root/radiance/ray/doc/man/man1/ranimate.1
Revision: 1.10
Committed: Mon Nov 10 19:08:17 2008 UTC (16 years, 5 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1, rad5R3
# User Rev Content
1 greg 1.10 .\" RCSid "$Id: ranimate.1,v 1.9 2007/09/04 17:36:41 greg Exp $"
2 greg 1.1 .TH RANIMATE 1 6/24/98 RADIANCE
3     .SH NAME
4     ranimate - compute a RADIANCE animation
5     .SH SYNOPSIS
6     .B ranimate
7     [
8     .B \-s
9     ][
10     .B \-n
11     ][
12     .B \-e
13     ][
14     .B \-w
15     ]
16     .B ranfile
17     .SH DESCRIPTION
18     .I Ranimate
19     is an executive program that reads the given
20     .I ranfile
21     and makes appropriate calls to
22     .I rad(1),
23     .I rpict(1),
24     .I pinterp(1),
25     and/or
26     .I pfilt(1)
27     to render an animation.
28     Variables in
29     .I ranfile
30     indicate input files, process servers (execution hosts), output
31     directories and file names, and various other controls and options.
32     .PP
33     Normally, commands are echoed to the standard output as they are
34     executed.
35     The
36     .I \-s
37     option tells
38     .I ranimate
39     to do its work silently.
40     The
41     .I \-n
42     option tells
43     .I ranimate
44     not to take any action (ie. not to actually execute any commands).
45     The
46     .I \-e
47     option tells
48     .I ranimate
49     to explicate all variables used for the animation, including
50     default values not specified in the input file, and print them on
51     the standard output.
52     .PP
53     The
54     .I \-w
55     option turns off warnings about multiply and misassigned variables.
56     .PP
57     Normally,
58     .I ranimate
59     will produce one animation frame for each view given in the specified
60     view file.
61     If an animation has ended or been killed in an incomplete state, however,
62     .I ranimate
63     will attempt to pick up where the earlier process left off.
64     If the process is still running, or was started on another machine,
65     .I ranimate
66     will report this information and exit.
67     .PP
68     Animation variable assignments appear one per line in
69     .I ranfile.
70     The name of the variable is followed by an equals sign
71     ('=') and its value(s).
72     The end of line may be escaped with a backslash ('\\'), though it is
73     not usually necessary since additional variable values may be given
74     in multiple assignments.
75     Variables that should have only one value are given in upper case.
76     Variables that may have multiple values are given in lower case.
77     Variables may be abbreviated by their first three letters, except
78     for "host", which must have all four.
79     Comments in
80     .I ranfile
81     start with a pound sign ('#') and proceed to the end of line.
82     .PP
83     The animation variables, their interpretations and default values
84     are given below.
85     .TP 10n
86     .BR DIRECTORY
87     The name of the animation directory.
88     All temporary files generated during the animation will be placed in
89     this directory, which will be created by
90     .I ranimate
91     if it does not exist.
92     A file named "STATUS" will also be created there, and will contain current
93     information about the animation process.
94     This variable has no default value, and its setting is required.
95     .TP
96     .BR OCTREE
97     The name of the octree file for a static scene walk-through
98     animation.
99     There is no default value for this variable, and any
100     setting will be ignored if the
101     .I ANIMATE
102     variable is also set (see below).
103     .TP
104     .BR ANIMATE
105     The scene generation command for a dynamic animation.
106     This command, if given, will be executed with the frame number as the
107     final argument, and on its standard output it must produce
108     the complete octree for that frame.
109     Care must be taken that this command does not create any temporary files
110     that might collide with same-named files created by other
111     animation commands running in parallel.
112     Also, the command should produce no output to the standard error, unless
113     there is a fatal condition.
114     (I.e., switch all warnings off;
115     see the BUGS section, below.)\0
116     There is no default animation command, and either this variable or the
117     .I OCTREE
118     variable must be set.
119     .TP
120     .BR VIEWFILE
121     This variable names a file from which
122     .I ranimate
123     may extract the view for each frame in the animation.
