| 1 |
.\" RCSid "$Id: rad.1,v 1.4 2004/01/01 19:31:45 greg Exp $"
| 2 |
.TH RAD 1 2/1/99 RADIANCE
| 3 |
.SH NAME
| 4 |
rad - render a RADIANCE scene
| 5 |
.SH SYNOPSIS
| 6 |
.B rad
| 7 |
| 8 |
.B \-s
| 9 |
| 10 |
.B "-n|-N npr"
| 11 |
| 12 |
.B \-t
| 13 |
| 14 |
.B \-e
| 15 |
| 16 |
.B \-V
| 17 |
| 18 |
.B \-w
| 19 |
| 20 |
.B "\-v view"
| 21 |
| 22 |
.B "\-o device"
| 23 |
| 24 |
.B rfile
| 25 |
| 26 |
.B "VAR\=value .."
| 27 |
| 28 |
.SH DESCRIPTION
| 29 |
.I Rad
| 30 |
is an executive program that reads the given
| 31 |
.I rfile
| 32 |
and makes appropriate calls to
| 33 |
.I oconv(1),
| 34 |
.I mkillum(1),
| 35 |
.I rpict(1),
| 36 |
.I pfilt(1),
| 37 |
and/or
| 38 |
.I rvu(1)
| 39 |
to render a specific scene.
| 40 |
Variables in
| 41 |
.I rfile
| 42 |
give input files and qualitative information about the rendering(s)
| 43 |
desired that together enable
| 44 |
.I rad
| 45 |
to intelligently set parameter values and control the simulation.
| 46 |
.PP
| 47 |
Normally, commands are echoed to the standard output as they are
| 48 |
executed.
| 49 |
The
| 50 |
.I \-s
| 51 |
option tells
| 52 |
.I rad
| 53 |
to do its work silently.
| 54 |
The
| 55 |
.I \-n
| 56 |
option tells
| 57 |
.I rad
| 58 |
not to take any action (ie. not to actually execute any commands).
| 59 |
The
| 60 |
.I \-N
| 61 |
option instructs
| 62 |
.I rad
| 63 |
to run as many as
| 64 |
.I npr
| 65 |
rendering processes in parallel.
| 66 |
The
| 67 |
.I \-t
| 68 |
option tells
| 69 |
.I rad
| 70 |
to bring rendering files up to date relative to the input
| 71 |
(scene description) files, without performing any actual
| 72 |
calculations.
| 73 |
If no octree exists, it is still necessary to run
| 74 |
.I oconv(1)
| 75 |
to create one, since the
| 76 |
.I \-t
| 77 |
option will not create invalid (i.e. empty) files, and
| 78 |
a valid octree is necessary for the correct operation of
| 79 |
.I rad.
| 80 |
The
| 81 |
.I \-e
| 82 |
option tells
| 83 |
.I rad
| 84 |
to explicate all variables used for the simulation, including
| 85 |
default values not specified in the input file, and print them on
| 86 |
the standard output.
| 87 |
.PP
| 88 |
Normally,
| 89 |
.I rad
| 90 |
will produce one picture for each view given in
| 91 |
.I rfile.
| 92 |
The
| 93 |
.I \-v
| 94 |
option may be used to specify a single desired view.
| 95 |
The
| 96 |
.I view
| 97 |
argument may either be a complete view specification
| 98 |
(enclosed in quotes and beginning with an optional identifier)
| 99 |
or a number or single-word identifier to match a view defined in
| 100 |
.I rfile.
| 101 |
If the argument is one of the standard view identifiers,
| 102 |
it may or may not be further elaborated in
| 103 |
.I rfile.
| 104 |
(See "view" variable description, below.)\0
| 105 |
If the argument does not match any views in
| 106 |
.I rfile
| 107 |
and is not one of the standard views, no rendering will take place.
| 108 |
This may be convenient when the only action desired of
| 109 |
.I rad
| 110 |
is the rebuilding of the octree.
| 111 |
In particular, the argument "0" will never match a view.
