--- ray/doc/man/man1/rad.1 2008/12/18 23:26:57 1.8 +++ ray/doc/man/man1/rad.1 2015/05/26 10:00:46 1.11 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rad.1,v 1.8 2008/12/18 23:26:57 greg Exp $" +.\" RCSid "$Id: rad.1,v 1.11 2015/05/26 10:00:46 greg Exp $" .TH RAD 1 2/1/99 RADIANCE .SH NAME rad - render a RADIANCE scene @@ -7,7 +7,7 @@ rad - render a RADIANCE scene [ .B \-s ][ -.B "-n|-N npr" +.B "-n | -N npr" ][ .B \-t ][ @@ -439,6 +439,25 @@ For a space with penetrating sunlight casting bright p few places, it should be set to HIGH. The default value is "L". .TP +.BR PGMAP +This variable designates a global photon map to be generated by +.I mkpmap(1) +and used to accelerate rendering. +The file name must be followed by the number of photons to be stored +in the map, and this number may be followed by a bandwidth for rendering. +There is no default value, meaning that a global photon map will not +normally be created. +.TP +.BR PCMAP +This variable designates a caustic photon map to be generated by +.I mkpmap(1) +and used during renderings to model light transmission by reflecting +and refracting surfaces. +The file name must be followed by the number of photons to be stored +in the map, and this number may be followed by a bandwidth for rendering. +There is no default value, meaning that a caustic photon map will not +normally be created. +.TP .BR OPTFILE This is the name of a file in which .I rad @@ -487,6 +506,15 @@ See the .I rtrace(1) manual page for a list of valid options. .TP +.BR mkpmap +This variable may be used to specify additional options to +.I mkpmap. +If the first word of the first instance of this variable is not an option, +it will be used in place of the default command path, "mkpmap". +See the +.I mkpmap(1) +manual page for a list of valid options. +.TP .BR render This variable may be used to specify additional options to .I rpict @@ -579,6 +607,10 @@ rad \-V \-v Zl \-n \-s sample.rif > plan.vf # make a p rad \-t sample.rif # update files after minor change to input .br rad \-s sample.rif & # execute silently in the background +.br +rad \-N 2 sample.rif # render views using two parallel rpict calls +.br +rad \-N 4 -v 1 sample.rif # render first view with four rpiece calls .PP If we decide that the default values .I rad @@ -640,6 +672,17 @@ $(PICTURE)_$(view).unf Unfinished output of .SH AUTHOR Greg Ward .SH BUGS +You cannot run more than one +.I rad +process at a time on the same input file, +as the second process will attempt to recover the output files +of the first process, damaging the results. +The exceptions to this are running interactively via the +.I \-o +option, or rendering different views using the +.I \-v +option. +.PP Incremental building of octrees is not supported as it would add considerable complexity to .I rad. @@ -676,6 +719,7 @@ accurately determine the ambient value for The use of upper and lower case naming for the standard views may be problematic on systems that don't distinguish case in filenames. .SH "SEE ALSO" -glrad(1), make(1), mkillum(1), objview(1), oconv(1), +glrad(1), make(1), mkillum(1), mkpmap(1), objview(1), oconv(1), pfilt(1), raddepend(1), ranimate(1), -rholo(1), rpict(1), rtrace(1), rvu(1), touch(1), vgaimage(1), ximage(1) +rholo(1), rpict(1), rpiece(1), rtrace(1), rvu(1), +touch(1), vgaimage(1), ximage(1)