124     This file should contain one valid view per frame, starting with
125     frame 1 on line 1, regardless of the setting of the
126     .I START
127     variable.
128     An exception is made for a view file with only a single view, which
129     is used for every frame of a dynamic scene animation.
130     This variable is required, and there is no default value.
131     .TP
132     .BR START
133     The initial frame number in this animation sequence.
134     The minimum value is 1, and if a later starting frame is given,
135     .I ranimate
136     assumes that the earlier frames are included in some other
137     .I ranfile,
138     which has been previously executed.
139     (See the
140     .I NEXTANIM
141     variable, below.)\0
142     The default value is 1.
143     .TP
144     .BR END
145     The final frame number in this sequence.
146     The minimum value is equal to the
147     .I START
148     frame,
149     and the default value is computed from the number of views in the
150     given
151     .I VIEWFILE.
152     .TP
153     .BR EXPOSURE
154     This variable tells
155     .I ranimate
156     how to adjust the exposure for each frame.
157     As in
158     .I pfilt,
159     the exposure setting may be given either as a multiplier or as a
160 greg 1.9 number of f\-stop adjustments (eg. +2 or \-1.5).
161 greg 1.1 Alternatively, a file name may be given, which
162     .I ranimate
163     will interpret as having one exposure value per line per frame,
164     beginning with frame 1 at line 1.
165     (See also the
166     .I VIEWFILE
167     variable, above.)\0
168     There is no default value for this variable.
169     If it is not given, an average level will be computed by
170     .I pfilt
171     for each frame.
172     .TP
173     .BR BASENAME
174     The base output file name for the final frames.
175     This string will be passed to the
176     .I \-o
177     and
178     .I \-z
179     options of rpict, along with appropriate suffixes,
180     and thus should contain a
181     .I printf(3)
182     style integer field to distinguish one frame number from another.
183 greg 1.10 The final frames will use this name with a ".hdr" suffix.
184 greg 1.1 The default value is the assigned
185     .I DIRECTORY
186     followed by "/frame%03d".
187     .TP
188     .BR host
189     A host to use for command execution.
190     This variable may be assigned a host name, followed by an optional
191     number of parallel processes, followed by an optional
192     directory (relative to the user's home directory on that machine),
193     followed by an alternate user name.
194     Multiple
195     .I host
196     assignments may appear.
197     It is not advisable to specify more than one process on a single-CPU
198     host, as this just tends to slow things down.
199     The default value is "localhost", which starts a single process in
200     the current directory of the local machine.
201     .TP
202     .BR RIF
203     This variable specifies a
204     .I rad
205     input file to use as a source of rendering options and other
206     variable settings.
207     If given,
208     .I ranimate
209     will execute
210     .I rad
211     and create an options file to later pass to
212     .I rpict
213     or
214     .I rtrace.
215     Besides prepending the
216     .I render
217     variable,
218     .I ranimate
219     will also extract default settings for the common variables:
220     .I OCTREE,
221     .I RESOLUTION,
222     .I EXPOSURE
223     and
224     .I pfilt.
225     Following the file name, overriding variable settings may be given,
226     which will be passed to
227     .I rad
228     on the command line.
229     Settings with spaces in them should be enclosed in quotes.
230     The execution of
231     .I rad
232     will also update the contents of the octree, if necessary.
233     There is no default value for this variable.
234     .TP
235     .BR DISKSPACE
236     Specify the amount of disk space (in megabytes) available on the
237     destination file system for temporary file storage.
238     .I Ranimate
239     will coordinate its batch operations based on this amount of storage,
240     assuming that there is either enough additional space for all the
241     final frames, or that the given
242     .I TRANSFER
243     command will move the finished frames to some other location (see
244     below).
245     The default value is 100 megabytes.
246     .TP
247     .BR ARCHIVE
248     After each batch rendering is finished and checked for completeness,
249     .I ranimate
250     will execute the given command, passing the names of all the
251     original pictures and z-buffer files generated by
252     .I rpict.