| 112 |
.PP
| 113 |
If the
| 114 |
.I \-V
| 115 |
option is given,
| 116 |
each view will be printed on the standard output before
| 117 |
being applied, in a form suitable for use in a view file or
| 118 |
.I rpict
| 119 |
rendering sequence.
| 120 |
This is helpful as feedback or for accessing the
| 121 |
.I rad
| 122 |
view assignments without necessarily starting a rendering.
| 123 |
.PP
| 124 |
By default,
| 125 |
.I rad
| 126 |
will run
| 127 |
.I rpict
| 128 |
and
| 129 |
.I pfilt
| 130 |
to produce a picture for each view.
| 131 |
The
| 132 |
.I \-o
| 133 |
option specifies an output device for
| 134 |
.I rvu
| 135 |
(usually "x11")
| 136 |
and runs this interactive program instead, using the first view in
| 137 |
.I rfile
| 138 |
or the view given with the
| 139 |
.I \-v
| 140 |
option as the starting point.
| 141 |
.PP
| 142 |
Additional variable settings may be added or overridden on the
| 143 |
command line following
| 144 |
.I rfile.
| 145 |
Upper case variables specified more than once will result in
| 146 |
a warning message (unless the
| 147 |
.I \-w
| 148 |
option is present),
| 149 |
and the last value given will be the one used.
| 150 |
.PP
| 151 |
The
| 152 |
.I \-w
| 153 |
option turns off warnings about multiply and misassigned variables.
| 154 |
.PP
| 155 |
Rendering variable assignments appear one per line in
| 156 |
.I rfile.
| 157 |
The name of the variable is followed by an equals sign
| 158 |
('=') and its value(s).
| 159 |
The end of line may be escaped with a backslash ('\\'), though it is
| 160 |
not usually necessary since additional variable values may be given
| 161 |
in multiple assignments.
| 162 |
Variables that should have only one value are given in upper case.
| 163 |
Variables that may have multiple values are given in lower case.
| 164 |
Variables may be abbreviated by their first three letters.
| 165 |
Comments in
| 166 |
.I rfile
| 167 |
start with a pound sign ('#') and proceed to the end of line.
| 168 |
.PP
| 169 |
The rendering variables, their interpretations and default values
| 170 |
are given below.
| 171 |
.TP 10n
| 172 |
.BR OCTREE
| 173 |
The name of the octree file.
| 174 |
The default name is the same as
| 175 |
.I rfile
| 176 |
but with any suffix replaced by ".oct".
| 177 |
(The octree must be a file --
| 178 |
.I rad
| 179 |
cannot work with commands that produce octrees.)\0
| 180 |
.TP
| 181 |
.BR ZONE
| 182 |
This variable specifies the volume of interest for this simulation.
| 183 |
The first word is either "Interior" or "Exterior", depending on
| 184 |
whether the zone is to be observed from the inside or the outside,
| 185 |
respectively.
| 186 |
(A single letter may be given, and case does not matter.)\0
| 187 |
The following six numbers are the minimum and maximum
| 188 |
X coordinates, minimum and maximum Y, and minimum and maximum Z
| 189 |
for the zone perimeter.
| 190 |
It is important to give the zone as it is used to determine many of
| 191 |
the rendering parameters.
| 192 |
The default exterior zone is the bounding cube for the scene as
| 193 |
computed by
| 194 |
.I oconv.
| 195 |
.TP
| 196 |
.BR EXPOSURE
| 197 |
This variable tells
| 198 |
.I rad
| 199 |
how to adjust the exposure for display.
| 200 |
It is important to set this variable properly as it is used to
| 201 |
determine the ambient value.
| 202 |
An appropriate setting may be discovered by running
| 203 |
.I rvu
| 204 |
and noting the exposure given by the "exposure =" command.
| 205 |
As in
| 206 |
.I rvu
| 207 |
and
| 208 |
.I pfilt,
| 209 |
the exposure setting may be given either as a multiplier or as a
| 210 |
number of f\-stop adjustments (eg. +2 or \-1.5).
