| 1 |
.\" RCSid "$Id$"
| 2 |
.TH RAD2MGF 1 5/15/95 RADIANCE
| 3 |
.SH NAME
| 4 |
rad2mgf - convert RADIANCE scene description to Materials and Geometry Format
| 5 |
.SH SYNOPSIS
| 6 |
.B rad2mgf
| 7 |
| 8 |
.B \-dU
| 9 |
| 10 |
| 11 |
.B input ..
| 12 |
| 13 |
.SH DESCRIPTION
| 14 |
.I Rad2mgf
| 15 |
converts one or more RADIANCE scene files
| 16 |
to the Materials and Geometry Format (MGF).
| 17 |
Input units are specified with the
| 18 |
.I \-mU
| 19 |
option, where
| 20 |
.I U
| 21 |
is one of 'm' (meters), 'c' (centimeters), 'f' (feet) or 'i'
| 22 |
(inches).
| 23 |
The assumed unit is meters, which is the required output unit for
| 24 |
MGF (thus the need to know).
| 25 |
If the input dimensions are in none of these units, then the user
| 26 |
should apply
| 27 |
.I xform(1)
| 28 |
with the
| 29 |
.I \-s
| 30 |
option to bring the units into line prior to translation.
| 31 |
.PP
| 32 |
The MGF material names and properties
| 33 |
for the surfaces will be those assigned in RADIANCE.
| 34 |
If a referenced material has not been defined, then its name will
| 35 |
be invoked in the MGF output without definition, and the description
| 36 |
will be incomplete.
| 37 |
.SH LIMITATIONS
| 38 |
Although MGF supports all of the geometric types and the most
| 39 |
common material types used in RADIANCE, there is currently no
| 40 |
support for advanced BRDF materials, patterns, textures or mixtures.
| 41 |
Also, the special types "source" and "antimatter" are not supported,
| 42 |
and all light source materials are converted to simple diffuse emitters
| 43 |
(except "illum" materials, which are converted to their alternates).
| 44 |
These primitives are reproduced as comments in the output and
| 45 |
must be replaced manually if necessary.
| 46 |
.PP
| 47 |
The RADIANCE "instance" type is treated specially.
| 48 |
.I Rad2mgf
| 49 |
converts each instance to an MGF include statement, using the corresponding
| 50 |
transformation and a file name derived from the octree name.
| 51 |
(The original octree suffix is replaced by ".mgf".)\0
| 52 |
For this to work, the user must separately create the referenced
| 53 |
MGF files from the original RADIANCE descriptions.
| 54 |
The description file names can usually be determined using the
| 55 |
.I getinfo(1)
| 56 |
command run on the octrees in question.
| 57 |
.SH EXAMPLE
| 58 |
To convert three RADIANCE files (in feet) to one MGF file:
| 59 |
.IP "" .2i
| 60 |
rad2mgf -df file1.rad file2.rad file3.rad > scene.mgf
| 61 |
.PP
| 62 |
To translate a RADIANCE materials file to MGF:
| 63 |
.IP "" .2i
| 64 |
rad2mgf materials.rad > materials.mgf
| 65 |
.SH AUTHOR
| 66 |
Greg Ward
| 67 |
.SH "SEE ALSO"
| 68 |
getinfo(1), ies2rad(1), mgf2meta(1), mgf2rad(1), obj2rad(1), oconv(1), xform(1)
| 69 |
.PP
| 70 |
MGF web site "http://radsite.lbl.gov/mgf/HOME.html"