253     (The command is executed in the destination directory, and file names
254     will be simple.)\0
255     Normally, the archive command copies the original files to a tape device
256     or somewhere that they can be retrieved in the event of failure in
257     the frame interpolation stages.
258     After the archive command has successfully completed, the original
259     renderings are removed.
260     There is no default value for this variable, meaning that the
261     original unfiltered frames will simply be removed.
262     Note that the last one or two rendered frames may not be copied, archived
263     or removed in case there is a another sequence picking up where this
264     one left off.
265     .TP
266     .BR TRANSFER
267     The command to transfer the completed animation frames.
268     The shell changes to the destination directory and appends
269     the names of all the finished frames to this command
270     before it is executed.
271     Normally, the transfer command does something such as convert the
272     frames to another format and/or copy them to tape or some other
273     destination device before removing them.
274 greg 1.6 The
275     .I fieldcomb(1)
276     script may be used to conveniently combine fields into frames for
277     field-based animations.
278 greg 1.1 If this variable is not given, the final frames are left where they
279     are.
280     (See
281     .I BASENAME,
282     above.)\0
283     .TP
284     .BR RSH
285     The command to use instead of
286 greg 1.5 .I ssh(1)
287 greg 1.1 to execute commands remotely on another machine.
288     The arguments and behavior of this program must be identical to the UNIX
289 greg 1.5 .I ssh
290 greg 1.1 command, except that the
291     .I -l
292     option will always be used to specify an alternate user name rather than the
293     .I "user@host"
294     convention.
295 greg 1.8 The
296 greg 1.1 .I -l
297     option may or may not appear, but the
298     .I -n
299     option will always be used, and the expected starting directory will
300     be that of the remote user, just as with
301 greg 1.5 .I ssh.
302 greg 1.1 .TP
303     .BR NEXTANIM
304     This variable specifies the next
305     .I ranfile
306     to use after this sequence is completed.
307     This offers a convenient means to continue an animation that
308     requires different control options in different segments.
309     It is important in this case to correctly set the
310     .I START
311     and
312     .I END
313     variables in each
314     .I ranfile
315     so that the segments do not overlap frames.
316     .TP
317     .BR OVERSAMPLE
318     This variable sets the multiplier of the original image size
319     relative to the final size given by the
320     .I RESOLUTION
321     variable.
322     This determines the quality of anti-aliasing in the final frames.
323     A value of 1 means no anti-aliasing, and a value of 3 produces very
324     good anti-aliasing.
325     The default value is 2.
326     (A fractional value may be used for previews, causing low
327     resolution frames with large, blocky pixels to be produced.)\0
328     .TP
329     .BR INTERPOLATE
330     This variable sets the number of frames to interpolate between each
331     rendered frame in a static scene walk-through.
332     Z-buffers for each rendered frame will be generated by
333     .I rpict,
334     and
335     .I pinterp
336     will be called to perform the actual "tweening."
337     This results in a potentially large savings in rendering time, but
338     should be used with caution since certain information may be lost or
339     inaccurate, such as specular highlights and reflections, and objects
340     may even break apart if too few renderings are used to interpolate
341     too much motion.
342     The default value for this variable is 0, meaning no interpolation.
343     Interpolation is also switched off if the
344     .I ANIMATE
345     variable is specified.
346     .TP
347     .BR MBLUR
348     This variable specifies the fraction of a frame time that the shutter
349     is simulated as being open for motion blur.
350     A number of samples may be given as a second argument, which
351     controls the number of additional frames computed and averaged
352     together by
353     .I pinterp.
354     If this number is less than 2, then bluring is performed by
355     .I rpict
356     only, resulting in greater noise than the combination of
357     .I rpict
358     and
359 greg 1.3 .I pinterp
360     used otherwise.
361 greg 1.1 (The default value for number of samples is 5.)\0
362 greg 1.3 The default fraction is 0, meaning no motion blurring.
363     This option does not currently work with the
364     .I ANIMATE
365     variable, since pinterp only works for static environments.
366     .TP
367     .BR DBLUR
368     This variable specifies the aperture diameter for depth-of-field blurring,
369     in world units.