| 211 |
There is no default value for this variable.
| 212 |
If it is not given, an average level will be computed by
| 213 |
.I pfilt
| 214 |
and the ambient value will be set to 10 for exterior zones
| 215 |
and 0.01 for interior zones.
| 216 |
.TP
| 217 |
.BR EYESEP
| 218 |
The interocular spacing for stereo viewing.
| 219 |
I.e., the world distance between the pupils of the left and right eyes.
| 220 |
The default value is the sum of the three "ZONE" dimensions divided by 100.
| 221 |
.TP
| 222 |
.BR scene
| 223 |
This variable is used to specify one or more scene input files.
| 224 |
These files will be given together with the materials file(s)
| 225 |
and any options specified by the "oconv" variable to
| 226 |
.I oconv
| 227 |
to produce the octree given by the "OCTREE" variable.
| 228 |
In-line commands may be specified in quotes instead of a file,
| 229 |
beginning with an exclamation mark ('!').
| 230 |
If the "scene" variable is not present, then the octree must already exist
| 231 |
in order for
| 232 |
.I rad
| 233 |
to work.
| 234 |
Even if this variable is given,
| 235 |
.I oconv
| 236 |
will not be run unless the octree is out of date with respect to
| 237 |
the input files.
| 238 |
Note that the order of files in this variable is important for
| 239 |
.I oconv
| 240 |
to work properly, and files given in later variable assignments will
| 241 |
appear after previous ones on the
| 242 |
.I oconv
| 243 |
command line.
| 244 |
.TP
| 245 |
.BR materials
| 246 |
This variable is used to specify files that, although they must
| 247 |
appear on the
| 248 |
.I oconv
| 249 |
command line, do not affect the actual octree itself.
| 250 |
Keeping the materials in separate files allows them to be modified
| 251 |
without requiring the octree to be rebuilt (a sometimes costly
| 252 |
procedure).
| 253 |
These files should not contain any geometry, and the
| 254 |
.I \-f
| 255 |
option must not be given in the "oconv" variable for this to work.
| 256 |
.TP
| 257 |
.BR illum
| 258 |
This variable is used to specify files with surfaces to be converted into
| 259 |
illum sources by
| 260 |
.I mkillum(1).
| 261 |
When this variable is given, additional octree files will be created
| 262 |
to contain the scene before and after illum source conversion.
| 263 |
These files will be named according to the (default) value of the
| 264 |
.I OCTREEE
| 265 |
variable, with either a '0' or a '1' appearing just before the file
| 266 |
type suffix (usually ".oct").
| 267 |
.TP
| 268 |
.BR objects
| 269 |
This variable is used for files that, although they do not appear
| 270 |
on the
| 271 |
.I oconv
| 272 |
command line, contain geometric information that is referenced
| 273 |
indirectly by the scene files.
| 274 |
If any of these files is changed, the octree will be rebuilt.
| 275 |
(The
| 276 |
.I raddepend(1)
| 277 |
command may be used to find these dependencies automatically.)\0
| 278 |
.TP
| 279 |
.BR view
| 280 |
This variable is used to specify a desired view for this zone.
| 281 |
Any number of "view" lines may be given, and each will result in a
| 282 |
rendered picture (unless the
| 283 |
.I \-v
| 284 |
or
| 285 |
.I \-o
| 286 |
option is specified).
| 287 |
The value for this variable is an optional identifier followed by
| 288 |
any number of view options (see
| 289 |
.I rpict(1)
| 290 |
for a complete listing).
| 291 |
The identifier is used in file naming and associating a desired view
| 292 |
with the
| 293 |
.I \-v
| 294 |
command line option.
| 295 |
Also, there are several standard view identifiers defined by
| 296 |
.I rad.
| 297 |
These standard views are specified by strings of the form
| 298 |
"[Xx]?[Yy]?[Zz]?[vlcah]?".
