is zero, the exact dimensions given will
421 be those produced.
422 Otherwise, they will be used as a frame in which the final image
423 must fit.
424 The default value for this variable is 640.
425 .TP
426 .BR render
427 This variable may be used to specify additional options to
428 .I rpict
429 or
430 .I rtrace.
431 These options will appear after the options set automatically by
432 .I rad,
433 and thus will override the default values.
434 .TP
435 .BR pinterp
436 This variable may be used to specify additional options to
437 .I pinterp,
438 which is used to interpolate frames for a static scene walk-through.
439 (See the
440 .I pinterp
441 man page, and the
442 .I INTERPOLATE
443 variable.)\0
444 Do not use this variable to set the
445 .I pinterp
446 .I \-fr
447 option, but use the
448 .I RTRACE
449 setting instead.
450 .TP
451 .BR pfilt
452 This variable may be used to specify additional options to
453 .I pfilt.
454 If this variable is given in the
455 .I ranfile,
456 then
457 .I pfilt
458 will always be used.
459 (Normally,
460 .I pfilt
461 is called only if
462 .I pinterp
463 is not needed or automatic exposure is required.)\0
464 See the
465 .I pfilt
466 manual page for details.
467 .SH EXAMPLES
468 A minimal input file for
469 .I ranimate
470 might look like this:
471 .IP "" .3i
472 .nf
473 ::::::::::
474 sample.ran
475 ::::::::::
476 # The rad input file for our static scene:
477 RIF= tutor.rif
478 # The spool directory:
479 DIRECTORY= anim1
480 # The view file containing one view per frame:
481 VIEWFILE= anim1.vf
482 # The amount of temporary disk space available:
483 DISKSPACE= 50 # megabytes
484 .fi
485 .PP
486 Note that most of the variables are not set in this file.
487 If we only want to see what default values
488 .I ranimate
489 would use without actually executing anything, we can invoke it
490 thus:
491 .IP "" .2i
492 ranimate \-n \-e sample.ran
493 .PP
494 This will print the variables we have given as well as default
495 values
496 .I ranimate
497 has assigned for us.
498 Also, we will see the list of commands that
499 .I ranimate
500 would have executed had the
501 .I \-n
502 option not been present.
503 .PP
504 Usually, we execute
505 .I ranimate
506 in the background, redirecting the standard output and standard
507 error to a file:
508 .IP "" .2i
509 ranimate sample.ran >& sample.err &
510 .PP
511 If we decide that the default values
512 .I ranimate
513 has chosen for our variables are not all appropriate, we can add
514 some more assignments to the file:
515 .IP "" .3i
516 .nf
517 host= rays 3 ~greg/obj/tutor ray # execute as ray on multi-host "rays"
518 host= thishost # execute one copy on this host also
519 INTERP= 3 # render every fourth frame
520 RES= 1024 # shoot for 1024x resolution
521 MBLUR= .25 # apply camera motion blur
522 EXP= anim1.exp # adjust exposure according to file
523 pfilt= \-r .9 # use Gaussian filtering
524 ARCHIVE= tar cf /dev/nrtape # save original renderings to tape
525 .fi
526 .PP
527 Note the use of abbreviation for variable names.
528 .SH FILES
529 $(DIRECTORY)/STATUS animation status file
530 $(DIRECTORY)/* other temporary files
531 $(BASENAME).pic final animation frames
532 .SH AUTHOR
533 Greg Ward
534 .SH BUGS
535 Due to the difficulty of controlling processes on multiple execution
536 hosts, the
537 .I \-n
538 option of
539 .I ranimate
540 is not useful in the same way as
541 .I rad
542 for generating a script of executable commands to render the
543 sequence.
544 It may give an idea of the sequence of events, but certain temporary
545 files and so forth will not be in the correct state if the user
546 attempts to create a separate batch script.
547 .PP
548 If multiple processors are available on a given host and the
549 .I RTRACE
550 variable is set to True, then the
551 .I \-PP
552 option of
553 .I rtrace
554 should be employed, but it is not.
555 There is no easy way around this problem, but it has only minor
556 consequences in most cases.
557 (The
558 .I \-PP
559 option is used for
560 .I rpict,
561 however.)\0
562 .I
563 .PP
564 The current implementation of the remote shell does not return the
565 exit status of the remote process, which makes it difficult to
566 determine for sure if there has been a serious error or not.
567 Because of this,
568 .I ranimate
569 normally turns off warnings on all rendering processes, and takes
570 any output to standard error from a remote command as a sign that a
571 fatal error has occurred.
572 (This also precludes the use of the
573 .I \-t
574 option to report rendering progress.)\0
575 If the error was caused by a process server going down, the server
576 is removed from the active list and frame recovery takes place.
577 Otherwise,
578 .I ranimate
579 quits at that point in the animation.
580 .PP
581 The current execution environment, in particular the RAYPATH variable,
582 will not be passed during remote command execution, so it is necessary
583 to set whatever variables are important in the remote startup script
584 (e.g., ".cshrc" for the C-shell).
585 This requirement may be circumvented by substituting the
586 .I on(1)
587 command for
588 .I ssh(1)
589 using the
590 .I RSH
591 control variable, or by writing a custom remote execution script.
592 .PP
593 If a different remote user name is used,
594 .I ranimate
595 first attempts to change to the original user's directory with a
596 command of the form
597 .I "cd \~uname".
598 This works under
599 .I csh(1),
600 but may fail under other shells such as
601 .I sh(1).
602 .PP
603 If multiple hosts with different floating point formats are used,
604 .I pinterp
605 will fail because the Z-buffer files will be inconsistent.
606 (Recall that
607 .I pinterp
608 is called if INTERPOLATE > 0 and/or MBLUR is assigned.)\0
609 Since most modern machines use IEEE floating point, this is not
610 usually a problem, but it is something to keep in mind.
611 .SH "SEE ALSO"
612 fieldcomb(1), pfilt(1), pinterp(1), pmblur(1), rad(1),
613 ran2tiff(1), ranimove(1), rpict(1), ssh(1), rtrace(1)