370     A number of samples may be given as a second argument, which controls the
371     number of additional frames computed and averaged together by
372     .I pinterp.
373     If this number is less than 2, then blurring is performed by
374     .I rpict
375     only, resulting in greater noise than the combination of
376     .I rpict
377     and
378 greg 1.1 .I pinterp
379 greg 1.3 used otherwise.
380     (The default value for number of samples is 5.)\0
381 greg 1.4 To simulate a particular camera's aperture, divide the focal length of
382     the lens by the f-number, then convert to the corresponding
383     world coordinate units.
384     For example, if you wish to simulate a 50mm lens at f/2.0 in
385     a scene modeled in meters, then you divide 50mm by 2.0 to get 25mm,
386     which corresponds to an effective aperture of 0.025 meters.
387 greg 1.3 The default aperture is 0, meaning no depth-of-field blurring.
388 greg 1.1 This option does not currently work with the
389     .I ANIMATE
390     variable, since pinterp only works for static environments.
391     .TP
392     .BR RTRACE
393     This boolean variable tells
394     .I ranimate
395     whether or not to employ
396     .I rtrace
397     during frame interpolation using the
398     .I \-fr
399     option to
400     .I pinterp.
401     If set to True, then the same rendering options and static octree
402     are passed to
403     .I rtrace
404     as are normally used by
405     .I rpict.
406     The default value is False.
407     Note that this variable only applies to static environment
408     walk-throughs (i.e., no
409     .I ANIMATE
410     command).
411     .TP
412     .BR RESOLUTION
413     This variable specifies the desired final picture resolution.
414     If only a single number is given, this value will be used for both
415     the horizontal and vertical picture dimensions.
416     If two numbers are given, the first is the horizontal resolution and
417     the second is the vertical resolution.
418     If three numbers are given, the third is taken as the pixel aspect
419     ratio for the final picture (a real value).
420     If the pixel aspect ratio is zero, the exact dimensions given will
421     be those produced.
422     Otherwise, they will be used as a frame in which the final image
423     must fit.
424     The default value for this variable is 640.
425     .TP
426     .BR render
427     This variable may be used to specify additional options to
428     .I rpict
429     or
430     .I rtrace.
431     These options will appear after the options set automatically by
432     .I rad,
433     and thus will override the default values.
434     .TP
435     .BR pinterp
436     This variable may be used to specify additional options to
437     .I pinterp,
438     which is used to interpolate frames for a static scene walk-through.
439     (See the
440     .I pinterp
441     man page, and the
442     .I INTERPOLATE
443     variable.)\0
444     Do not use this variable to set the
445     .I pinterp
446     .I \-fr
447     option, but use the
448     .I RTRACE
449     setting instead.
450     .TP
451     .BR pfilt
452     This variable may be used to specify additional options to
453     .I pfilt.
454     If this variable is given in the
455     .I ranfile,
456     then
457     .I pfilt
458     will always be used.
459     (Normally,
460     .I pfilt
461     is called only if
462     .I pinterp
463     is not needed or automatic exposure is required.)\0
464     See the
465     .I pfilt
466     manual page for details.
467     .SH EXAMPLES
468     A minimal input file for
469     .I ranimate
470     might look like this:
471     .IP "" .3i
472     .nf
473     ::::::::::
474     sample.ran
475     ::::::::::
476     # The rad input file for our static scene:
477     RIF= tutor.rif
478     # The spool directory:
479     DIRECTORY= anim1
480     # The view file containing one view per frame:
481     VIEWFILE= anim1.vf
482     # The amount of temporary disk space available:
483     DISKSPACE= 50 # megabytes
484     .fi
485     .PP
486     Note that most of the variables are not set in this file.
487     If we only want to see what default values
488     .I ranimate
489     would use without actually executing anything, we can invoke it
490     thus:
491     .IP "" .2i
492 greg 1.9 ranimate \-n \-e sample.ran
493 greg 1.1 .PP
494     This will print the variables we have given as well as default
495     values
496     .I ranimate
497     has assigned for us.
498     Also, we will see the list of commands that
499     .I ranimate
500     would have executed had the
501     .I \-n
502     option not been present.