| 299 |
(That is, an optional upper or lower case X followed by an optional
| 300 |
upper or lower case Y followed by an optional upper or lower case Z
| 301 |
followed by an optional lower case V, L, C, A or H.)\0
| 302 |
The letters indicate the desired view position, where upper case X
| 303 |
means maximum X, lower case means minimum and so on.
| 304 |
The final letter is the view type, where 'v' is perspective (the
| 305 |
default), 'l' is parallel, 'c' is a cylindrical panorama,
| 306 |
'a' is angular fisheye, and 'h' is hemispherical fisheye.
| 307 |
A perspective view from maximum X, minimum Y would be "Xy" or "Xyv".
| 308 |
A parallel view from maximum Z would be "Zl".
| 309 |
If "ZONE" is an interior zone, the standard views will
| 310 |
be inside the perimeter.
| 311 |
If it is an exterior zone, the standard views will be outside.
| 312 |
Note that the standard views are best used as starting points,
| 313 |
and additional arguments may be given after the
| 314 |
identifier to modify a standard view to suit a particular model.
| 315 |
The default view is "X" if no views are specified.
| 316 |
A single specified view of "0" means no views will be automatically
| 317 |
generated.
| 318 |
.TP
| 319 |
.BR UP
| 320 |
The vertical axis for this scene.
| 321 |
A negative axis may be specified with a minus sign (eg. "\-Y").
| 322 |
There is no default value for this variable, although the standard
| 323 |
views assume Z is up if no other axis is specified.
| 324 |
.TP
| 325 |
.BR RESOLUTION
| 326 |
This variable specifies the desired final picture resolution.
| 327 |
If only a single number is given, this value will be used for both
| 328 |
the horizontal and vertical picture dimensions.
| 329 |
If two numbers are given, the first is the horizontal resolution and
| 330 |
the second is the vertical resolution.
| 331 |
If three numbers are given, the third is taken as the pixel aspect
| 332 |
ratio for the final picture (a real value).
| 333 |
If the pixel aspect ratio is zero, the exact dimensions given will
| 334 |
be those produced.
| 335 |
Otherwise, they will be used as a frame in which the final image
| 336 |
must fit.
| 337 |
The default value for this variable is 512.
| 338 |
.TP
| 339 |
.BR QUALITY
| 340 |
This variable sets the overall rendering quality desired.
| 341 |
It can have one of three values, "LOW", "MEDIUM" or "HIGH".
| 342 |
These may be abbreviated by their first letter, and may be
| 343 |
in upper or lower case.
| 344 |
Most of the rendering options will be affected by this setting.
| 345 |
The default value is "L".
| 346 |
.TP
| 347 |
.BR PENUMBRAS
| 348 |
This is a boolean variable indicating whether or not penumbras are
| 349 |
desired.
| 350 |
A value of "TRUE" will result in penumbras (soft shadows), and a
| 351 |
value of "FALSE" will result in no penumbras (sharp shadows).
| 352 |
True and false may be written in upper or lower case, and may be
| 353 |
abbreviated by a single letter.
| 354 |
Renderings generally proceed much faster without penumbras.
| 355 |
The default value is "F".
| 356 |
.TP
| 357 |
.BR INDIRECT
| 358 |
This variable indicates how many diffuse reflections are important in the
| 359 |
general lighting of this zone.
| 360 |
A direct lighting system (eg. fluorescent troffers recessed in the
| 361 |
ceiling) corresponds to an indirect level of 0.
| 362 |
An indirect lighting system (eg. hanging fluorescents directed at a
| 363 |
reflective ceiling) corresponds to an indirect level of 1.
| 364 |
A diffuse light shelf reflecting sunlight onto the ceiling would
| 365 |
correspond to an indirect level of 2.
| 366 |
The setting of this variable partially determines how many interreflections
| 367 |
will be calculated.
| 368 |
The default value is 0.
| 369 |
.TP
| 370 |
.BR PICTURE
| 371 |
This is the root name of the output picture file(s).
| 372 |
This name will have appended the view identifier (or a number if no
| 373 |
id was used) and a ".pic" suffix.
