root/Development/ray/doc/man/man1/rad2mgf.1
Revision: 1.4
Committed: Sun Nov 30 17:53:07 2008 UTC (17 years ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, HEAD
Changes since 1.3: +6 -5 lines
Added mention of "mesh" primitive
# User Rev Content
1 greg 1.4 .\" RCSid "$Id: rad2mgf.1,v 1.3 2007/09/04 17:36:41 greg Exp $"
2 greg 1.1 .TH RAD2MGF 1 5/15/95 RADIANCE
3     .SH NAME
4     rad2mgf - convert RADIANCE scene description to Materials and Geometry Format
5     .SH SYNOPSIS
6     .B rad2mgf
7     [
8     .B \-dU
9     ]
10     [
11     .B input ..
12     ]
13     .SH DESCRIPTION
14     .I Rad2mgf
15     converts one or more RADIANCE scene files
16     to the Materials and Geometry Format (MGF).
17     Input units are specified with the
18     .I \-mU
19     option, where
20     .I U
21     is one of 'm' (meters), 'c' (centimeters), 'f' (feet) or 'i'
22     (inches).
23     The assumed unit is meters, which is the required output unit for
24     MGF (thus the need to know).
25     If the input dimensions are in none of these units, then the user
26     should apply
27     .I xform(1)
28     with the
29     .I \-s
30     option to bring the units into line prior to translation.
31     .PP
32     The MGF material names and properties
33     for the surfaces will be those assigned in RADIANCE.
34     If a referenced material has not been defined, then its name will
35     be invoked in the MGF output without definition, and the description
36     will be incomplete.
37     .SH LIMITATIONS
38     Although MGF supports all of the geometric types and the most
39     common material types used in RADIANCE, there is currently no
40     support for advanced BRDF materials, patterns, textures or mixtures.
41     Also, the special types "source" and "antimatter" are not supported,
42     and all light source materials are converted to simple diffuse emitters
43     (except "illum" materials, which are converted to their alternates).
44     These primitives are reproduced as comments in the output and
45     must be replaced manually if necessary.
46     .PP
47 greg 1.4 The RADIANCE "instance" and "mesh" types aretreated specially.
48 greg 1.1 .I Rad2mgf
49 greg 1.4 converts each instance or mesh to an MGF include statement,
50     using the corresponding
51     transformation and a file name derived from the octree or mesh name.
52     (The original octree/mesh suffix is replaced by ".mgf".)\0
53 greg 1.1 For this to work, the user must separately create the referenced
54     MGF files from the original RADIANCE descriptions.
55     The description file names can usually be determined using the
56     .I getinfo(1)
57     command run on the octrees in question.
58     .SH EXAMPLE
59     To convert three RADIANCE files (in feet) to one MGF file:
60     .IP "" .2i
61 greg 1.3 rad2mgf \-df file1.rad file2.rad file3.rad > scene.mgf
62 greg 1.1 .PP
63     To translate a RADIANCE materials file to MGF:
64     .IP "" .2i
65     rad2mgf materials.rad > materials.mgf
66     .SH AUTHOR
67     Greg Ward
68     .SH "SEE ALSO"
69     getinfo(1), ies2rad(1), mgf2meta(1), mgf2rad(1), obj2rad(1), oconv(1), xform(1)
70     .PP
71     MGF web site "http://radsite.lbl.gov/mgf/HOME.html"