503     .PP
504     Usually, we execute
505     .I ranimate
506     in the background, redirecting the standard output and standard
507     error to a file:
508     .IP "" .2i
509     ranimate sample.ran >& sample.err &
510     .PP
511     If we decide that the default values
512     .I ranimate
513     has chosen for our variables are not all appropriate, we can add
514     some more assignments to the file:
515     .IP "" .3i
516     .nf
517     host= rays 3 ~greg/obj/tutor ray # execute as ray on multi-host "rays"
518     host= thishost # execute one copy on this host also
519     INTERP= 3 # render every fourth frame
520     RES= 1024 # shoot for 1024x resolution
521     MBLUR= .25 # apply camera motion blur
522     EXP= anim1.exp # adjust exposure according to file
523 greg 1.9 pfilt= \-r .9 # use Gaussian filtering
524 greg 1.1 ARCHIVE= tar cf /dev/nrtape # save original renderings to tape
525     .fi
526     .PP
527     Note the use of abbreviation for variable names.
528     .SH FILES
529     $(DIRECTORY)/STATUS animation status file
530     $(DIRECTORY)/* other temporary files
531 greg 1.10 $(BASENAME).hdr final animation frames
532 greg 1.1 .SH AUTHOR
533     Greg Ward
534     .SH BUGS
535     Due to the difficulty of controlling processes on multiple execution
536     hosts, the
537     .I \-n
538     option of
539     .I ranimate
540     is not useful in the same way as
541     .I rad
542     for generating a script of executable commands to render the
543     sequence.
544     It may give an idea of the sequence of events, but certain temporary
545     files and so forth will not be in the correct state if the user
546     attempts to create a separate batch script.
547     .PP
548     If multiple processors are available on a given host and the
549     .I RTRACE
550     variable is set to True, then the
551     .I \-PP
552     option of
553     .I rtrace
554     should be employed, but it is not.
555     There is no easy way around this problem, but it has only minor
556     consequences in most cases.
557     (The
558     .I \-PP
559     option is used for
560     .I rpict,
561     however.)\0
562     .I
563     .PP
564     The current implementation of the remote shell does not return the
565     exit status of the remote process, which makes it difficult to
566     determine for sure if there has been a serious error or not.
567     Because of this,
568     .I ranimate
569     normally turns off warnings on all rendering processes, and takes
570     any output to standard error from a remote command as a sign that a
571     fatal error has occurred.
572     (This also precludes the use of the
573     .I \-t
574     option to report rendering progress.)\0
575     If the error was caused by a process server going down, the server
576     is removed from the active list and frame recovery takes place.
577     Otherwise,
578     .I ranimate
579     quits at that point in the animation.
580     .PP
581     The current execution environment, in particular the RAYPATH variable,
582     will not be passed during remote command execution, so it is necessary
583     to set whatever variables are important in the remote startup script
584     (e.g., ".cshrc" for the C-shell).
585     This requirement may be circumvented by substituting the
586     .I on(1)
587     command for
588 greg 1.5 .I ssh(1)
589 greg 1.1 using the
590     .I RSH
591     control variable, or by writing a custom remote execution script.
592     .PP
593     If a different remote user name is used,
594     .I ranimate
595     first attempts to change to the original user's directory with a
596     command of the form
597     .I "cd \~uname".
598     This works under
599     .I csh(1),
600     but may fail under other shells such as
601     .I sh(1).
602     .PP
603     If multiple hosts with different floating point formats are used,
604     .I pinterp
605     will fail because the Z-buffer files will be inconsistent.
606     (Recall that
607     .I pinterp
608     is called if INTERPOLATE > 0 and/or MBLUR is assigned.)\0
609     Since most modern machines use IEEE floating point, this is not
610     usually a problem, but it is something to keep in mind.
611     .SH "SEE ALSO"
612 greg 1.6 fieldcomb(1), pfilt(1), pinterp(1), pmblur(1), rad(1),
613 greg 1.7 ran2tiff(1), ranimove(1), rpict(1), ssh(1), rtrace(1)