| 374 |
If a picture corresponding to a specific view exists and is not out
| 375 |
of date with respect to the given octree, it will not be
| 376 |
re-rendered.
| 377 |
The default value for this variable is the root portion of
| 378 |
.I rfile.
| 379 |
.TP
| 380 |
.BR RAWFILE
| 381 |
This is the root name of the finished, raw
| 382 |
.I rpict
| 383 |
output file.
| 384 |
If specified,
| 385 |
.I rad
| 386 |
will rename the original
| 387 |
.I rpict
| 388 |
output file once it is finished and filtered
| 389 |
rather than removing it, which is the default action.
| 390 |
The given root name will be expanded in the same way as the
| 391 |
"PICTURE" variable, and if the "RAWFILE" and "PICTURE" variables
| 392 |
are identical, then no filtering will take place.
| 393 |
.TP
| 394 |
.BR ZFILE
| 395 |
This is the root name of the raw distance file produced by the
| 396 |
.I \-z
| 397 |
option of
| 398 |
.I rpict.
| 399 |
To this root name, an underscore plus the view name plus a ".zbf"
| 400 |
suffix will be added.
| 401 |
If no "ZFILE" is specified, none will be produced.
| 402 |
.TP
| 403 |
.BR AMBFILE
| 404 |
This is the name of the file where "ambient" or diffuse interreflection
| 405 |
values will be stored by
| 406 |
.I rpict
| 407 |
or
| 408 |
.I rvu.
| 409 |
Although it is not required, an ambient file should be given whenever
| 410 |
an interreflection calculation is expected.
| 411 |
This will optimize successive runs and minimize artifacts.
| 412 |
An interreflection calculation will take place when the
| 413 |
"QUALITY" variable is set to HIGH, or when the "QUALITY"
| 414 |
variable is set to MEDIUM and "INDIRECT" is positive.
| 415 |
| 416 |
.TP
| 417 |
.BR DETAIL
| 418 |
This variable specifies the level of visual detail in this zone,
| 419 |
and is used to determine image sampling rate, among other things.
| 420 |
If there are few surfaces and simple shading, then this should be set
| 421 |
to LOW.
| 422 |
For a zone with some furniture it might be set to MEDIUM.
| 423 |
If the space is very cluttered or contains a lot of geometric detail
| 424 |
and textures, then it should be set to HIGH.
| 425 |
The default value is "M".
| 426 |
.TP
| 427 |
.BR VARIABILITY
| 428 |
This variable tells
| 429 |
.I rad
| 430 |
how much light varies over the surfaces of this zone, and is
| 431 |
used to determine what level of sampling is necessary in the
| 432 |
indirect calculation.
| 433 |
For an electric lighting system with uniform coverage, the value
| 434 |
should be set to LOW.
| 435 |
For a space with spot lighting or a window with sky illumination
| 436 |
only, it might be set to MEDIUM.
| 437 |
For a space with penetrating sunlight casting bright patches in a
| 438 |
few places, it should be set to HIGH.
| 439 |
| 440 |
.TP
| 441 |
.BR OPTFILE
| 442 |
This is the name of a file in which
| 443 |
.I rad
| 444 |
will place the appropriate rendering options.
| 445 |
This file can later be accessed by
| 446 |
.I rpict
| 447 |
or
| 448 |
.I rvu
| 449 |
in subsequent manual runs using the at-sign ('@') file insert option.
| 450 |
(Using an "OPTFILE" also reduces the length of the rendering
| 451 |
command, which improves appearance and may even be necessary on some
| 452 |
systems.)\0
| 453 |
| 454 |
.TP
| 455 |
.BR REPORT
| 456 |
This variable may be used to specify a reporting interval for
| 457 |
batch rendering.
| 458 |
Given in minutes, this value is multiplied by 60 and passed to
| 459 |
.I rpict
| 460 |
with the
| 461 |
.I \-t
| 462 |
option.
| 463 |
If a filename is given after the interval, it will be used as the
| 464 |
error file for reports and error messages instead of the standard error.
