1 |
.\" RCSid "$Id: ran2tiff.1,v 1.1 2005/09/17 05:14:14 greg Exp $" |
2 |
.TH RAN2TIFF 1 9/16/2005 RADIANCE |
3 |
.SH NAME |
4 |
ran2tiff - expose and convert a RADIANCE animation to TIFF frames |
5 |
.SH SYNOPSIS |
6 |
.B ran2tiff |
7 |
8 |
.B "-W prev_frame_wt" |
9 |
10 |
.B "-H histo" |
11 |
12 |
.B "-D dir" |
13 |
14 |
15 |
.B "pcond opts" |
16 |
17 |
18 |
.B "ra_tiff opts" |
19 |
20 |
.B "frame1.pic frame2.pic .." |
21 |
.SH DESCRIPTION |
22 |
.I Ran2tiff |
23 |
takes an animated sequence of Radiance pictures and converts them by calling |
24 |
.I pcond(1) |
25 |
and |
26 |
.I ra_tiff(1) |
27 |
in such a way that exposure changes gradually |
28 |
from one frame to the next. |
29 |
It accomplishes this by computing a histogram for each image and |
30 |
blending it with a weighted histogram from the previous frame, |
31 |
where the weight is set by the |
32 |
.I \-W |
33 |
option, or 0.9 by default. |
34 |
A value of 0.5 would mean that the previous frame carries 1/2 the weight |
35 |
of the current one, and the frame before that 1/4, 1/8 before that, |
36 |
and so on. |
37 |
.PP |
38 |
The |
39 |
.I \-H |
40 |
option specifies a histogram file to be used to ensure continuous |
41 |
exposure between the current sequence and one before it. |
42 |
If the file does not exist, it will be created at the end of |
43 |
the conversion. |
44 |
If it does exist, its contents will be used as the histogram |
45 |
at the end of the previous sequence. |
46 |
.PP |
47 |
The |
48 |
.I \-D |
49 |
option may be used to specify an output directory for the resulting |
50 |
TIFF frames. |
51 |
Otherwise, the current directory will be used. |
52 |
The output file names will correspond to the input names, but |
53 |
with a ".tif" suffix. |
54 |
.PP |
55 |
Ran2tiff also accepts the standard options for |
56 |
.I pcond |
57 |
and |
58 |
.I ra_tiff, |
59 |
though output to LogLuv TIFF formats is not supported. |
60 |
(There would be no point in adjusting the exposure if the output were HDR.)\0 |
61 |
.SH EXAMPLE |
62 |
To convert a sequence of frames using a rapid human exposure response |
63 |
and LZW compression on the output: |
64 |
.IP "" .2i |
65 |
ran2tiff \-W 0.7 \-h \-z frame*.pic |
66 |
.PP |
67 |
Similar to |
68 |
.I fieldcomb(1), |
69 |
this program works well with the "TRANSFER" facility of |
70 |
.I ranimate(1). |
71 |
.SH AUTHOR |
72 |
Greg Ward |
73 |
.SH "SEE ALSO" |
74 |
fieldcomb(1), getinfo(1), pcond(1), pfilt(1), phisto(1), |
75 |
ra_tiff(1), ranimate(1), rpict(1) |