| 465 |
(See the
| 466 |
.I \-e
| 467 |
option of
| 468 |
.I rpict(1).\)\0
| 469 |
| 470 |
.TP
| 471 |
.BR oconv
| 472 |
This variable may be used to specify special options to
| 473 |
.I oconv.
| 474 |
See the
| 475 |
.I oconv(1)
| 476 |
manual page for a list of valid options.
| 477 |
.TP
| 478 |
.BR mkillum
| 479 |
This variable may be used to specify additional options to
| 480 |
.I mkillum.
| 481 |
See the
| 482 |
.I rtrace(1)
| 483 |
| 484 |
.TP
| 485 |
.BR render
| 486 |
| 487 |
.I rpict
| 488 |
or
| 489 |
.I rvu.
| 490 |
These options will appear after the options set automatically by
| 491 |
.I rad,
| 492 |
and thus will override the default values.
| 493 |
.TP
| 494 |
.BR pfilt
| 495 |
| 496 |
.I pfilt.
| 497 |
See the
| 498 |
.I pfilt(1)
| 499 |
manual page for details.
| 500 |
.SH EXAMPLES
| 501 |
A minimal input file for
| 502 |
.I rad
| 503 |
might look like this:
| 504 |
.IP "" .3i
| 505 |
.nf
| 506 |
| 507 |
sample.rif
| 508 |
| 509 |
# The octree we want to use:
| 510 |
OCTREE= tutor.oct # w/o this line, name would be "sample.oct"
| 511 |
# Our scene input files:
| 512 |
scene= sky.rad outside.rad room.rad srcwindow.rad
| 513 |
# The interior zone cavity:
| 514 |
ZONE= I 0 3 0 2 0 1.75 # default would be scene bounding cube
| 515 |
# The z-axis is up:
| 516 |
UP= Z # no default - would use view spec.
| 517 |
# Our exposure needs one f-stop boost:
| 518 |
EXPOSURE= +1 # default is computed ex post facto
| 519 |
.fi
| 520 |
.PP
| 521 |
Note that we have not specified any views in the file above.
| 522 |
The standard default view "X" would be used if we were to run
| 523 |
.I rad
| 524 |
on this file.
| 525 |
If we only want to see what default values
| 526 |
.I rad
| 527 |
would use without actually executing anything, we can invoke it thus:
| 528 |
.IP "" .2i
| 529 |
rad \-n \-e sample.rif
| 530 |
.PP
| 531 |
This will print the variables we have given as well as default
| 532 |
values
| 533 |
.I rad
| 534 |
has assigned for us.
| 535 |
Also, we will see the list of commands that
| 536 |
.I rad
| 537 |
would have executed had the
| 538 |
.I \-n
| 539 |
option not been present.
| 540 |
(Note if the octree, "tutor.oct", is not present, an error will
| 541 |
result as it is needed to determine some of the opiton settings.)\0
| 542 |
.PP
| 543 |
Different option combinations have specific uses, ie:
| 544 |
.IP "" .2i
| 545 |
.br
| 546 |
rad \-v 0 sample.rif OPT=samp.opt # build octree, put options in "sample.opt"
| 547 |
.br
| 548 |
rad \-n \-e \-s sample.rif > full.rif # make a complete rad file
| 549 |
.br
| 550 |
rad \-n sample.rif > script.sh # make a script of commands
| 551 |
.br
| 552 |
rad \-V \-v Zl \-n \-s sample.rif > plan.vf # make a plan view file
| 553 |
.br
| 554 |
rad \-t sample.rif # update files after minor change to input
| 555 |
.br
| 556 |
rad \-s sample.rif & # execute silently in the background
| 557 |
.PP
| 558 |
If we decide that the default values
| 559 |
.I rad
| 560 |
has chosen for our variables are not all appropriate, we can add
| 561 |
some more assignments to the file:
| 562 |
.IP "" .3i
| 563 |
.nf
| 564 |
QUAL= MED # default was low
| 565 |
DET= low # default was medium - our space is almost empty
| 566 |
PEN= True # we want to see soft shadows from our window
| 567 |
VAR= hi # daylight can result in fairly harsh lighting
| 568 |
view= XYa \-vv 120 # let's try a fisheye view
| 569 |
PICT= tutor # our picture name will be "tutor_XYa.pic"
| 570 |
.fi
| 571 |
.PP
| 572 |
Note the use of abbreviations, and the modification of a standard
| 573 |
view.
| 574 |
Now we can invoke
| 575 |
.I rad
| 576 |
to take a look at our scene interactively with
| 577 |
.I rvu:
| 578 |
.IP "" .2i
| 579 |
rad \-o x11 sample.rif
| 580 |
.PP
| 581 |
.I Rad
| 582 |
will run
| 583 |
.I oconv
| 584 |
first to create the octree (assuming it doesn't
| 585 |
already exist), then
| 586 |
.I rvu
| 587 |
with a long list of options.
| 588 |
Let's say that from within
| 589 |
.I rvu,
| 590 |
we wrote out the view files "view1.vp" and "view2.vp".
| 591 |
We could add these to "sample.rif" like so:
| 592 |
.IP "" .2i
| 593 |
.nf
| 594 |
view= vw1 \-vf view1.vp # Our first view
| 595 |
view= vw2 \-vf view2.vp # Our second view
| 596 |
RESOLUTION= 1024 # Let's go for a higher resolution result
| 597 |
.fi
| 598 |
.PP
| 599 |
To start
| 600 |
.I rvu
| 601 |
again using vw2 instead of the default, we use:
| 602 |
.IP "" .2i
| 603 |
rad \-o x11 \-v vw2 sample.rif
| 604 |
.PP
| 605 |
Once we are happy with the variable settings in our file, we can run
| 606 |
.I rad
| 607 |
in the background to produce one image for each view:
| 608 |
.IP "" .2i
| 609 |
rad sample.rif REP=5 >& errfile &
| 610 |
.PP
| 611 |
This will report progress every five minutes to "errfile".
| 612 |
.SH FILES
| 613 |
$(PICTURE)_$(view).unf Unfinished output of
| 614 |
.I rpict
| 615 |
.SH AUTHOR
| 616 |
Greg Ward
| 617 |
.SH BUGS
| 618 |
Incremental building of octrees is not supported as it would add
| 619 |
considerable complexity to
| 620 |
.I rad.
| 621 |
Complicated scene builds should still be left to
| 622 |
.I make(1),
| 623 |
which has a robust mechanism for handling hierarchical
| 624 |
dependencies.
| 625 |
If
| 626 |
.I make
| 627 |
is used in this fashion, then only the
| 628 |
"OCTREE" variable of
| 629 |
.I rad
| 630 |
is needed.
| 631 |
.PP
| 632 |
The use of some
| 633 |
.I pfilt
| 634 |
options is awkward, since the "EXPOSURE" variable results in a
| 635 |
single pass invocation (the
| 636 |
.I \-1
| 637 |
option of
| 638 |
.I pfilt\)
| 639 |
and two passes are necessary for certain effects, such as star
| 640 |
patterns.
| 641 |
The way around this problem is to specify
| 642 |
a "RAWFILE" that is the same as the "PICTURE" variable so that no
| 643 |
filtering takes place, then call
| 644 |
.I pfilt
| 645 |
manually.
| 646 |
This is preferable to leaving out the
| 647 |
"EXPOSURE" variable, since the exposure level is needed to
| 648 |
accurately determine the ambient value for
| 649 |
.I rpict.
| 650 |
.PP
| 651 |
The use of upper and lower case naming for the standard views may be
| 652 |
problematic on systems that don't distinguish case in filenames.
| 653 |
.SH "SEE ALSO"
| 654 |
glrad(1), make(1), mkillum(1), objview(1), oconv(1),
| 655 |
pfilt(1), raddepend(1), ranimate(1),
| 656 |
rholo(1), rpict(1), rtrace(1), rvu(1), touch(1), vgaimage(1), ximage(1)
